http://www.ebay.co.uk/itm/Ford-focus-ghia-1-6-02-plate-Mot-failure-/252317843031?hash=item3abf50be57:g:GpAAAOSw8-tWZQGh
99p Focus with leather....
 M o t failure - cooling system, smoking abit, wheel baring
Doesnt sound too bad.... Lets have a look at the last MOT
MOT history of this vehicle
  • Test date7 July 2015
  • Test ResultFail
  • Odometer reading98,433 miles
  • MOT test number3392 4838 5113
  • Reason(s) for failure
    Rear fog lamp not working (1.3.2b)
    Nearside Rear Seat belt anchorage prescribed area is excessively corroded (5.2.6)
    Emissions not tested (7.3.A.1)
    Nearside Rear Rear wheel bearing has excessive play (2.6.2)
http://www.ebay.co.uk/itm/Alfa-Romeo-156-JTD-2-4-Estate-/231868748853
I am selling my Alfa to which has issues these being as follows (big list)
1/ No Service history
2/ I have replaced the cambelt and waterpump (local garage)
3/ MOT runs out in just over a month
4/ Heavy Vibration front drivers side ( could be drive shaft or bearing (expect the worst))
5/Rear passengers side window not working (currently taped up. Assume its the motor)
6/ No rear reverse lights (this will be at the gearbox selector guide)
7/ Trouble with gear selector (1st and reverse). Note this is the gear selector and not the box
8/ Headlights are not correctly aligned
9/ Rear door handle does not work
10/ Rear window washer / wiper does not work
11/ Handbrake a bit soft
12/ Air con not the best
13/ Seat belt / air bag light on
14/ Alternator noisy on start up - This is new
15/ Under full accelerator the turbo can be smokey
In summary?
Great car.
15 year old alfa for £350
WPCGW
https://www.gumtree.com/p/alfa-romeo/sale-alfa-t-spark-147/1159012609
MOT history is rather interesting...
Test date: 11 October 2012
Test Result: Fail
Odometer reading: 118,202 miles
Nearside Front Tyre(s) incorrect because different size tyres are fitted on the same axle. (4.1.A.1a)
Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Nearside Front Suspension arm has excessive play in a ball joint (2.4.G.2)
Offside Front Suspension arm has excessive play in a ball joint (2.4.G.2)
Advisory notice item(s)
Vehicle structure has slight corrosion (6.1.A.1)
Then...
Test date: 16 October 2012
Expiry date: 25 October 2013
Test Result: Pass
Odometer reading: 118,216 miles
Which is fine, I guess some welding has been done.
However, there is nothing until:
Test date: 20 June 2015
Expiry date: 19 June 2016
Test Result: Pass
Odometer reading: 118,308 miles
3 Years later, with no mention of any corrosion ... on an Alfa...
£350 though with 3 months MOT left.
Not my cup of tea (I don't even like tea), but pretty sure someone on here maybe interested in this one:
Volvo 940 Wentworth saloon. 15g turbo
https://www.gumtree.com/p/volvo/volvo-940-wentworth-saloon.-15g-turbo-for-sale-1992-/1158952048
Is a 15g turbo good?
Even more info here: http://www.carandclassic.co.uk/car/C715563
Load of photos here: https://www.flickr.com/photos/127950519@N06/sets/72157664528594229/
He sure does seem to love that thing!
Cripes!
Somewhat unbelievably, quite a few of these were made. It is a Guy salmon XJ-S. Someone actually paid loads of money back in the '80s for it to look this silly.
