oldcars Posted August 13, 2016 Posted August 13, 2016 Subframe on my Kia is looking a little* scabby. I have cleaned it up and waxoiled it up but it will need replaced soon.
nisfan Posted August 13, 2016 Posted August 13, 2016 Mazdas are THE worst for rust , on par with datsuns captain_70s 1
DodgyBastard Posted August 13, 2016 Author Posted August 13, 2016 I knew these wheels would eventually be fitted to something, I also painted the primered areas back to the original colour... Sent from my 5022X using Tapatalk phil_lihp, oldcars, Ghosty and 8 others 11
DodgyBastard Posted August 13, 2016 Author Posted August 13, 2016 DSC_0903 by srblythe, on Flickr DSC_0897 by srblythe, on Flickr DSC_0906 by srblythe, on Flickr Looks like a winner wagon to me... Lacquer Peel, f1fan111, KruJoe and 5 others 8
Ben_O Posted August 13, 2016 Posted August 13, 2016 One of my old neighbours had a Samara, it replaced his Talbot Solara I always admired it because it was the only one i had seen at that point in my life. Mind you, the same could be said for the Solara really DodgyBastard 1
DodgyBastard Posted August 13, 2016 Author Posted August 13, 2016 DSC_0875 by srblythe, on Flickr DSC_0878 by srblythe, on Flickr Finished making my Proton fuel filler neck, lets hope it fits! Sheefag and KruJoe 2
DodgyBastard Posted August 13, 2016 Author Posted August 13, 2016 Before! Lada Samara by srblythe, on Flickr After Lada Samara GL by srblythe, on Flickr Before Lada Samara by srblythe, on Flickr After Lada Samara GL by srblythe, on Flickr I think it's looking better! phil_lihp, Ghosty, KruJoe and 12 others 15
DodgyBastard Posted August 13, 2016 Author Posted August 13, 2016 Just need to remove the residue left from the bump strips and pull the dent out and it'll be looking like new haha! Dick Cheeseburger, phil_lihp, trigger and 2 others 5
captain_70s Posted August 13, 2016 Posted August 13, 2016 Just need to remove the residue left from the bump strips and pull the dent out and it'll be looking like new haha!Probably better. Amazing what some rattle cans and some tidy wheels can do. oldcars and DodgyBastard 2
oldcars Posted August 15, 2016 Posted August 15, 2016 Just need to remove the residue left from the bump strips and pull the dent out and it'll be looking like new haha!Carmel wheel should get rid of the glue without damaging the paint.
DodgyBastard Posted August 19, 2016 Author Posted August 19, 2016 1988 Peugeot 309 GLD by srblythe, on Flickr 1988 Peugeot 309 GLD by srblythe, on Flickr 1988 Peugeot 309 GLD by srblythe, on Flickr 1988 Peugeot 309 GLD by srblythe, on Flickr 1988 Peugeot 309 GLD by srblythe, on Flickr I'm kinda glad that this was so difficult to sell, I started it up after months of sitting and it fired into life straight away, I took it for a quick spin up the road and it drives surprisingly well and seemed reasonably quick for a na xud. I think I will tidy up the rust and keep it. I had the wheels left over from the first Wilsonx2 309 I bought so thought I would fit them to see how it looked. Cleon-Fonte, anonymous user, Skizzer and 1 other 4
DodgyBastard Posted August 19, 2016 Author Posted August 19, 2016 DSC_0633 by srblythe, on Flickr Previously I had said that the rallye steels I had balanced and fitted to the c15 didn't wobble but I hadn't gotten it above 60 at the time of writing, The steering wheel wobble was actually pretty unbearable above 60 mph so I removed the tyres from the wheels fitted to the front of the van and fitted them to the Saxo spare wheels I had just painted. I didn't bother balancing them and the difference is amazing, I can cruise at 70 without the risk of hand arm vibration syndrome... Jim Bell, Skizzer and oldcars 3
DodgyBastard Posted August 20, 2016 Author Posted August 20, 2016 Took the 305 for a nice long drive from Dunoon to Pitlochry and back down to fife, must have clocked a couple of hundred miles and the odometer rolled around to 108k. DSC_0140 by srblythe, on Flickr DSC_0106 by srblythe, on Flickr DSC_0151 by srblythe, on Flickr AndyW201, worldofceri, anonymous user and 5 others 8
DodgyBastard Posted August 21, 2016 Author Posted August 21, 2016 Had a go at tidying up the rust on the 309 DSC_0196 by srblythe, on Flickr DSC_0197 by srblythe, on Flickr Used the flappy disc to grind off the rust, primed the filled any holes then used a random can of white I found in the boot of another car... DSC_0198 by srblythe, on Flickr DSC_0200 by srblythe, on Flickr Ignore the over-spray on the bumper I will remove that later. DSC_0204 by srblythe, on Flickr I fitted the reflective "Heckblende" or whatever it's called, just need to sort out a sticky brake caliper and change the drive shafts and it'll be on the road in no time. worldofceri, oldcars, KruJoe and 1 other 4
DodgyBastard Posted August 21, 2016 Author Posted August 21, 2016 While I had the car running I noticed it was leaking, the engine was covered in oil and the rocker cover appeared to be leaking. DSC_0207 by srblythe, on Flickr Old Gasket DSC_0208 by srblythe, on Flickr Mrs FOAD fitted the new gasket DSC_0209 by srblythe, on Flickr The old gasket had a few splits and the metal surfaces were caked in oil and grime, with the new gasket on it no longer leaks oil but the arm on the pump is leaking diesel and will likely need changed. I already did the one on the 305 so there's a link somewhere in this thread for the correct o ring.
DodgyBastard Posted August 21, 2016 Author Posted August 21, 2016 Managed to get my filler neck welded together and painted then fitted. DSC_0211 by srblythe, on Flickr DSC_0213 by srblythe, on Flickr DSC_0215 by srblythe, on Flickr Junkman, oldcars, ShiteRider and 1 other 4
DodgyBastard Posted August 21, 2016 Author Posted August 21, 2016 We finally had a go at painting with a compressor and spray gun DSC_0219 by srblythe, on Flickr If the paint is thin enough it works quite well, the grey wasn't all that great but I have a big tin of red oxide I painted the r18 with, I remembered it was very thin so chucked some of that in. DSC_0217 by srblythe, on Flickr It lasted quite well. I'm thinking I should paint a car with the spray gun, the paint on the ranger is quite bad so that's a possibility to practice on.
DodgyBastard Posted August 23, 2016 Author Posted August 23, 2016 The ranger is going forestry commission green, I picked up a tin of metal paint from aldi for £5 so if I get it finished it'll be my cheapest paint job yet... Sent from my 5022X using Tapatalk Supernaut, Lacquer Peel, KruJoe and 1 other 4
DodgyBastard Posted August 23, 2016 Author Posted August 23, 2016 DSC_0240 by srblythe, on Flickr DSC_0241 by srblythe, on Flickr DSC_0242 by srblythe, on Flickr DSC_0245 by srblythe, on Flickr I used the 309's service history and old mots to mask it off.. DSC_0246 by srblythe, on Flickr DSC_0248 by srblythe, on Flickr Aldi paint and spray gun... DSC_0249 by srblythe, on Flickr Should have the rest painted tomorrow after work. oldcars, The Moog, dave21478 and 2 others 5
trigger Posted August 23, 2016 Posted August 23, 2016 Why would you use the service history to mask it?
Felly Magic Posted August 23, 2016 Posted August 23, 2016 Spotted the Samara on carandclassic earlier GLWTS
DodgyBastard Posted August 24, 2016 Author Posted August 24, 2016 Why would you use the service history to mask it?Because it belonged to a car that I no longer owned. Sent from my 5022X using Tapatalk
DodgyBastard Posted August 25, 2016 Author Posted August 25, 2016 Not fucking bad at all... Sent from my 5022X using Tapatalk oldcars, jonathan_dyane, The Moog and 4 others 7
DodgyBastard Posted August 25, 2016 Author Posted August 25, 2016 DSC_0257 by srblythe, on Flickr Slightly better photo. The paint is ok but could be better, I'm happy with it anyway.
Kiltox Posted August 25, 2016 Posted August 25, 2016 Sort that front plate out with some sticky pads instead of screws and it would look pretty damn clean!
DodgyBastard Posted August 28, 2016 Author Posted August 28, 2016 Take a wire wheel to a lada wheel DSC_0276 by srblythe, on Flickr add some Aldi paint DSC_0278 by srblythe, on Flickr And here's the result! DSC_0282 by srblythe, on Flickr And back to looking crap! DSC_0373 by srblythe, on Flickr oldcars, strangeangel, Lacquer Peel and 1 other 4
