95 quid Peugeot Posted August 23, 2017 Posted August 23, 2017 Since the demise of my fav 406, i've still been hankering after another.Theres this one on gumtree with suspected pump problems, its a new one on me as everything else similar ive had has had bullet proof mechanics https://www.gumtree.com/p/peugeot/peugeot-406-2.0-hdi-estate-12-month-mot-fuel-pump-issue/1262826642
sierraman Posted August 23, 2017 Posted August 23, 2017 I wouldn't give £4.50 for it. He having a laugh, replacing the pump and injectors will be expensive. It's scrap. It's had it and he knows it. £450 and you are in running Peugeot 406 territory not one that needs hundreds chucking at it.
paulplom Posted August 23, 2017 Posted August 23, 2017 What price would a new engine be with all the ancillaries? Maybe worth buying a donor car as the body work looks mint as you would expect on such a low mileage example.
paulplom Posted August 23, 2017 Posted August 23, 2017 http://www.ebay.co.uk/itm/Citroen-Picasso-2-0-hdi-engine-Complete-with-injectors-and-pump-2-0-HDI-/222595845449?hash=item33d3bf0d49:g:bj8AAOSw5cNYiizZ Answered my own question
sierraman Posted August 23, 2017 Posted August 23, 2017 While the engines out you'd be as well sticking another clutch in it as well. Sounds like a lot of fucking about. I'd find one that's a going concern.
95 quid Peugeot Posted August 23, 2017 Author Posted August 23, 2017 reason i asked was i've never heard of these engines shitting fuel pumps like that.. a renault Clio dizzer maybe, but not a mighty Pug
SiC Posted August 23, 2017 Posted August 23, 2017 Yeah often when a fuel pump goes, its subsequent internal destruction of its internal parts often is spread across the rest of the fuel system and ruining it all. Not worth it tbh. Could just be a failure of the part due to internal manufacturing defect, or even previously put the wrong fuel in, etc.
SiC Posted August 23, 2017 Posted August 23, 2017 reason i asked was i've never heard of these engines shitting fuel pumps like that.. a renault Clio dizzer maybe, but not a mighty Pug Even reliable designs can break occasionally!
twosmoke300 Posted August 23, 2017 Posted August 23, 2017 If its a 90hp then injectors are non coded and cheap as chips secondhand , as are pumps .If it were mine id get secondhand pump , injectors and pipes as well as the filter housing . Put a new filter in it as well as put a cheap inline one in before the main filter . You may need to change this a few times as it filters out any swarf thats made its way back to the tank via the leak offs. Or remove the tank and clean / blow through the pipes etc.I reckon a £100 quid and you could get it back on the road if you were canny . paulplom 1
twosmoke300 Posted August 23, 2017 Posted August 23, 2017 Even reliable designs can break occasionally!Bosch junk I expect - reached its designed life span no doubt. SiC 1
95 quid Peugeot Posted August 23, 2017 Author Posted August 23, 2017 Cheers twosmoke. That was my first thoughts. What I really need is a service manual on CD. Oh. You've got my old ones. Lol
95 quid Peugeot Posted August 24, 2017 Author Posted August 24, 2017 no its fine, im still going for a 406, not this one,
JJ0063 Posted August 24, 2017 Posted August 24, 2017 I wonder if by chance this beauty is still available... Cazana doesn't show a new owner registered yet... https://www.gumtree.com/p/peugeot/peugeot-406-hdi-diesel-/1259673253
They_all_do_that_sir Posted August 24, 2017 Posted August 24, 2017 As has been said its worth less than half what hes asking. If its mega mint I'd leave my number with an offer of £250 and walk away. If he bites do as twosmoke says... Sent from my SM-A510F using Tapatalk
