Tommy's A-series Misery - NC500 prep!
I found CIF the best thing to get oily grime out of the paint on pigs. They do tend to absorb oily finger prints.
I did this. It came out rally well!
Before
After
Its not perfect but it looks a lot better if you ignore all the scratches
On 21/03/2025 at 22:13, Tommyboy12 said:
Also the Rialto will definitely be up for sale here when it's time!
  • Agree 1
Excellent! Often the best things aren't the obvious ones. I used to call these the silly boot,it is strange reliant bothered to make the saloon being the estate was by far the most popular. I think at the time they couldn't get the strength in the roof for the hatch that came out in 87, or had simply not thought it was needed and wanted to cater for those that wanted a saloon.
They were however seemingly more stable at speed and generally felt a bit more solid+all things are relative of course!)
Well I tried to go to work today...PXL_20250404_062734099.jpg.7ecb1a5060708d36e612909a98e3d7b8.jpg
I think I might have cooked it 😅
I've had a lovely time sitting in the sun all day.
Turns out I popped a core plug
Back of engine/head?
I'm almost certain I once fixed a broken down passing Reliant by drilling an hole in the bulkhead and poking a long bar through to tap a new core plug in.
It is indeed that one. Thankfully on Rialto's there's a service hatch behind the centre 'console' so a couple of screws and I'll have easy access.
I'm hoping that I haven't cooked the head gasket but I have bought one just incase
Yes bang in with a rounded 3/4" extension was my method.
In a stellar show of service CHG Classics (a 3 and 4 wheel Reliant specialist) had my parts on the door step 18 hours after I ordered them!
Remove access panels
Find I have no core plug
Clean up the hole and bang in a new one
I think Ill give my cooling system another flush...
It still runs nicely so I'm hoping that it hasn't cooked it's head gasket but I have picked up £20 kit regardless
Fingers crossed that this is a quick fix 🤞
I assume that any of the others are a pain to get to?  I'd have been tempted to do the lot if they're not buried under the manifold or something like that.  If one has failed I'd not expect the rest to be far behind.
Or are these engines known for randomly spitting the rear one out?
There are no others it's just a single core plug on the back of the cylinder head. The block is very simple and uses liners so no need for complex core castings and plugs.
I know they're known for rotting out. I suspect it had partially rotted out then fallen out. I am just basing this on the sheer amount of silt and crud in the engine when I jet washed it out.
Every day's a school day.  I didn't know that about the construction.  One less thing to worry about then.
Yeah, definitely looks like a few regular coolant flushes are on the cards!
It was not a quick fix...
I did a 20 minute drive round the town and it ran fine to begin with then slowly got hotter and hotter until I called it quits and pulled back up at home.
I did a compression test and it came back healthy (160-170psi) on all cylinders.  Thought I would check the cap and this made me sad
It also had a lot more oil than I remember putting in 😅
Anyone got any chips?
Needless to say things escalated...
Reliant engines are rather notorious for welding their heads to the studs and this one was no exception. Thankfully I have already been here before and had made a tool for such a job.
Yes it's some box with some holes badly drilled in it. Did it work? Yes. Yes it did. It basically pushes down on the head studs using the rocker studs as leverage.
However that was only half the battle. I had to fight the cylinder head off to the very end. Driving more and more wedges into it to get it moving.
Eventually it came off and I was greeted to more blocked cooling galleries which probably didn't help
Yummy
In for a penny in for a pound so I jet washed the head and the bloke water passages and thought I'd clean the block while I was at it. Loads of water got in the bores but seeing as I'm changing the oil anyway it's not really a problem.
New head gasket and cleaned head back on
It's a very laborious torque tightening sequence on these heads. There's 15 head studs to be tightened to a mere 25lb. But they ideally need doing in stages. Some do it in 5lb increments but I do not have the patience for that so I did 10, 18, 25lb. You cant access all of them from one place and you need different length extensions depending on the stud due to other stuff being in the way. So begins a circus of moving from bonnet to passenger seat to drivers seat with various lengths of extension.
Then back on with the rocker assembly, rocker cover, carb, and dizzy. Start and run it for 30 seconds then leave it to cool. This seals a ring of sealant that runs round the head gasket.
Tomorrow I'll be stripping the carb and rocker assembly back off to retorque the studs. You're then meant to do that again at 500 miles.
However! It runs again!
I just hope it doesn't continue to mix oil and water. If it does then it's likely a liner has corroded through the liner seal and coolant is leaking into the sump directly. Or less likely it's  corroded through an oil gallery in the side of the block. That usually puts oil in the cooling system rather than the other way around but if either of those things happen I'm acquiring a new engine.
I said to myself last time I was never doing a reliant head gasket again. But here we are!
Yummy
On the other hand. Considering what you and Sharley have planned, far better it throws all its toys out the cot now close to home. Then you can do the necessary and be fighting fit for the big trip.
  • Agree 2
I do agree. I would rather it did it now than in July!
My worst pig head gasket took 4 days to get the head off,with the tool.was stuck on one corroded stud all the way.i tended to open the holes up a bit in the head somit wouldn't happen again. So pleased you will be retorquing in the morning, an old reliant whizz told me to do it about five times with five hot and cold cycles,no driving,the amount it expands,contracts and how much more turn you get on the nuts is un real, leaving it 500 miles is a recipe to fail.absolute arse getting the rockers and setting the valves each time though!
We are now at the stage where age has caused a few to corrode through the oil ways, I suspect in your case it may just be old age with the gasket,your mayo content isn't anywhere near what I've had to spoon out of a rocker before 😂
Given how much crap is in there I wonder if a new radiator might just be worth it as a preventative measure - it's unlikely to be at all healthy if there's been that much crap floating around in there.
This is a new to me radiator already but I do plan to flush it out in situ again before I refit everything.
I guess I'll retorque it a few more times before 500 miles. I will be honest I didn't spend a huge amount of time setting valve gaps. I just check it actually had one and moved on to the next. Not much point doing much more for 30 seconds of running
I did another torque down and ran the engine up to temp last night over about 20-30 mins. It runs great and didnt overheat! It did bubble through the rad a lot to begin with which had me worried that a cylinder was pressuring the cooling system but I think it was burping itself out as the level suddendly dropped and it stopped bubbling.
Tonight I need to go through the process for the third retorque. Then I can try to get some miles on the new gasket.
  • Like 9
If you can be arsed to check,have a look at the stat,if it hasn't got a bleed valve in the edge,drill a 5mm hole in it,this helps stop any air locks and is something I did to all of mine. re profiling the fan to a smoother more rounded shape is something I played with as well as a free mod.
I changed the stat already and it didn't have a bleed hole. I do need to take it out and replace the gasket as it's weeping so I'll drill a hole in it
The older original stats always had this little jiggle pin type thing in the lip,I used to replicate this by drilling a small hole,it always helped when filling it up as always got an air lock in the heater matrix.i figured it was a good thing to have.
This car has been sent to test me
I'm going to look at the cooling system some more. Take the water pump off and check it and the passageways. If there's nothing there I'm hunting for a new engine
10 hours ago, plasticvandan said:
Is it actually getting hot though?
Well when I pull the rad cap I get steam and no water, as in its all gone and the rad is empty, so yes I suspect it is!
Only ask as there are a lot of sender's which give incorrect readings.
Did it mix it again, or did some seal blow and it leaked it all out?
