dieselnutjob Posted January 11, 2012 Author Posted January 11, 2012 would it make any difference in neutral or park? it does it in neutral and park. Putting it in gear actually stabilises the idle.
dieselnutjob Posted January 12, 2012 Author Posted January 12, 2012 What carb is it? it has two carbsThere is a Solex 34TBIA which is operated by the throttle cable and a Solex 35CEEI which operates by vacuum control. Only the 34TBIA works at small throttle openings and I think is the only one with a choke mechanism. I suppose that the 35CEEI could be opening when it shouldn't but I doubt it.
504GL Posted January 12, 2012 Posted January 12, 2012 What carb is it? it has two carbsThere is a Solex 34TBIA which is operated by the throttle cable and a Solex 35CEEI which operates by vacuum control. Only the 34TBIA works at small throttle openings and I think is the only one with a choke mechanism. I suppose that the 35CEEI could be opening when it shouldn't but I doubt it. I think my 504 had a similar setup. Replacing it all with a single Weber did wonder for the engine, though it did somewhat poo on the fuel economy.
M'coli Posted January 12, 2012 Posted January 12, 2012 Wow! It's amazing the heath-robinson solutions that problems threw up in the days before fuel injection was virtually compulsory. Either that, or this one's a solution looking for a problem...
504GL Posted January 12, 2012 Posted January 12, 2012 Wow! It's amazing the heath-robinson solutions that problems threw up in the days before fuel injection was virtually compulsory. Either that, or this one's a solution looking for a problem... Yup! Looks a lot like the "solution" that my 504 came with My dads 504 just had a single solex and was MUCH better.
dieselnutjob Posted January 12, 2012 Author Posted January 12, 2012 the point is that the big carb doesn't open unless the pedal is pressed hard, and I don't believe that it has a choke on it either. Therefore the problem is most likely with the smaller carb which is just a standard single choke Solex. I've guessing that something is gummed up in the auto choke but I don't really know how they work.
dieselnutjob Posted January 12, 2012 Author Posted January 12, 2012 more documents but I don't understand
Pete-M Posted January 13, 2012 Posted January 13, 2012 I'd be giving the carb body a thorough clean out. There are a lot of bits to get blocked up with gunk in there and you're the first person to drive it in how long? Is there an inline fuel filter plumbed in? Of course, as eny fule kno the correct answer to PRV V6 Carb issues is this one...
dieselnutjob Posted January 13, 2012 Author Posted January 13, 2012 if I'm going to do that then I might as well do this
dieselnutjob Posted January 17, 2012 Author Posted January 17, 2012 been doing some fiddling with my carlast week I got to the end of the road and the dash illumination quithad to go past endless speed cameras n wotnot with my phone screen illuminating the dashso I pulled out the instrumentson a 604 the illumination bulbs are not in the instruments at all, but in a lighting bar above it DSC_1176 by dieselnutjob, on Flickr for some slightly mental Gallic reason the 1/4" spade is not the same piece of metal as the bus bar and as the years go by the bits are not pressed together as well as they were DSC_1178 by dieselnutjob, on Flickr luckily the bus bars just slide out DSC_1179 by dieselnutjob, on Flickr put a kink in them and slide them back in and it all works lovely DSC_1181 by dieselnutjob, on Flickr
dieselnutjob Posted January 17, 2012 Author Posted January 17, 2012 whilst I was in there had a fiddle with the speedo cable as well as the needle was shaking end of cableIMAG0209 by dieselnutjob, on Flickr pop the clip outIMAG0204 by dieselnutjob, on Flickr now the inner just pulls out and I greased it upIMAG0199 by dieselnutjob, on Flickr I'm glad I pulled the instruments because there was a wire floating around that had snapped off a connector and another that snapped as soon as I touched it. These were wires that the Peugeot main dealer added back in 1976 for the extra fog lightsI got the proper fog light symbol to light up when the rear fogs are switched on as well
dieselnutjob Posted April 22, 2012 Author Posted April 22, 2012 This week I went to see a stash of cars containing a 604 to see whether it could be saved or whether it would be a parts donor. I was told that the wheels had been used elsewhere but I have some 604 wheels. Unfortunately I think it's too far gone to be saved The scene as I approachedDSC02483 by dieselnutjob, on Flickr Driving a 70s Peugeot through undergrowth felt just right. As I got nearerDSC02485 by dieselnutjob, on FlickrDSC02484 by dieselnutjob, on Flickr First the 504 coupe which is utterly utterly rottenDSC02491 by dieselnutjob, on FlickrDSC02517 by dieselnutjob, on FlickrDSC02492 by dieselnutjob, on Flickr The 604DSC02489 by dieselnutjob, on FlickrDSC02488 by dieselnutjob, on FlickrDSC02497 by dieselnutjob, on FlickrDSC02500 by dieselnutjob, on FlickrDSC02499 by dieselnutjob, on Flickr which I decided is too far gone The crime sceneDSC02490 by dieselnutjob, on Flickr As I started to steal parts from HOD for Pete and myself which will seal its fate johngarty, Junkman and Uncle Jimmy 3
Albert Ross Posted April 22, 2012 Posted April 22, 2012 Those Koop wheels will be worth the save surely?? Might get international interest with slot mag action.
dieselnutjob Posted April 22, 2012 Author Posted April 22, 2012 yes I have never seen anything like them. Not mine to take though. The owner of the 604 gave me permission to take stuff but the 504 coupe isn't his.
dieselnutjob Posted April 30, 2012 Author Posted April 30, 2012 today I spent £100 on thisDSC02535 by dieselnutjob, on Flickr in order to repair this also I had a look at the sunroof drains because they are an issue on all old Pugs. Until recently the car has always been under a breathable cover but now I stopped the boot leaking I've been a bit braver. On the back of thisDSC02531 by dieselnutjob, on Flickr there is a rubber/plastic pipe that runs down the A pillar and dumps the water inside the front wing, thus causing the front of the sill to rust out When I had a poke inside the headlining I found thisDSC02528 by dieselnutjob, on Flickr yep, that's the other end of the tube rusted totally off.So the sunroof frame is rusted to heck. Now I have to remove the headlining to see if the sunroof frame can be dropped, removed and welded up.
Pete-M Posted May 1, 2012 Posted May 1, 2012 Mine's not that bad, but I reckon someone will end up doing it if the car is still going in 5-10 years.
dieselnutjob Posted May 19, 2012 Author Posted May 19, 2012 This week the sunroof came out and got fixed. I took the car over to Brooklands Welding for the day. This came outDSC02539 by dieselnutjob, on Flickr I was told that you have to remove the front or rear glass to remove this; not true. With the passenger seat removed it came out through the front passenger door quite easily. ThisDSC02538 by dieselnutjob, on Flickr was replaced with thisDSC02543 by dieselnutjob, on Flickr This roof looks like this without the sunroof presentDSC02542r by dieselnutjob, on Flickr DSC02541 by dieselnutjob, on Flickr and actually hadn't rotted through. So it was cleaned up and repainted before refitting the sunroof Lastly some rot in the chassis rail was welded upDSC02544r by dieselnutjob, on Flickr I'm hoping to get the headlining back in tomorrow. Uncle Jimmy 1
dieselnutjob Posted September 1, 2012 Author Posted September 1, 2012 this week I finally managed to find an RCK33 manual choke conversion, which is listed as the right one for the 604. I spent all day fitting it, and then removing and refitting the original automatic choke, and then the car wouldn't start until I chucked petrol down the carb intakes The kit fits on the carb all right, and does what it's supposed to, but the air filter will not fit on top. Before, and after Solex 34 TBIA automatic choke mechanism by dieselnutjob, on Flickr Filter hits manual chokeRCK33 problem by dieselnutjob, on Flickr The only upside is that having taken the auto choke to bits and rebuilt I guess I understand how it works a bit better. Maybe I can make it work properly. Uncle Jimmy 1
dieselnutjob Posted November 3, 2012 Author Posted November 3, 2012 the 604 is being right pain at the moment. 1. The "chassis" rail where the front cross member bolts on has rusted through. No big holes but the metal is getting very thin and has some small holes in. Luckily you can see this only from inside the engine bay and not from below so the MOT man didn't notice it. My welding guy says that the engine will have to come out in order to fix this The plan for this is to just cover it with thick paint until I'm ready to get the engine out in a year or two. 2. The starter motor is occasionally unreliable. 3. It is generally running badly. It starts okay but then very quickly runs on half its cylinders and belches out smoke (I think fuel not engine oil) until it's completely warm. Even once warm it idles okay (though hunting between two speeds) but doesn't accelerate cleanly. So I am considering a slightly radical cure to the running problems. The wierd big carb/small carb appears to be a bit rubbish even when it's working (and they never do) so I think instead of throwing money and effort at the carbs I will go EFI. Apparently a Ford Falcon EA throttle body will bolt onto the inlet manifold in place of the big carb, and the small one can just be blanked off. I'm pretty sure that I can hide under the existing air filter and so look completely standard unless the air filter is removed. The thing can then be controlled with a megasquirt ECU. I'm not looking for any more power (and probably won't get it) but I would really like to make it reliable, nicer to drive and hopefully use less fuel, and I think that EFI is the way to do this, without changing the character of the car. If anyone knows any Aussie car nuts who could help me source the parts that I need ?
dieselnutjob Posted November 23, 2012 Author Posted November 23, 2012 Australian car nut has been found and is getting me this throttle body. Is anyone on here going to USA any time? I need someone to bring me back a megasquirt kit.
dieselnutjob Posted September 15, 2013 Author Posted September 15, 2013 The 604 failed its MOT this week but surprisingly lightly. Exhaust leak where the downpipe joins into the front box.Steering rack gaiter with no clips on one sideSteering rack gaiter split on the other side. Luckily the one that is split is the side that is much easier to repair and that gaiter is easily available. On the other side you have to buy them in France and the power steering ram and the knuckle that it connects to have to be removed. Yesterday I took the pipes off between the front box and middle box and they came off surprisingly easily, but I could not get the front box off. Someone has attempted to fix this before by filling the slots of the joint with weld and I fear that they have welded the downpipe to the box. For now I wrapped in tin and put the clamp over the top and it is 90% better. Also it started blowing at the back as well. I don't think that universal U clamps are going to work on this car. Originally it had something like this Which cover the slots in the joint, so, I have ordered some of these as well. Lastly the car drinks transmission oil so whilst underneath I though I would figure out from where. It's all quite damp under there but the only drip I can see (which is tiny) is from the stud and lock nut that holds in the speedo cable. I am wondering whether the vacuum capsule has split and the oil is going into the engine and being burnt ?
warren t claim Posted September 15, 2013 Posted September 15, 2013 When you strip it down to be welded make sure you have a curious cat handy to poke its head through the rust hole.
dieselnutjob Posted January 24, 2016 Author Posted January 24, 2016 The 604 failed its MOT in the Autumn on only one item: sky high CO emissions. The limit is 4.5. When I first got the car it was about 2.5 I think, but over the years it ran worse and worse and finally failed, scoring 9.0. I took the small idle carb off and gave it to a friend to take apart and rebuild. He found that the base plate was loose, and checked everything and rebuilt it. After refitting it the car is already running much better. It now idles properly for example. However it now has a problem that if you press the accelerator quickly it will backfire. If you press it slowly the power is there. I put the carb on and put it on my mates gas analyser, but it still wasn't right. Initially it seemed okay but as it warmed up the CO seemed to climb and climb again. Eventually I asked him to clamp off the fuel supply to the big rear carb. Once it had drained of fuel the CO figure dropped right down to about 1.0. It looks like the rear carb is going to have to come off for a rebuild as well. Craig the Princess and dugong 2
Asimo Posted January 25, 2016 Posted January 25, 2016 if you press the accelerator quickly it will backfire. If you press it slowly the power is there. Likely indicating that accelerator pump is not doing it's thing.
dieselnutjob Posted November 13, 2016 Author Posted November 13, 2016 I just found an online shop in France that appears to have a right rear door and a left rear door skin in stock. Only 220 Euros delivered. So now I have (or will have) three door skins, a complete door, a wing and a front valance in stock. Basically this is all that's needed to start a resto. I am now just waiting for the email saying "Désolé mais nous n'avons pas ces pièces" or something.... Skizzer and nacho man 2
dieselnutjob Posted November 13, 2016 Author Posted November 13, 2016 More good news. The doors that I have ordered are parts 9007 65 and 9011 20 which according to this are pre 77 partshttps://flic.kr/p/PaSuS4 It's very odd, because I thought that the rear doors didn't change in the 77 facelift. The door skins seem to have the same part number before/after but the whole door changes. I suspect that my frames are going to need repairing but with new skins the job has to be easier. I am right chuffed with this beacuse I thought that these things were totally unobtainium. Skizzer and RobT 2
Felly Magic Posted November 13, 2016 Posted November 13, 2016 I mustard mit, these do look fine motors, esp the minty fresh one I saw in Needham Market a couple of months ago
Magnificent Rustbucket Posted November 13, 2016 Posted November 13, 2016 It is good to see this lovely old car still going strong.
