DodgyBastard Posted May 8, 2016 Author Posted May 8, 2016 The 440 is still here at the moment. It is very likely to be scrapped if nobody steps in and saves it. I think £60 would buy it. Sent from my 5022X using Tapatalk
bub2006 Posted May 8, 2016 Posted May 8, 2016 What's actually up with it though? I had no issues in over 4k. Bit disappointed its broke. Sorry.
DodgyBastard Posted May 8, 2016 Author Posted May 8, 2016 I'm disappointed it stopped working, It was running fine and I had a great day touring the hills and lochs of Perthshire in it. The next day I took it out it cut out and wouldn't restart. The started motor jammed, started smoking and now doesn't work. It's a fueling issue, fuel pump maybe. I have a spare pump and I could probably get a starter motor from Derskine from a 440 that he broke for spares but I don't have the time to spend trying to fix it. I feel pretty shitty at the thought of it being scrapped but I'm over my limit of cars I can store.
bub2006 Posted May 8, 2016 Posted May 8, 2016 I feel bad its bust on you. I honestly didn't know there was anything wrong. Then again electric components fail at no notice
DodgyBastard Posted May 8, 2016 Author Posted May 8, 2016 As bad as I feel about the 440 the 306 is growing on me... DSC_0479 by srblythe, on Flickr DSC_0476 by srblythe, on Flickr DSC_0463 by srblythe, on Flickr Underside looks fine too...
captain_70s Posted May 8, 2016 Posted May 8, 2016 I like 306 estate, the "little estate" is a concept I agree with.
DodgyBastard Posted May 27, 2016 Author Posted May 27, 2016 What's been happening lately? Panhard65 kindly sent me some rockers to try on the 18, upon opening the package they looked different to the ones on the car, I think they were slightly more beefed up as they had come from a Turbo diesel. I fitted it anyway and got a new belt from Derskine. Renault 18 gtd timing belt by srblythe, on Flickr DSC_0432 by srblythe, on Flickr I had some slight issues with timing it correctly, I put the belt on with guesswork, I found the cam and pump marks easily enough but couldn't figure out which marks on the crank pulley were the correct ones to line up the new belt with. I found out there's a way to determine tdc on the crank by removing a bolt on the casing and poking something in it until it stops turning. I tried this method along with lining up the other timing mark but when trying to turn over by hand it stopped turning. For some reason I figured it was 180 degrees out but after unbolting the rockers and turning the cam it still wouldn't turn over by hand.I decided to remove the bottom pulley and noticed the timing marks were there so I lined all of the lines marked on the belt up and tried turning it over by hand. It turned freely but after one revolution of the belt none of the marks lined up so I turned it over a few more times and the marks were at a different point each time. I thought "fuck it" and connected a battery to see what would happen when trying to start it. The result was good, it was my first timing belt change so I was a bit apprehensive about doing it but I got there in the end... egg, Angrydicky, jonathan_dyane and 2 others 5
DodgyBastard Posted May 27, 2016 Author Posted May 27, 2016 I think a fleet reduction is in order so first up is my 309 DSC_0415 by srblythe, on Flickr next will be the 306 DSC_0479 by srblythe, on Flickr And after that will be my 240 DSC_0489 by srblythe, on Flickr Coprolalia 1
DodgyBastard Posted May 27, 2016 Author Posted May 27, 2016 I *finished welding one side of the Tata DSC_0208 by srblythe, on Flickr It looks fucking horrendous. I'm planning on making the tide mark straight but I used underseal to try and cover the roughness of the welds, I'll hammerite the rest. Cairn O'mount Classics by srblythe, on Flickr I got the rear arches on the 305 looking slightly less shit DSC_0276 by srblythe, on Flickr DSC_0441 by srblythe, on Flickr Angrydicky, oldcars, Bucketeer and 1 other 4
Mr_Bo11ox Posted May 28, 2016 Posted May 28, 2016 Does that 18 need a new gearbox? I vaguely remember offering one from an espace TD to someone on here then forgetting all about it.
DodgyBastard Posted May 28, 2016 Author Posted May 28, 2016 Does that 18 need a new gearbox? I vaguely remember offering one from an espace TD to someone on here then forgetting all about it. There's a slight crunch going down into second and the clutch is past it's best but other than that it's not too bad. A spare gearbox would be handy but it's not really essential at the moment.
DodgyBastard Posted May 28, 2016 Author Posted May 28, 2016 Today I spent a bit more time on the 18, I got a new v-belt from my local motor factors, it didn't fit so I took it back and got a longer one which was a better fit. To fit the belt the alternator needed unbolted but when unbolted there's not a whole lot of movement available so getting a belt to fit was always going to be a fluke.After fitting the belt, I fitted the radiator and bled the cooling system. The rear drums were seized so I removed the rear wheel to hit the drum with a hammer and it freed off, I took the wheel inside to put air in the tyre but the valve was letting air back out. I broke the bead only to find an inner tube inside so grabbed some Renault Espace wheels and fitted some tyres I had lying around... DSC_0457 by srblythe, on Flickr DSC_0459 by srblythe, on Flickr DSC_0461 by srblythe, on Flickr The sill on the drivers side rear was starting to look a bit frilly so I cut it out and welded a patch in and undersealed it. DSC_0470 by srblythe, on Flickr It was actually some of the best looking welding I've managed on car bodywork but I didn't take any photos unfortunately. oldcars, worldofceri, CGSB and 11 others 14
Dick Cheeseburger Posted May 28, 2016 Posted May 28, 2016 Damn, those E-Space alloys look just right. Looking forward to seeing this one continue to get some loving.
DodgyBastard Posted May 28, 2016 Author Posted May 28, 2016 Here's a crap video of it driving Richard, Essex V6, Dick Cheeseburger and 6 others 9
Dick Cheeseburger Posted May 28, 2016 Posted May 28, 2016 ^ Quality wordage at the end of the 'production'
worldofceri Posted May 29, 2016 Posted May 29, 2016 Those wheels look flippin' class on it. Would look amazing in the original colour. [/hint] DodgyBastard 1
DodgyBastard Posted May 29, 2016 Author Posted May 29, 2016 The wheels do look better now than they did 2 years ago with the balloon tyres on them... DSC_0337 by srblythe, on Flickr
Felly Magic Posted May 30, 2016 Posted May 30, 2016 I think the vid needed an 'It lives muahahahahahahaha!!!!' when it started up.
Jim Bell Posted May 31, 2016 Posted May 31, 2016 +1 on the sick rimz. I've always liked them. Look gr9 on that heap too.
Dick Cheeseburger Posted May 31, 2016 Posted May 31, 2016 What became of the gold Horizon you were taking about a while back? Was looking forward to a collection/ getting her going update on that one.
DodgyBastard Posted May 31, 2016 Author Posted May 31, 2016 What became of the gold Horizon you were taking about a while back? Was looking forward to a collection/ getting her going update on that one.I've still to collect it, if someone wants to buy my 309 I will go get it. Sent from my 5022X using Tapatalk Dick Cheeseburger 1
derskine Posted May 31, 2016 Posted May 31, 2016 I'm glad to see Rennie getting some love again, I'll miss it, but I'm still happy with the swap.
DodgyBastard Posted May 31, 2016 Author Posted May 31, 2016 I'm glad to see Rennie getting some love again, I'll miss it, but I'm still happy with the swap.Mind you've to fit the driveshafts on the 309 as part of the deal. Sent from my 5022X using Tapatalk
DodgyBastard Posted June 2, 2016 Author Posted June 2, 2016 The colour on the v5 is red and now so is the car... Renault 18 GTD by srblythe, on Flickr Renault 18 GTD by srblythe, on Flickr worldofceri, CortinaDave, Jim Bergerac and 10 others 13
DodgyBastard Posted June 2, 2016 Author Posted June 2, 2016 The radiator fan on the 18 didn't work so I went to the scrapyard to see if I could find another one, there were very few cars that had the fan on the correct side. I found one that looked like it might fit in a Saxo, ripped it out and paid £12 for it. I removed the old fan and wired in the Saxo one. Derskine had previously wired in a switch so all of the wiring was there which made the job fairly quick.The fan wasn't a perfect fit, I had to break some of the plastic from the original mounts but when I fitted the grille it looked almost oem. derskine and oldcars 2
DodgyBastard Posted June 3, 2016 Author Posted June 3, 2016 Managed to get some pics of the fan. Renault 18 GTD by srblythe, on Flickr Just about finished painting it. Renault 18 GTD by srblythe, on Flickr Renault 18 GTD by srblythe, on Flickr Renault 18 GTD by srblythe, on Flickr I also managed to wire up a stereo and some pimpin' Kenwoods on the parcel shelf from the 440 I got from Bub. It makes driving the car a bit more pleasant and the speakers go loud enough to drown the noise of the engine.I know most of you would have preferred I resprayed the car in the original colour but I just can't justify wasting that kinda money on a car that will never be worth more than a couple of hundred quid. Jim Bergerac, CortinaDave, jonathan_dyane and 7 others 10
