Bren Posted December 28, 2014 Posted December 28, 2014 Any vauxhall gurus here? Looking for a cheap code reader on shite bay to see exactly why my 07 vectra diesel is a bastard to start. My mate lent me his sons reader, however the plug was different - his car is a petrol 1.6. My local specialist charges £30 plus vat to read the codes which I think is a bit steep for what is involved. Anybody know which one?
the judge Posted December 28, 2014 Posted December 28, 2014 I have a basicish one which should read it. In widnes
twosmoke300 Posted December 28, 2014 Posted December 28, 2014 Try and get opcom . special software just for Opel and vaux.I got a clone tech 2 with genuine UK software and its bloody brilliant. Was 550 quid tho
nacho man Posted December 28, 2014 Posted December 28, 2014 I got a obdii reader (not a Bluetooth thingy, one with a proper lead) of ebay for like 7.99 or summat it read my focus fine, worked on a few other cars as well just messing about, can't complain will try and get a link.
nacho man Posted December 28, 2014 Posted December 28, 2014 http://m.ebay.co.uk/itm/141458705710?nav=SEARCH
gordonbennet Posted December 28, 2014 Posted December 28, 2014 I was recommended to buy an Autel MS509, around £33/35 on Amazon, not regretted, has done everything i've asked of it, quickly diagnosed the cylinder that was slightly misfiring on the Legacy which ironically switched the stability control warning light on, the machine gave codes for weak mixture, indeed it turned out to be a slightly blocked LPG injector on the cylinder the scanner diagnosed.Note, i haven't clue if it connects to Vx so ignore my useless scribble.
dieselnutjob Posted December 28, 2014 Posted December 28, 2014 An 07 should be EOBD compliant so a cheap ELM327 based PC device should work. I happen to make these things for Rovers and MGs in case anyone hadn't noticed... £30 sounds pretty reasonable if the mechanic is using professional equipment which probably cost him £2000 or more. The basic principle with these things is to follow this process. 1. Read the codes and write them all down.2. Erase the codes.3. Drive around for a bit and read them again to see what comes back. The codes in step 3 are the ones that are most likely related to the issue rather than 1. HillmanImp and alf892 2
beko1987 Posted December 28, 2014 Posted December 28, 2014 Never found an obd car my £6 Bluetooth module and free torgue doesn't read! fordperv 1
HH-R Posted December 28, 2014 Posted December 28, 2014 Those little Autel ones are GR9, never used one on a VOXUL though.
fordperv Posted December 28, 2014 Posted December 28, 2014 Never found an obd car my £6 Bluetooth module and free torgue doesn't read!Last year the mrs bought me a very good £20 one and I downloaded torque it's been very useful even though I don't have a car it will work on because they are too old, i use it on other people's to help them out
