ShiTe170- Moogs Mootahs
I really like the little Pug....All that graft to get the handbrake light to work properly would test the patience of a saint though, and that's ignoring the other jobs.
Hat purposefully doffed to you for getting stuck in!
Thing is that it is pretty easy to work on - there is nothing to them, which is part of the charm
Only annoying things are 1) old plastic it is pretty brittle 2) a mix of torx and cross head screws
Bloody hell, you really don't want to do that assignment do you.
No comment...
This morning I thought that I would see if I could fix the dash lights
The back of the binnacle
This is the feed for dash lighting
Cleaned carefully
Reinstalled
Didn't make a jot of difference. Voltage is just millivolts so not enough to get lights working. Continuity is good.
At this point I noticed smoke wafting from the back - the handbrake light bulb had gone as well plus stop light. I think this might have been the original issue.
Pulling some of the bulb holders shows this
So looks like a new binnacle is probably the best best to fix it all.
It’s only a really basic circuit....if we aren’t bothered about originality, just fit the bulb holders without the circuit and solder hard wiring to the relevant connectors?
That might be a plan.
There is some melty bits on the track but testing continuity shows it is all connected
Testing continuity on the back highlighted that some of the bulbs weren't making proper contact due to manky tracks and quite a few of the bulbs have blown.
Cleaned up the tracks and that improved things. Ordered a load of new bulbs so will swap them out before ordering another binnacle.
Minor victory this morning. The golf buzzes at about 50 mph which goes away when you push the dash.  It is one of those noises that once heard, doesnt go away.
This morning I stripped the front fascia out (about 15 min job) and tightened all the screws I could find. Trip to work this morning showed the buzz has gone ... very pleased and a small victory.
Sadly I am suffering from Shiters Itch - the car is great, does everything I need it to, fsh and been well looked after  ... but i keep getting tempted to change it. Ignoring the fact I have a 205 in bits, a Rover being fixed elsewhere, Mx5 that wants some love.
You need a Mazda 323 that doesn't run right to add to that list. ?
The green bastard has been tamed by Northern Monkey!
He pushed on to get it finished when I would have pushed it in the canal.
Anyone want to buy a starter classic car? Low mileage, new MOT ..
Will do an advert for car and classic tonight and get it up to sell.
Don’t forget the new timing belt....no roulette here ?
Second time in less than a week....
Not my fault if my customers bring me cars for extensive work with no bloody fuel in them.....
I remember when I picked up that MGF off you last year and the Rover was sitting on the drive with it’s ruined cam. It’s come a long way. Great job rescuing it from the abyss!
I bought a set of track tyres off GM for the little Mazda but the alloys were a bit crispy. The tyres kept going down and I couldn't use them for Autotesting as not on the approved list.
I have got a spanking new set of rainsports to go on, so took the opportunity to do a quick refresh
Before
a21c9c0062d32961a6a4b680f3c5c10a.jpg0740674404dc6dd9879974b7da190481.jpg3f49f6d696cfcfbc984b8b132cb8e79b.jpg2c75fdcf8b7ff1aba1fd85f57489018b.jpg610966a0383b47f6019aff646c5c71fd.jpg
Sanded with hand sander, wire brush in drill, wire wool and wet and dry paper.
Getting the loose stuff off resulted in this
9c29c19f80e5be111c59b7f06009a3f5.jpgd5156fe8b0107d950e1c922e508eb818.jpg18a6a3ec2f8968b6d21fccc9cfac95f5.jpg8fb9503b70f84c3d43acc874e6243e98.jpg8572de3311123cf63a52586a1610a361.jpg05fa341a9257a44217fde64e40d686e9.jpg
2ps to cover the bolt holes
Then couple of coats of primer
7cc2cabc383354a4915ffe2aed47419e.jpg1c10043b024fc2848d6af7391b16d35e.jpg1058066d125a18fabe54fc22521512dd.jpg53e50fe15c7fac912843888f98bddad2.jpg
You can see before at the top, during on the right and primered at the bottom
When it dried it has pulled a bit more of the paint off so I will scrape that off tomorrow
8ccb44493eb38563602a23fe1da8856a.jpg4ede1dd82cfc20b6fb8ff7cb00bdc52d.jpgbae2b6d8a40520a079def03719b2abe7.jpg
They are going to be black as I have been informed it will look best.
Outside currently looks like the early 90s
Norman cook agrees :D
Whoever convinced you black wheels were the way to go has no sense of style or panache. All the cool kids are rolling on primer white rims.
He even offered to buy the black paint as I have got silver in stock...
White will show the brake dust up a bit too quickly!
Those wheels are Enkie's, quite sought after on the basis of being expensive at the time as they're well made, tough and also light. Well worth the effort to refurb them!
They could do with proper sandblasting and then a powder coat. This though should cost me £40 and a few hours which leaves money for shiny things
Nah mate, white ages gracefully.
Spotless.....
We left the wheels primed last night andeft to go off.
Today was time to do the colour
I bought a waterproof table cloth to try and protect the bench a bit more. It was a partial success
Primed wheels
Starting to dust some coats
Doing the underneath
Also did the centre caps with a little of colour funk
Come out alright. Definitely 10 yarders it not bad.
I also picked up a pair of lower front arms to sort out and poly bush to fit.
These are miles less rusty than last lotso not going to do too much.
Took off the balljoint and other bolts
fd616e7851da77ede524214b0973d874.jpg9533909f85807c2a52dabc8baed12cb6.jpg35b64d60a6def4407f95b7c96b34e383.jpg
Quick go over with wire wheel and brake cleaner
Then the glass reinforced chassis paint to protect them
Couple of coats
Looking good - need polybushing and then is ready to swap over.
Also did the ramps I was given by my neighbour. They had rust spots so wire brush back and then coated in paint to give them another 50 years of life.b
