High oil pressure on Lotus
My dad owns a 1974 Lotus Elite,which he has had for years...
He has recently done a top end rebuild,and it started today and ran well,but has a high oil pressure at 2000RPM on choke it was showing 80psi,it should be 40 psi at 3500,and drops to 5-10psi on idle,he used 15/40 grade oil(good quality)but didn,t leave it running for long through fear of popping an oil seal,what causes this and should he be alarmed???
Should he go down to 10/40 oil?
Pressure relief valve stuck, incorrect head gasket, incorrect oil filter or a blockage somewhere.
Head gasket upside down, blocking the head oil feed?? Try to find out quickly, before it fucks the lot up.
What kind of guage is it? electrical or capillary? has that been ruled out?
Update is all seems well,it dropped to 10psi on idle and rose to 30-40psi on higher revs,thanks for the ideas i put them all to my dad.
