lesapandre Posted December 15, 2023 Posted December 15, 2023 The engine bay/ bonnet on these is not very long - they are pretty cramped inside too. All ash framed - including the doors - and the fabric roof is just that over a metal meshing. So it's going to need to be something short. If an auto box is needed - you'd want something with not too complicated fuel delivery - and not too much weight. An XK engine won't fit I think too. It's also going to need brake and possible suspension work to deal with 150 bhp +. These are about 60bhp on the original unit. I don't know them - but an MX5 engine or equivalent sounds right - it would not look too out of place either - the Riley was DOHC. Looks very sound. Watch out for insurance if modifying - it's got very funny these days. Owners club is very active. Maybe ask them. Rocket88 1
lesapandre Posted December 15, 2023 Posted December 15, 2023 One of the big Austin/BMC 'B' Type Series would be a period modification - there was a 2.6x4 that went in various cars. No auto tho. A bog standard B Series might struggle with the weight but something MGB-ish would work maybe. Or just source an original engine? The owners club wd help I'm sure.
Stinkwheel Posted December 15, 2023 Posted December 15, 2023 10 hours ago, Rocket88 said: If I could find one…… https://www.ebay.co.uk/itm/126117296190?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=eEob4XUsRHG&sssrc=2047675&ssuid=yt8LC5osTgW&widget_ver=artemis&media=COPY This guy has an engine with a torque converter hanging off it, he migh have the gearbox as well? lesapandre 1
Stinkwheel Posted December 15, 2023 Posted December 15, 2023 10 hours ago, Rocket88 said: If I could find one…… found a brand new one 🤣 https://www.ebay.co.uk/itm/223518480340?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=H5DiwuWOQCS&sssrc=2047675&ssuid=yt8LC5osTgW&widget_ver=artemis&media=COPY lesapandre 1
Rocket88 Posted December 15, 2023 Author Posted December 15, 2023 Looks like someone has already done an MX5 conversion! garethj, grizz, chaseracer and 1 other 4
lesapandre Posted December 15, 2023 Posted December 15, 2023 Looks very nicely done. The 1.5 is slow in it's original form - 0-60 about 20 seconds top speed 75 - you'd not want to run much over 65 tho. So no harm in modifications if the car has lost its engine. Rocket88 1
Rocket88 Posted December 15, 2023 Author Posted December 15, 2023 I don’t want to have to start modifying brakes and suspension. Standard set up should cope fine with engine upgrade, which is smaller and lighter than the original. Think I’ve found someone local to me who’ll take on the conversion sdkrc, grizz, Tickman and 1 other 4
Rocket88 Posted December 15, 2023 Author Posted December 15, 2023 Best thing about the MX5 lump is that number of times it’s been used in kit cars, there’s a wealth of knowledge and experience out there with stand alone ECU s etc tooSavvy, Stinkwheel and Saabnut 3
alf892 Posted December 16, 2023 Posted December 16, 2023 Got to be the mx5 unit……..I’ve got an RMA and there is not a lot of room in the bay but the Mazda engine would go in a treat and look similar. Original was twin cam…….cams in block and quite tall. Not sure about gearbox as rear axle part torque tube but then the Mazda engine is maybe a little shorter. Being live the rear axle mounting methods is very simple though…..just a matter of welding a couple of spring perches on the axle case Rocket88 and Matty 2
Rocket88 Posted December 17, 2023 Author Posted December 17, 2023 12 hours ago, alf892 said: Got to be the mx5 unit……..I’ve got an RMA and there is not a lot of room in the bay but the Mazda engine would go in a treat and look similar. Original was twin cam…….cams in block and quite tall. Not sure about gearbox as rear axle part torque tube but then the Mazda engine is maybe a little shorter. Being live the rear axle mounting methods is very simple though…..just a matter of welding a couple of spring perches on the axle case Might possibly change the rear axle……. tooSavvy and alf892 2
Rocket88 Posted December 18, 2023 Author Posted December 18, 2023 Actually clapped eyes on this for the first time today….. it’s really nice! No bubbles on the fabric covered roof ( bad news on these) no rust anywhere, really good chrome and interior. Traded my Scimitar and XM for it, and got £2.5 k in my pocket. Have sourced a Mazda MX 5 engine and auto box to fit Dyslexic Viking, Matty, TrabbieRonnie and 2 others 5
Rocket88 Posted December 19, 2023 Author Posted December 19, 2023 Also hasn’t been plate raped….. eddyramrod 1
Rocket88 Posted December 19, 2023 Author Posted December 19, 2023 On 16/12/2023 at 20:02, alf892 said: Got to be the mx5 unit……..I’ve got an RMA and there is not a lot of room in the bay but the Mazda engine would go in a treat and look similar. Original was twin cam…….cams in block and quite tall. Not sure about gearbox as rear axle part torque tube but then the Mazda engine is maybe a little shorter. Being live the rear axle mounting methods is very simple though…..just a matter of welding a couple of spring perches on the axle case These are the dimensions of the Mazda lump…. eddyramrod 1
alf892 Posted December 19, 2023 Posted December 19, 2023 Might be tight on length…….although the bellhousing to front pulley is ok the quoted overall length (with coils and water fitting) at 26” is a bit much. Presumably these can be moved? At top of block height (ie no head) total you’ve got about 22” between bulkhead and front suspension cross tube…….but below this bulkhead slopes off backwards. Looks like the complete Mazda engine height is about same a riley block height. Can’t see width being a problem…….the o/s footwell does go into the engine bay a bit but could easily be trimmed tooSavvy 1
Rocket88 Posted December 19, 2023 Author Posted December 19, 2023 2 hours ago, alf892 said: Might be tight on length…….although the bellhousing to front pulley is ok the quoted overall length (with coils and water fitting) at 26” is a bit much. Presumably these can be moved? At top of block height (ie no head) total you’ve got about 22” between bulkhead and front suspension cross tube…….but below this bulkhead slopes off backwards. Looks like the complete Mazda engine height is about same a riley block height. Can’t see width being a problem…….the o/s footwell does go into the engine bay a bit but could easily be trimmed Might have to be some bulkhead trimming. I’d prefer to fit the engine as far back as possible . I would think Mazda engine is probably lighter as well. Transmission tunnel is already unbolted, which helps.
sheffcortinacentre Posted December 20, 2023 Posted December 20, 2023 Why same as a ford xflow ( as std springs work fine in MK1/2 escort when I've done them). Coil pack unbolts of back of head. alf892 1
Rocket88 Posted December 20, 2023 Author Posted December 20, 2023 5 hours ago, sheffcortinacentre said: Why same as a ford xflow ( as std springs work fine in MK1/2 escort when I've done them). Coil pack unbolts of back of head. Riley has torsion bar front suspension, so is adjustable
sheffcortinacentre Posted December 20, 2023 Posted December 20, 2023 Bloody spellcheck was supposed to say weight not why.
