PhilA Posted September 14, 2019 Author Posted September 14, 2019 Just spent a pleasant evening BSing about cars with that there Hairnet. Nice to have you stop by! Phil loserone 1
hairnet Posted September 14, 2019 Posted September 14, 2019 Thanks Phil Omg it's late Also shit hire car alert
PhilA Posted September 14, 2019 Author Posted September 14, 2019 Well, there's the rain and thunder that wasn't forecast. 4 weeks with no rain up to right now this morning. Excellent!
hairnet Posted September 14, 2019 Posted September 14, 2019 Porn alert purplebargeken, LightBulbFun and STUNO 3
hairnet Posted September 15, 2019 Posted September 15, 2019 Huge thanks to Phil and Elise Currently in kenner again having lunch at Denny's Heading for mississippi PhilA, STUNO and Saabnut 3
hairnet Posted September 16, 2019 Posted September 16, 2019 Meridian Mississippi ( Google it) Reuben and a soup
hairnet Posted September 16, 2019 Posted September 16, 2019 On 9/14/2019 at 4:54 PM, hairnet said: Mississippi River All them buttons - ejector seat and oil slick and shit Orders Wendy's for ya too
hairnet Posted September 16, 2019 Posted September 16, 2019 Not greenbow Alabama Greensboro breakfast
PhilA Posted September 16, 2019 Author Posted September 16, 2019 That's a very long straight road. Lots of trees. Phil purplebargeken 1
PhilA Posted September 16, 2019 Author Posted September 16, 2019 Ordered oil pump today. New old stock item. Ordered the thrust washers and a new nose seal because the NOS pump is 68 years old and so is the seal. Phil LightBulbFun 1
hairnet Posted September 17, 2019 Posted September 17, 2019 9 hours ago, PhilA said: That's a very long straight road. Lots of trees. Phil actually it wasn't that bad - got twistier later but yeah many tree - saw faiar few logging trucks - was on a roads mostly - trucks don't slow down do they and they don't do 56 like at home overtaken by one on the freeway with cars on the back and I was doing 70 nutters route for tomorrow can go via atlanta and its 5 hours but the twisty alternative NW is only 45 mins more guess what im doin more trees hopefully some toot to look at will I get shot if elmer sees me photoing his tat
hairnet Posted September 17, 2019 Posted September 17, 2019 2 hours ago, PhilA said: Ordered oil pump today. New old stock item. Ordered the thrust washers and a new nose seal because the NOS pump is 68 years old and so is the seal. Phil much like yourself (kidding)
PhilA Posted September 17, 2019 Author Posted September 17, 2019 A lot of older trucks aren't limited, there's no regulation for them to do a set speed other than the company operating them- some bigger firms have limited their trucks to 65 to "save fuel". Flat out the older ones will do over 100 but the tires aren't rated for it. Avoid Atlanta, the traffic through there is horrible. Phil
Jimbo Posted September 17, 2019 Posted September 17, 2019 Nothing more frightening than doing 75 on the interstate in a centre lane and have a big rig either side of you passing at breakneck speed. The box trailers have no chassis or under run protection let alone mudguards, Europe has a lot more safety precautions then a the states.
PhilA Posted September 17, 2019 Author Posted September 17, 2019 Newer trailers are gaining side bars and mudguards but a lot of older stuff still doesn't have. You get used to it, the country is too big to have trucks doing 56 everywhere, also. Plus, most interstates are 2 lanes both ways so getting 2 trucks trying to crawl past each other is a recipe for significant angst. STUNO and colnerov 1 1
PhilA Posted September 18, 2019 Author Posted September 18, 2019 Found manual. Found stroboscopic timing light. Cleaned mile-wide paint off the pulley and did the grooves marked TDC (red), 3° and 6° BTDC in new paint. Timing was nearly 45 degrees advanced. Previous owner had indexed plug leads one off. That's why the idle was lumpy. It's now set to 6° and idles and revs freely. Funny, that. Phil adw1977, mercedade, Tickman and 5 others 8
hairnet Posted September 18, 2019 Posted September 18, 2019 7 hours ago, PhilA said: Newer trailers are gaining side bars and mudguards but a lot of older stuff still doesn't have. You get used to it, the country is too big to have trucks doing 56 everywhere, also. Plus, most interstates are 2 lanes both ways so getting 2 trucks trying to crawl past each other is a recipe for significant angst. Today I only saw that twice in 320 miles
hairnet Posted September 19, 2019 Posted September 19, 2019 48 Buick Roadmaster straight 8 - fireball 8.................
PhilA Posted September 19, 2019 Author Posted September 19, 2019 Brand new, old stock 1951 Hydra-Matic front oil pump. Mmmm. Phil somewhatfoolish, LightBulbFun, hairnet and 1 other 4
colnerov Posted September 19, 2019 Posted September 19, 2019 On 9/17/2019 at 3:10 PM, PhilA said: Newer trailers are gaining side bars and mudguards but a lot of older stuff still doesn't have. You get used to it, the country is too big to have trucks doing 56 everywhere, also. Plus, most interstates are 2 lanes both ways so getting 2 trucks trying to crawl past each other is a recipe for significant angst. Ahh yes, Elephant racing.
hairnet Posted September 20, 2019 Posted September 20, 2019 I have a Ben n my possession Lost for words (Not for the reason you think) ❤️
PhilA Posted September 20, 2019 Author Posted September 20, 2019 My initial suspicion was correct. A bearing wasn't sat fully- the oil pump bearing I replaced. However, my method to attempt to remedy that was flawed, leading to busting the flange on the oil pump. However, I think the flange wasn't straight anyhow looking at the way it sat in the end of the case compared with this one. New pump gone in, factory spec- now with a 66 thou think spacing washer I have 35 thou of lash, so need to tighten that up about 30 thou. Closest washer is 26 thou which would leave me at 11 thou lash which is within tolerance. Ordering washer tomorrow Phil LightBulbFun, cort1977, somewhatfoolish and 2 others 5
hairnet Posted September 20, 2019 Posted September 20, 2019 Oh no Phil's on the lash Oh dear shit joke sorry Phil purplebargeken 1
LightBulbFun Posted September 20, 2019 Posted September 20, 2019 I justed wanted to say Quote Haynes: As described in Chapter 7... Translation: That'll teach you not to read through before you start, now you are looking at scarey photos of the inside of a gearbox. is very appropriate for this thread should anyone make the mistake of skipping ahead a few pages (from here for those not aware, its a right laugh http://messybeast.com/dragonqueen/real-haynes.htm ) paulplom, PhilA and adw1977 1 2
