hairnet Posted September 20, 2019 Posted September 20, 2019 Charlotte Heading home Bye Phil Thanks Phil STUNO and The Moog 2
PhilA Posted September 20, 2019 Author Posted September 20, 2019 #5 washer ordered. Hoping Tuesday it'll be here. Reset timing, noticed that revving the engine the timing was moving the other way. Not sure the vacuum retard works- gonna check on that after the fact. Phil
PhilA Posted September 21, 2019 Author Posted September 21, 2019 Oil change ready; just bought 2 gallons of engine oil for $21 I like this "unsuitable for engines newer than about 1994" business. Phil LightBulbFun 1
Zelandeth Posted September 21, 2019 Posted September 21, 2019 Is there any sort of standardised colour scheme for the wiring like was common on British cars back at least in the 60s and 70s? While a lot of the detail work will still involve crawling around with a multimeter and crossing as many fingers as you can, it can at least speed along the basic sanity checks or help narrow down potential faults.
PhilA Posted September 21, 2019 Author Posted September 21, 2019 Within brands, yes. I have used... not the colors they had. But the scheme makes sense. Phil
hairnet Posted September 21, 2019 Posted September 21, 2019 due to considerations would y'all be up for a visit in october
hairnet Posted September 22, 2019 Posted September 22, 2019 22 hours ago, PhilA said: Within brands, yes. I have used... not the colors they had. But the scheme makes sense. Phil if you redo it and it makes sense to you if you ever fix it then why not
hairnet Posted September 22, 2019 Posted September 22, 2019 17 hours ago, PhilA said: Whenabouts? 18 21 october its only a maybe due to well, the story is (and it here as it happened while on the visit ) did deals gap and blue ridge on weds - got back and needed a drink and ice cream went to the gas station next to the house and bought ice cream and some dr pepper id been talking to phil about scratchcards in vending machines - this lot didnt do that but had like in england a stand on the counter with a few in decided to buy two 5 buck ones they had 1 to 20 dollar ones took them home and didnt think anything of them thursday did wheels thru time and remembered the cards scratched the ben one and ooh $5 scratched the other one and nothing so i went to cash in the $5 one........ got there and realised id brought this one you notice the 38? - id not scratched this and while waiting to be served i scratched it and got the 38 - ooh 25 bucks so waited to be served and give in the ticket she scratched the panel at the bottom for the barcode and scanned it *ALL KINDS OF MUSICAL NOISES what does that mean? its only 25 bucks 'youve won...........' spartacus 1
hairnet Posted September 22, 2019 Posted September 22, 2019 *ABSOLUTLEY STUNNED i stood there and couldnt say anything loserone 1
somewhatfoolish Posted September 22, 2019 Posted September 22, 2019 Quick! buy some chod! hairnet and beko1987 2
hairnet Posted September 22, 2019 Posted September 22, 2019 Walked back to the house Sat down outside here and wondered wtf just happened for an hour The other ice cream I'd bought melted
hairnet Posted September 23, 2019 Posted September 23, 2019 phils done a meatloaf on us tell us about the silverado ffs
PhilA Posted September 23, 2019 Author Posted September 23, 2019 I did a whatnow? Silverado? Daily hack. 2007 model. 1500 LT. Nothing particularly special
PhilA Posted September 24, 2019 Author Posted September 24, 2019 One headlight was missing this little clip. P.O. had used Sikaflex to hold the headlight trim on, sub-optimal. New clip $12, screw that. Take a length of baling wire and bend to shape. Unfortunately baling wire has the metal strength of plasticine. Cue heat treatment! Warm the wire up until it's orange hot and then quench in water. Repeat but not quite so hot. Then heat to cherry red and let cool slowly. Result- harder metal that still has a bit of spring. Fit into place, nice design that it's mostly geometric lock. With Sikaflex removed, peg now fits into the slot at the top. Screw holds it in at the bottom. Nice. Matches the other side now and is significantly less likely to fall off. Phil paulplom, LightBulbFun, beko1987 and 6 others 9
hairnet Posted September 24, 2019 Posted September 24, 2019 12 hours ago, PhilA said: I did a whatnow? Silverado? Daily hack. 2007 model. 1500 LT. Nothing particularly special Far flasher than a mk5 fiesta ? meatloaf - 2 outta 3 ain't bad ?
PhilA Posted September 25, 2019 Author Posted September 25, 2019 20 hours ago, hairnet said: @PhilA need to hear it noise It really doesn't make a whole lotta noise- standard intake and exhaust system. Vortec is a quiet V8 in stock guise.
PhilA Posted September 25, 2019 Author Posted September 25, 2019 Hopefully the last piece in the gearbox puzzle. Phil STUNO, hairnet, stonedagain and 3 others 6
PhilA Posted September 26, 2019 Author Posted September 26, 2019 That'll do. Thunderbirds might possibly be go. Phil Tickman, paulplom, Skizzer and 1 other 4
PhilA Posted September 26, 2019 Author Posted September 26, 2019 With everything coming up in the next few weeks I don't think I'll be making it to Cruisin' The Coast. Maybe next year. Phil
hairnet Posted September 26, 2019 Posted September 26, 2019 shame - you were talking about that sounded like a larf
PhilA Posted September 26, 2019 Author Posted September 26, 2019 Tonight is brought to you by the letter T. T is for Torque! Lowercase t. Main caps tightened and locked in place with tab. Drive case oil rings in place. Torus snap rings back in their grooves. Stopped for dinner LightBulbFun, somewhatfoolish and adw1977 3
PhilA Posted September 27, 2019 Author Posted September 27, 2019 Fitted new oil rings to the governor shaft. Fitted governor in place and located front servo and feed pipe from rear pump. Rear servo in place, front oil pickup pipe and strainer. Reverse lever mechanism and valve block fitted. New oil seals and rings put on. Oil pans fitted. Will have to take them apart again to redo initial band adjustment but wanted to make sure everything fitted and no crap gets in. My shoulder is killing me now. Phil tooSavvy, Skizzer, grizgut and 5 others 8
PhilA Posted September 28, 2019 Author Posted September 28, 2019 I took the lower oil pan off the gearbox again. The brake bands require an initial adjustment in order to function correctly. The rear band is set by measuring the distance from the rear of the servo to the end of the pin. It's meant to be 5 7/16". Slack, it's quite a bit more than that. I wound the adjustment bolt in. Accounting for parallax, that's now set correctly. Adjustment locknut tightened up and that called done. The front band is a little more difficult to set- this plug needs to come out, a 7/16" insert needs to go in with a stud or bolt down the center that can be used to accurately wind the piston down by 300 thou'. Once that's preloaded the band adjuster is tightened up until the band is snug. I need to go to the hardware store to get a brass fitting (easy to tap a thread in) to do this, then I can put the oil pan back on and think about the fluid torus. Phil Skizzer, mercedade, RayMK and 4 others 7
