155V6 Posted September 9, 2017 Posted September 9, 2017 I've managed to collect about 5 spare car batteries,& can't actually remember which ones are any good.I've looked on eBay,& you can get testers for a tenner or less,are these likely to be any good,or is it a case of getting what you pay for?
sierraman Posted September 9, 2017 Posted September 9, 2017 I'd just use a multimeter, charge them up then see what happens.
twosmoke300 Posted September 9, 2017 Posted September 9, 2017 Multimeter is pretty limited . What you need is the old fashioned drop test with the two spikes and a big spark . Lacquer Peel, gordonbennet, alf892 and 2 others 5
DodgeRover Posted September 9, 2017 Posted September 9, 2017 Heavy discharge tester is the proper way of doing it, or put them one a vehicle and use it for a bit with the original in the boot and some jump leads.Multimeter can tell you if a cell is gone anything less than 12v when they've been sat for a day after being fully charged and they are usually scrap, if you can open it up to top up electrolyte then adding some EDTA and slowly charging might revive it, I have a 50% success rate doing this for use in the caravan or a battery bank in the shed.
cobblers Posted September 9, 2017 Posted September 9, 2017 The cheapo battery testers don't tell you much. To test them pretty accurately with what you have lying around, Charge the batteries up full and then wire a 55w headlamp bulb up. Come back after 3 hours, the bulb should still be bright. If not, scrap it as it's got less than 15AH left.A lot of batteries will have their capacity marked on the top, but usually a small battery will be 35AH up to 100+ for a massive one. Adjust your timings accordingly. SiC 1
DodgeRover Posted September 9, 2017 Posted September 9, 2017 As above but add a timer and low voltage cut off batteries don't really like being fully flattened
SiC Posted September 9, 2017 Posted September 9, 2017 As above but add a timer and low voltage cut off batteries don't really like being fully flattened55w bulb at 12v draws 4.5a ish. If it can't draw that for 2-3hrs (9ah to 13.5ah), then the battery is pretty knackered and worthy as scrap anyway...or as a spare to throw in before flogging chod on. Just don't forget to check it in 2hrs or so and leave it running!
Des Posted September 9, 2017 Posted September 9, 2017 There are tiny little LCD battery testers available for about £30, you dial in the capacity and they take about 10 seconds to tell you what % is left using sorcery, I've found one to make sense, but still value the second opinion of a drop tester or wanging over on the starter with the coil lead off and a voltmeter telling tales.
PiperCub Posted September 9, 2017 Posted September 9, 2017 Got a cheap Bergen drop tester, about £20 on Amazon - actually been pretty accurate in my experience. But the bulb test/drain method detailed above it a neat zero-cost alternative. A multimeter is virtually useless as by definition it puts very little load on a circuit when testing voltage, my neighbours u/s battery showed a fairly healthy 12.45V across the terminals but was utterly knackered - loading it up even a bit dropped the voltage to around 7V. Lacquer Peel and alf892 2
155V6 Posted September 9, 2017 Author Posted September 9, 2017 Thanks for the replies,I'll try the bulb method as I can do that tomorrow.I might invest in a drop tester though,pretty cheap as said.
Eddie Honda Posted September 9, 2017 Posted September 9, 2017 http://autoshite.com/topic/26460-shite-battery-chargers-the-bradex-thread/?p=1110053 PiperCub 1
PiperCub Posted September 10, 2017 Posted September 10, 2017 ^^ Now that's a battery tester to be proud of!!!
cros Posted September 10, 2017 Posted September 10, 2017 Just try and start one of these 2 cylinder jobbies, if theres smoke it's a good 'un.
AMC Rebel Posted September 10, 2017 Posted September 10, 2017 ..or as a spare to throw in before flogging chod on. I wondered why I always seemed to need a new batt on recently acquired vehicles
