uk_senator Posted April 9, 2017 Posted April 9, 2017 Had a look at my Daewoo`s ABS problem yesterday, ended up snapping the bracket while trying to get the sensor out of it (and snapped the bolt holding it onto the hub). So if anyone has a NSF Daewoo Lanos hub or upright (and a driveshaft with an undamaged ABS ring would be handy), especially in the London/Herts/Essex/Bucks/Bedfordshire area, give me a shout please. They are closely related to late 80`s/90`s Vauxhalls and share stuff like the bracket with the Astra/Cav, maybe others (but dont have the same ABS ring or sensor). Not sure if the whole hubs are interchangeable. Possibly Daewoo/Chevrolet Lacetti as well. Its so hard to find any info on these buggers, no one seems to be bothering with them, proper shite, set to become extinct in the next decade I reckon, which is a shame as its nowhere near as bad as I was expecting, & is more fun to drive than a lot more `prestigious` Japanese blandmobiles.
twosmoke300 Posted April 9, 2017 Posted April 9, 2017 If you took the knuckle off couldn't a local engine rebuild place get the sensor and bolt out for you ? Got a bloke down this way that would do that for 20 quid
Station Posted April 9, 2017 Posted April 9, 2017 Sensor looks completely mashed. I've never got one out of a car without breaking it.I have on a Saab though, they seem to be better quality and fit OK. uk_senator 1
Eddie Honda Posted April 9, 2017 Posted April 9, 2017 There's enough of that thread still there to lock a pair of nuts and use lots of FIRE to help ease it out. I'll look more later.
twosmoke300 Posted April 9, 2017 Posted April 9, 2017 Not sure a small fiat engine will help much ? uk_senator, Eddie Honda and The Moog 3
uk_senator Posted April 9, 2017 Author Posted April 9, 2017 I will be have a pop with the old blow torch & mole grips, I`ve sprayed it several times with penetrating fluid in readiness (I did the roll bar links while I was down there as I have to change them too), but its all very corroded down there, like a 5 year old Chinese bike, so I`m not holding my breath. I had hoped I`d salvaged the sensor bracket, but as I was levering it off, snap.. Wonderful.. If it comes to it I could always drill & tap another 2 holes in the hub & clamp it on with a bit of perforated strip between 2 bolts as the locating pin is still there, or, Araldite it on if I cant be arsed going through all that agro..
