Wireless Bluetooth Transmitter - in Cigarette port
Are these any good? Seen em on ebay but Jag I am getting tomorrow being 2003 doesn't have bluetooth and changing the Headunit is not an option because dash and large screen is all moulded as if one piece....
Anyone got one of these?
14 minutes ago, tooSavvy said:
Yup :)
How does it work for you? Are they easy to use? I suppose you just tune it to the same frequency on the fm radio? Do you by any chance have a link to the one you bought?
Thank you
Jag, has a BURY bluetooth system already installed, though not working.
There is also a spare one I purchased in the boot. Never really looked into it to fix it, so you might already have all the bits you need,.
See you in the morning.
Thank you
Yes..... It will play [Blootooth paired] from your phone/or Thumbstick direct (as here for me) and plugged into the aux headphone input - or broadcast on a spare freq for the radio to be tuned into...
Also has mic for handsfree phone answering ;)
Problem with the FM transmitter versions that never get mentioned is if you are traveling through a lot of cities, doing a lot of miles.. then you will probably end up clashing with a local TX near or on your set frequency which will cause interference..
I've had an aux version before, had it in the xantia and it was OK for music, calls were a bit shit though. Perma wired it in and had it power on with the car (well, it would stay on with the engine off and kill its little battery in 2 hours so came back on when the car was on...)
I imagine the fm ones are shit though, any way to aux in? Cd changer port to aux cable?
I use one 50 hours a week.  As long as you pick an empty frequency they're great.
Aldi had them in at £29 and they come with dab aerial to fit.
I’ve only had ones that were rubbish, worked fine when in the driveway but down the road when some of the other radio transmitters come into range they faded and sort of blended together.
is there a CD changer circuit on the Jag you can tap into with a Bluetooth receiver?  This is what I did on the Honda CRV.
I believe you can get a slightly posher version of the Bluetooth radio thing that plugs into the back of the radio aerial socket which is supposed to work better but I’ve never tried one.
Thanks for the replies - I shall look into this. I may have the bits I could cobble together to get it to work with what gadgetgricey is giving me however if unsuccessful I shall look at cable in the cd changer port however this jag has a gigantic satnav screen unit not a conventional single din Headunit to pop out so not sure what the back of one would look like.
On another matter until recently I had been playing spotify on my phone through the aux cable and into my prius but was getting horrendous static and I'm sure others have had it that when the revs build up the whine of the static gets louder. I have now managed to pair my phone up to the bluetooth (took me so long as the entire language of the Headunit is in Japanese being an import and you cannot change this to english) and it is crystal clear with no static at all.....hence why I'd rather go the bluetooth route with the Jag in an ideal world
To get rid of the noise when the engine revs rise, get an in-line earth loop isolator.  About a tenner I think.
I had to get one on my Bluetooth receiver because while it was quiet normally, charging through the cheap 12V USB socket gave the horrible buzzing noise.
My aux to tape with my phone was fucking unbearable in the xm! Interference everywhere, I knew I was getting a call or text a good 5 seconds before the phone rung, and on long journeys I knew when it was changing cell tower too!
Dug my creative zen out for the rest of my ownership of the xm after that!
I will say that I only use mine for music/sat Nav directions.
I use airpods for phone calls.
