How smoky should a diesel be?
My Sharan is on 212k and the engine feels strong. When sitting in traffic it stinks of fumes. Is this normal for a high mileage diesel. It doesn't seem to throw too much clag out the back just a bit.
Exhaust flexi ok? Pollen filter seal? My BMW 530d has 260k and smokes like Dot Cotton when it's on boost but doesn't smell inside.
Diesel Lagunas should not emit any smoke at all. If they do, it is because they are on fire.
Cracked manifold? I know the Honda 2.2 CTDi symptom of a crack manifold is diesel smell in the cabin.
I'm really not sure what it is. I'm not sure it's coming through the vents. More if I have a window slightly down. It doesn't have a webasto heater as far as I know.
I had this on my galaxy - it was something to do with the Aux Heater im sure! 1.9 TDI
Betcha it has a heater and the glow plugs kaput; have a look under the passenger side rear door
Thats the one, thats where mine was - I think the fuse was taken out of mine.
There's a repair manual online for it; apparently the diesel is so thermally efficient that it's used when coolant temp is below a certain degree to give fairly instant heat from start up, and improved cold running efficiency; mine smoked a fair bit and struggled to get to running temperature in cold weather, new glow plug and replace a popped fuse and as I've noticed the last couple of mornings at 0 deg outside it's to 85/90 on the gauge in less than 10 minutes
Have you changed the pollen filter (they get ignored because they're fiddly)
Edited to add: here's the manual http://www.mirez.co.uk/Galaxy/PDF/Galaxy%20-%20Auxiliary%20Heater%20Information.pdf
