Car covers
I need advise on getting a top quality outside car cover,as i have a car i need to keep outside(NOT the 25!)but want it covered as i don,t plan to use it much,any advise?Had covers before but lifted them off after a heavy shower and the car is soaking,also interested in them up and over steel framed jobbies,any info??Must keep the car bone dry.
At this time off the year no cover will stop the condensation :( ive tried a few different covers but none are as good as an insulated garage :wink: the carcoon is very good but also very pricey.
A fitted car cover will be very hard to keep condensation-free inside... even the really expensive ones will retain some moisture.I'd be very wary of a steel-framed tent type, purely for the fact if you get a good wind you've got a lot of metal tubes waving around near your car.
I read recently about people having issues with paint microblistering caused by covers. Not experienced it myself but then most of the cars i have under covers have shite paintwork anyway.
My Escort has a bit of the microblistering on the (repainted) bonnet now after being under a cover.It's from direct contact of the cover with the panel, if you can keep the cover off the car with a frame so that there is airflow it should be o.k.
Microblistering tends to be a problem on newer paint - I beleive.If its done a few seasons, its usually OK,treated 'reasonably'.Carcoons your best option, although I'dbe tempted tofashionashort term car port using a few lengths of clear corrugated plastic. Air circulation will ensure it stays dry-longest.
