Pas rack STOP leak fluid
My wifes Laguna has a slight PAS leak,its very slight,and i know its there,keep an eye on it etc,but it does leak,anyone suggest a good cure leak substance??,i know i should replace the rack,but they aren,t cheap and the arms/track rod ends and gaitors are all perfect,so i would rather just try and stop the leak without the major cost,any advise?
There is some stuff that reconditions the seals, think you can buy it from Halfrauds and the like..Never tried it myself mind..
Must be a Renault thing. I tried the stuff in my old Clio and it worked for a while
Agreed with the Lucas oils additive. I used to sell that stuff in a past life and had some very good reports back.
I used to sell wynns PAS Stop Leak Dave, Was alway told by customers that it was good stuff.Maybe worth a try?
The Lucas stuff is very good, I've used it on my BMW E30 and i've not had to touch it since which suprised me as I was expecting it to be a waste of time and money.
It'll stop leaks on seals, but anywhere else you need to replace. PAS uses extremely high pressure and will blow and repairs out regardless.
