Bootiful Day 🌅
..... nothing strenuous 🚀
Up through Creswell [Creswell Ices 🍦, double sugar cone 😋], on to Alnwick, then Bamburgh Castle.... Lots of mist, quite gothic tbh!
Steam back down the A1....
Joys 👍
Today, I have been mostly...... Doing spacers 😮
Problem with the Astra fwbrg is that it rotates front and back, the bolt in carrier must be 'suspended [on pillars]/spacers+long bolts' if you want to spin the bearing 😐
It took a while, and lots of jiggering about, to get the hub secured in place on the B&D drill stand... the T-Slots were a help, pre cast into the base 👍
Once I had the bearing cranked up tight, I dropped the disc on [back to front, in this situation] and swung the power drill around, locked the Carbide Cutter in the chuck >> I need the drill mount to swing at the fixed cutting height BUT need to lock it to ensure a precise cutting pass around the disc 'inner dia' (of the bell... It's 1mm a side too small to go over the hub 🤬)
I have a piece of steel clamped on the vertical pole and it serves to hold the drill/cutter dead on height for a pass.... Rock On 🚀
By the time I got all this set up.... Lunch Time 🍽️👀
..... I've put it all away now and can pick a *sunny day to finish off 🛠️
Helpfully 😉... When I've completed the cutting pass = flip disc over and PROVE it now fits ✔️
Carlisle, slow jaunt....
Bootiful Day.... Tizz true 🏝️
..... Absolutely Stonkinn 🏝️
Lunch sorted, now away to Penrith 🛣️
So warm, So bloo....
79k oil + filter coming up....
Mannol £18.95, filter £6.95.
Looking sunny in the coming weeks 👍
Up ramps + @loserone AdBlu tub 😉
*first crank of my *modified Oil Filter Socket 🔧
Completed my 'buzz/skim' of the new discs.
They both fit nice & neat on the Vx hub! 😉👍
..... now to sort out Kev, for the bearing + discs/pads ✔️
Following my *successful 'buzz/skim' of my new discs.... My faithful [and VERY old] 400w drilling machine conked... with an impressive 'exodus of Lucas smoke!' 🫤
My trusty charge card, never to sleep in my hand, was brought to bear on this item...
£20 $hite, obvz.... But it has a metal gear casing/variable speed knob/fixed trigger hence a shoe-in for pillar drill duties 🥂👍
Will report further, when doing mods to my Lathe 😋 project.
Pillar drill sorted.... 🔧👀
Steel 'rod of truth' checked to be central in base/perp 👍...
Custom retainer, to fix drill into frame...
And wire hose clip holds the drill hard against the body stops ✔️
Now ready to do modding on the Lathe project 😋...
Had 'insp' pop up on the dash trip....
Utoob hitup....
Brake ON, Button IN >> Ign....
W..A..I..T.. >>&.     - - - -  bars 👀👍
Sorted 🛠️
*Miles 78,860 = oil drop @79,000 due 🔧
Given the weather forecast, over the coming days...
@loserone AdBloo tub to the fore >>>>
My *custom shortened Oil Filter Socket performed admirably 🥂
My c/htg copper pipes, joining my tx oil cooler bodge-up, are looking weathered but resolute 👍
Slight top-up to the coolant but likely evaporation near 20k 😮
Had a run out today.... Lovely weather 🏝️
Out A69, past ExSycamore Gap, at Greenhead the fuzz had access onto the main A69 blocked off... All traffic our way sent round by Birdoswald! 😮
We carried on straight through to the back of Brampton, right towards Longtown and then a left down towards Carlisle.
Doubled back towards Newcastle along A69 but fuzz blocking the road still... Sending us all back down the back roads to Gilsland 🙄 >> fu#k that!
Left turn and back along to Low Row (crossing the rails twice), right back to Carlisle then turn up @Lanercost cross roads, up towards Alston...
Take the road to drop down into Haltwhistle >>> back into cruise mode along A69 dual & home.
163 miles...
 Fab run out (... and I know all those roads 😉)
Carter bar.... En route to lunch 🍽️😋
Oooooh! Numbers 👀
...... Whoooshh 🚀
Ace 😍
Given we are on 15k since I changed it....
Blueprint is *kwality kit 👍🔧
Oooof.... 🚀
..... 10mins in the Sun 👍 .....  🏝️
A/F in..... B&D wizz-screwwie ace 🥰
Old filter not really scruffy @15k....
Eeh, isn't *tech GR9! 🙄🔧
..... bimbling along and >>>
>>> Bit of a Trousers Streak Moment!! 👀
Ah Haa.... Having done the a/f yesterday, I'd checked the oil [good habits!] and it was *there on the stick ✔️
Seems AVAS has a manservant, who creeps up on you and coughs.. discreetly.. "It would appear one has a smidge less oil than one might reasonably presume to be a sufficiency, Sir". 🤬
I'm home now and about to drop the last dreggs of the fresh oil change container in....
Nice to have a friend 🧐
YaYee... 🎉🎉
Getting shot of my old alloys today....
£50 lot 👀
Is that weighing them in or selling?
Sold FB, the guy popped up £50 derv money too!
6weeks on Gumtree @£50 = not a sniff (not *even 'chipped Xbox 2nite' 😢)....
What a absolutely Stonkinn Day ♥️🏝️🌞
Blast over Military Rd. into Carlisle, for a lazy lunch....
Wiggled through the lanes down to Penrith and then over Hartside, back to Haltwhistle >> then home along dually past Hexham. 115M @ 5h.
Auto + OOmphhh = chill rolling 😎
Up the hill, from Penrith...
I think that 'hump' is Castle Douglas, Scotland beyond the Solway Firth.... Superb views today [& ice cream van FTW 🍦] 😉
Methinks SWMBO fancies a cup of tea......
..... @Goathland.
Bit of 'Heartbeat' nostalgia
*I 'might' see a toot toot 👀
Ahhh.....
Pah!! Only DervSmokers 2day 🫤
....ooh err, Missus 😍
..... If Yorkshire Council car parks included a ride on the trains >>
>> then £4:50 would look like VFM 😵‍💫
Nothing startling today, just a trundle to enjoy this glorious weather 🌞🏝️.
..... managed to 'loop through' Cresswell, for an ice cream [double + sugar cone 🍦]
...... View North, around Druridge Bay.
*Rather chilly breeze off the North Sea 😵‍💫
  • 4 weeks later...
It's that time again...... 84,000+ 👀
Oil + Filter @85,000 😮
Oil £18.75 + Filter £5.30 (voucher applied 🎉)
...... Sunny Dayyz 🏝️
I occasionally refer to myself as *IMPnutter... 😄
This was my first *resto..... Got an MOT >> promptly stolen 😵‍💫.
.... This was [..is 🥲] my P&J. 998 + viva disc mod.
Stuffed by a wildly tank slapping MK4 cortina taxi >> I.R. seatbelts!! F.T.W.
My fellow IMPclub member, Mr Platten, brought his round for the 'laying on of hands'.
Ex's Crapi 1.6L & 'smiley' IMP, my first one!
Early 80's
That shot of the imp on the trailer behind a Capri is fucking brilliant.  Calendar shot!
Can’t beat an Imp!, my old Dad and I both had one, him in the 70s and me, when I obviously hadn’t learned a lesson, in the 80s.  We changed the engine in his one weekend in the street outside our house at the time because he’d blown his head gasket going on holiday. The donor engine had been lying in someone’s back garden for some time, but it did work for a week or two till someone blew that up spectacularly while overtaking a lorry…….
@privatewire.. Yes, as soon as I got 884KOE unloaded I began uncoupling things/draining down 😄
..... that engine never ran again [parted out to support 998 block assy].
*Something for the Weekend.. 😎
This was waiting for the 998 😋
