Xantia of Desires - Farewell xantia!
Like said above . Disconnect / plug the boost sense pipe to the UFO when you are round the corner from the test centre .
I can't say I really agree with this approach but it will get you out of a sticky situation.
I'm no greeny but I don't really like to see too many cars belching out smoke
No, not tried injector cleaner. I don't think it needs it, as in it doesnt smoke in normal driving, and I really tried to get it to smoke on the way to and from work today. But nothing.
Nothing for 22 miles of b road, a road, m40 and a road. In fact I got to work a bit early today, and my nate had just arrived too so I showed him the smoke. As in just stopped after a 35 minute drive, parked, neutral, full throttle, burp of black smoke.
Coming home I held it at 4.5k in the most unmechanically sympathetic way when I got off the m40, and no smoke that I could see in the mirrors.
Got to stop ragging it about now though, got 1/4 a tank and I need it to last, bit skint now!
Tried it disconnected, still smoked. Perhaps not as black, but still lots of smoke. As it hits top revs with your foot buried in the carpet, belch. Lift off, and it's gone, whisping down the road romantically
I think so. If it smoked more, then I'd lean towards magic potion, but it doesn't, so it's got to be something physical. It needs Danny's magic hands!
If it was a dodgy hoover turbopower, I'd change the motor fan, seal up the fancase and mod the tool suction slide, but it's not, and therefore I know nothing!
Just drive it normally till Saturday and don't tinker any more or try and get it hot.
It sounds like a problem that is easily sorted with not many tools and a bit of patience.
Panic from Saturday afternoon onwards.
Stop it! I like my car. Ever since I sat in it pissed on homebrew at SF16 I loved it! It's just a minor blip, it'll be ok...
possibly...
Sorry for letting you sit in it then :-( feel bad you having hard times mate. I didn't touch anything on it though. I didn't understand it fully to tinker with it and as it ran fine I had no reason to mess it about.
No don't be sad, these things happen! I'm still very pleased with it.
Its just one of those things, the gamble we take when buying modified cars!
i thought it was not opening the whole UFO up and physically turning the pin, I just popped the cap off and undid the locknutted screw 2 turns.... worried now (although it didn't break, I just won't play with it anymore)
I tried taking the boost hose off and revving it and still got the soot, didn't bung it up though.
Meh, I'll wait until Saturday. Want to find out how it all works anyway and maybe get it de-tuned slightly for more mingebaggeryness with the fuel, it's nice to be able to do 80 in 3rd but I can't say when I last did it bar last week to clear it out in the hope it sorted it.
What you did was fine. All that screw outside does is set how far down the pin sits at rest.
Oh Chompy. Did it pass an MOT in its tuned state?
I its had a hard time getting it through before but everyone's had more friendlier testers who ragged it until it was nice and hot and it squeaked through. I haven't got that luxury, although I'm hopeful that if it's sorted now, next year's test should be a breeze!
Id quite like to be able to tweak it up and down, it is fun when fast, but I need Danny to show me what to do and how to reset it
Its more economical atm though, 100 miles and the needle hasn't moved! It's also lovely and silent with the new exhaust
Don't know much about these. Its the fuel pump a bit like a carb, in the way the mixture can be adjusted? Does it have an ecu to control the fueling or is it all manual adjustments?
It has an ecu, but I don't know if it controls anything
For emissions, the pump is still mostly mechanical bar an electronic timing advance (possibly?).
I am in no way expert on xud's, but if it's not boosting properly it will not clear the black smoke. Does it drive like a 90bhp turbo diesel should? Or could you increase the boost to clear the smoke?
Nah its properly quick once you get above 3k revs. Will do 85 in 3rd before I fully realise! A few days after I got it I got it to defiantly mot 120 on the m40 quite easily, although it felt a bit unstable, was at the red line and I've never done it again (came across someone doing 75 in L3 on an otherwise empty motorway, but couldn't call him a cocktard because I was being more illegal)
Its always felt less nippy at lower revs than the zx did, but the zx weighed alot less.
Do be sure all the tyres are in 1st class order and not low on pressure at those speeds, if it felt unstable then chances are something's not right, mebbe spheres? [/oldfart]
The tyres are old, the spheres are hard.... The wheel wobble vanishes at over 90 though! (well, it did, not tried it recently!)
Well magic Danny has worked his magic! So I now have a less harsh lda pin, rotated to the less harsh part, and he turned the fuel right down and so far, no black smoke!
Thanks Arthur! Will get it hot on the way home and double check the smoke
:mrgreen:  great news, hope it passes. If it does you need one of these for the lol  :mrgreen:
It had one of those on it when I bought it! It now just reads no poke...
Hopefully it passes now dude.
Then you can turn the LDA back the other way and crank the fuel again, just maybe not quite as much next time.
Home now! After the run back, repeated snap acceleration produces a whispy light cloud of light grey, not a black ash cloud, so that's hopeful!
Its also a different car to drive! It's detuned massively, and feels more like a normal xud, with a gentle wave of boost, rather then a slingshot. It's quite pleasant though!
The plan is to leave it be for now and get it passed. I light leave the lda alone, it's nice and pottery. Or I'll turn it around to the cut part and have the mahoosive speed back...
Looking good so far. It's going to go back to somewhere else for the mot too as I'll have to get it done near work. That might help
