2004 Ford Fiesta. HELP REQUIRED
You need to get it on a four poster with someone driving it up through the gears while you listen through a big screwdriver on the hub carriers. Almost certainly a wheelbearing.
A two poster may be slightly safer.
..... And stress test the jacking points while yrr at it!
TS
I will run it through the gears on the stands again, but listen with a screwdriver on the hub carriers, as suggested.
That is a damn fine/very simple idea, and I am cursing myself to fuck for not thinking of it, myself.
At least the work done should futureproof it a bit!
And no, the bearings aren't expensive. Only a fiver and I already have one.
There's the small matter of the N/S being rusted into the hub, and the ball joint pinch torx bolts rounding when previously attempting hub removal this way, though.
The N/S hub, shaft and bottom arm all had to come off in a oner, to do the 'box.
Oh well, I have never claimed to be a mechanic, I just like to have a go lol.
Cheers, chaps. :-)
Try swapping the front wheels for the rears. As has already been suggested, a tyre delaminating can make odd noises. It may appear to be sound on the outside but completely shafted on the inside.
Guest Hooli
We had a '58 plate fiesta...
... best thing you can do is scrap it, they are one of the few cars with no redeeming features at all.
Guest Hooli
A fiver for the bearing? What kind of chinese shite must they be ?
OEM?
Could be as our 1.25 blew the head gasket at 20k due to the brilliant design of a flappy heater pipe near a sharp edge & a temp gauge that's ECU controlled so you don't get any warning till it flicks to 'boiled'.
I paid just under 70 quid for a blueprint water pump, QH timing belt kit, 5L of correct grade oil, oil/air/fuel filter and a couple of bearings.
They are from a trade only motorfactors, Thor.
Luckily, my uncle has an account, and gets me stuff.
My Mondeo only cost me £20 to service.
