AVAS.. Poor Yorick! â™ĨïļðŸŽą
Well..... First port of call = PAS Dipstick.
Fluid is just wetting bottom tip of (presumably = low) skinny stick, poking down from screw in bottle top ðŸĪ”
I'll refill to top of the 'skinny stick' dipstick + tonight, when I park, I will slot an unfolded newspaper under the front (nipped by tyre) and tomorrow we will see colour of drips [green in PAS] 👍😐
The car came with 'throwaway' 3month Warranty ðŸĪ. I may just read it up....
🚙ðŸ’Ļ
Ffinn Ell . . . 🔧⚙ïļðŸ•‘
'Designed for Living'!!
Origami+ (... no clues to find ALL the screws ðŸĪŽ)
Used a sheet of folded stiff paper to 'funnel' PAS juice... Now up to FULL 👍
🚙ðŸ’Ļ
Imagine yourself standing near a shop, the shop is being refitted.... Inside, a guy is slicing 3/8ply with his circular saw <zeezeeingnnninngggg>.....
Imagine me, sitting in my car, having that soundtrack played out through the bulkhead [except when turning on a roundabout/over half lock] IT'S DRIVING ME NUTTZ ðŸĪŠ
I know the pumps have a rep [all Vx forri say as much] but mine was totally silent until 3 days ago 😕
Is it eating itself ðŸ˜ĩ‍ðŸ’Ŧ
🚙ðŸ’Ļ
Someone... oot there, in the Webbie Netherworld... has stated that the PAS Motor DOESN'T run in 'dead ahead' and any noises will be heard when it is UNDER LOAD ðŸ˜Ŋ...
Bit of lateral thinking here >> as the Alt puts a whacking current INTO the PAS Motor [when PAS is loaded] could the corrollary be the Alt is making the noise/bearings... And 'shuts up' when heaving juice into the PAS ðŸĪ”
Do we reckon, with the hood up, I'm going to get a  crack at locating this 'whine'... ✔ïļ
🚙ðŸ’Ļ
After some further thoughts..... It can't be the Alt.
The noise 'runs on' & dies for a second AFTER the engine has stopped, so must be standalone source 😕
I will listen with the hood open.....
🚙ðŸ’Ļ
I stood infront of the car, hood up >> it's the PUMP 😕
Fitted my 'reversing sensors' 🔧✔ïļ
Perhaps the line of location is mildly sub-optimal.... but CrashBar is right where it should be 🙄.
Drilled and numbered the fly leads..
Fed them singly through the little gap, under the light pod.
I have taken a 'fly lead' of +12V off the rev lighting plug and just need to pick up a -Ve Ground.
I will not be using the led display (it has the bleeper in it) so everything will be bundled up behind the clip-in grille over the lights.
I needed to make a small notch, in the lamp casing, where it crushes the foam gasket... allowing the sensor cabling to come through into the boot 👍
Not wired up at this time.... Lunch Gong!!
🚙ðŸ’Ļ
Ahh...... Lunch, mmmmm 😉
Picked up Ground from chassis nut, just below lamp unit â™Ĩïļ
Gentle fold over to consume all lengths, cable tie + snip off. Feed into void 👍
Bleeping Marvelous, M9 💰
🚙ðŸ’Ļ
After somewhat shambolic 'jiggery pokery', with a BMW estate rear spoiler >> just not making it!
We have received today my 'revised contender' = flat across width ✔ïļ thin in section ✔ïļ and good proportion/profile ✔ïļ ðŸ˜Ž
A Porsche part for ÂĢ22 delivered 🙄
🚙ðŸ’Ļ
Whilst lying under AVAS arse, squinting up, wrapping together the reversing sensor cabling - bright sun ðŸ˜ē...
... I was in awe of the humongous back box + it's NEWness ðŸĪĢ. The front Flexi was done by the seller 👍
General chassis condition is NON rusty & all the fuel hoses and brake lines are looking factory fresh.... Lanoguard lash worthy!!
Bought on 60,700.. Now 63,550 >> good test drive for 1st month 🚀
🚙ðŸ’Ļ
The lip spoiler is a glass fibre sandwich, with the locator diaphragm glued in...
Removing the inner, with a chisel and then using a very sharp wood chisel to skin/peel the adhesive = bastard ITCHY HANDS 😕
It will all prove worth it, in the end ðŸĪĢ
🚙ðŸ’Ļ
Well.... That was fun [not..ðŸĪŽ]
Just crested the main road, at Westerhope, on our way to The Poachers for lunch....
NO PAS.... Like a flipping elephant is sitting on the bonnet!!
I'll have to wrestle AVAS back home and get my Oily Spanner on the hunt for a scrappy ZF pump (needs Tech2, apparently for the CanBus)....
That's us on the bus for a few days 😐
AVAS = 💰💰
🚙ðŸ’Ļ
  • Sad 3
My local guy, Kevin, has done a few...
If I get the pump, he will whack it in 👍
Canny ✔ïļ
🚙ðŸ’Ļ
Been out to the car.... taking photos of the Pompe 🙄
..... guy at the breakers needs to know EXACTLY what I have.... Like there are two versions of my Astra ZF Pompe.
I only see ONE in my Webbie searches..
As long as we're all happy, eh 👍
🚙ðŸ’Ļ
Pompe @ÂĢ50 cash ..... Collect 1pm.
🚙ðŸ’Ļ
Looking at this 'monkey snipped cabling, in yard' photo.... ðŸ˜Ŋ
Seems this motor is pulling them amps ðŸ˜ē
🚙ðŸ’Ļ
Though the PAS is dead, I'm still helming AVAS (developing those he-man muscles whilst I'm at it....).
Gots to say the Rear Parking Bleepers are a revelation!! Very difficult to chop the estate back end in with confidence of NOT tip-touching >> small rear window ðŸ˜ķ‍ðŸŒŦïļ
My Bleepers are punching me straight in @10" min = solid beeeeee 😉
Maggikkk 👍
🚙ðŸ’Ļ
Pompe Achieved â™ĨïļðŸŽˆ
.... And we have Top Up, as required ✔ïļ
🚙ðŸ’Ļ
Dropped the pump into the garage + top-up fluid.
He is quite busy, one man and a gofer operation, so is looking to have AVAS up on his lift Thursday. I will take it around on Wed pm, he will put it on the lift before he goes home and it will be clay cold in the morning, 07:30 start.
Reckons on dropping the subframe....
🚙ðŸ’Ļ
2 hours ago, ProgRocker said:
Has the Astra replaced the Getz?
Yeah.... #laughter mocking Bart#
Wanted an auto/slush.... Began eliminating cars as they got newer but without slushhie.
The Aisin 4sp is fitted to GM Saturn >> the Septics can't break it *BIG selling point for me 😉.
I've wanted an estate for a lifetime... Just never hit the GO button.
I don't much like the 'astra slug' shape BUT when I spotted an H estate [with rear dark glass] giving off 'classic square back' vibes.. unlike sloping Wagons.. I hit the BUY button!
The fact it's broken doesn't bother me, I'll hammer the fuck out of it... then something else will pop ðŸĪĢ
It's a quiet, roomy WooshVagen🚀 â™Ĩïļ
🚙ðŸ’Ļ
  • Like 8
Anyway.... More IMPORTANTLY!!
Tyres ðŸ˜Ŋ
On the front a fresh pair of Sailwin Antares 68 tyre 👍
Had a wee moment, just Sunday, as I sailed straight on negotiating a mini rbt... and I've been having bother 'getting off the line' as they light up under acceleration... Wet roads, of course.
None of the allys are kerbed 👍
I think the Smart Money is on Kumhos 😐
🚙ðŸ’Ļ
As a 'side consequence' of AVAS being crocked ..  SWMBO likes to be out/have lunch in a pub = 💰
Staying near home/lunching in the house is making a 💰saving!!
That 'positive cashflow' is contributing to my ultimate repair bill ⚙ïļðŸ”§ðŸ‘
🚙ðŸ’Ļ
Kumhos are decent IMHO, I've had some for 35k miles on an Almera , yonks ago, they wore well and gripped fine, and I now have PS71s on my 200bhp RWD lexus and they grip fine, especially so in the wet. They'd be a fine choice on the Astra.
Just stuck my head around the door, at the lockup... Shuffling strategies currently applied should see AVAS positioned on his 2 poster @Teatime Thursday.
Job ON ... Friday✔ïļðŸ˜‰
He has had a bit of worrying news.. Landlord of building is selling up and new owner doesn't want a sitting tennant. He reckons he'll just go back on the tools.
Exchange & Mart: Newish 2poster for sale 😕
🚙ðŸ’Ļ
I'm really missing my driving AVAS 😕
..... Weekend Beckons 🚀💞
🚙ðŸ’Ļ
Yo, Ho and UP she rises...!👍
Car is in and the mechanic went under, looked up... and started $wearing ðŸ˜ĩ
*Good call >> not trying DIY with TJ + Axlestands ðŸ˜ķ‍ðŸŒŦïļ
🚙ðŸ’Ļ
YaY.. 🎈🎈🎈🎈
Car all done.... NO Xmas tree lights!!
ÂĢ80 2hrs (+ÂĢ50 pump) = ÂĢ130 â™ĨïļðŸ‘
🚙ðŸ’Ļ
Swift blast around the edge of nowhere...
88miles and extremely 'twirly whirly' in those tight turns 👍👍
To quote Donkey... "Back on the road again!"
🚙ðŸ’Ļ
37 minutes ago, tooSavvy said:
edge of nowhere
O hai
