steveo3002 Posted March 29, 2017 Posted March 29, 2017 ok so ive posted elsewhere , my mk1 focus 1600 petrol has a erratic temp gauge but doesnt appear to actauly be overheating google has threads suggesting a new ecu cured it can i buy a used ecu from the correct engine code and use that ? or main dealer programme jobbie help please really fucked off with it
twosmoke300 Posted March 29, 2017 Posted March 29, 2017 A new ecu would need to be coded . You would be better off sending it to some one like ECUTesting .They would confirm your fault and repair your unit . This wouldn't need any coding / programming
scaryoldcortina Posted March 29, 2017 Posted March 29, 2017 ECU is coded to the keys, you can diy it IF the ecu comes with at least two keys. If not you need either tech2000 or a licenced copy of forscan. Erratic temp gauge might be the clocks starting to misbehave, which is actually more common, they are plug and play so get a £10 scrapyard set and change them first.
steveo3002 Posted March 29, 2017 Author Posted March 29, 2017 its had a brand new set of clocks 18 months ago theres plenty of ecu with one key on ebay...wont one key do it? i have a laptop version of forscan , dont really know wether it does coding or no? what would recoding be under
steveo3002 Posted March 29, 2017 Author Posted March 29, 2017 anyone local that could give me a hand to code it ? cambridge/sudbury/bury st eds
sierraman Posted March 29, 2017 Posted March 29, 2017 I've an ECU, 1 key and a central locking module from a 1.6LX Estate 2001 if that's any good to you.
steveo3002 Posted March 30, 2017 Author Posted March 30, 2017 I've an ECU, 1 key and a central locking module from a 1.6LX Estate 2001 if that's any good to you.just orderd one from egay...cheers anyway
steveo3002 Posted March 30, 2017 Author Posted March 30, 2017 Good old google diagnostics !what do you suggest i do? pay someone £80 an hour to do what ive done so far?
twosmoke300 Posted March 30, 2017 Posted March 30, 2017 personally I'd send the ecu away to be tested and repaired . Ecu faults are really rare to be honest and always a deeply suspicions diagnosis .
steveo3002 Posted March 30, 2017 Author Posted March 30, 2017 well ive gone with a ebay one...might work /might be a waste of money but i figured £35 isnt too bad to try where would i send an ecu to be repaired anyway?
steveo3002 Posted April 3, 2017 Author Posted April 3, 2017 righto ebay ecu worked with its key , hasnt fixed the problem
Jazoli Posted April 3, 2017 Posted April 3, 2017 Have you changed the coolant temp sensor or thermostat?
steveo3002 Posted April 3, 2017 Author Posted April 3, 2017 yes !! engine feels and behaves normal - i "think" its thinking its hot when its fine , will also go back to normal on the gauge if i pull over and switch the ign on/off
twosmoke300 Posted April 3, 2017 Posted April 3, 2017 These have a coolant temp sensor and cyl head sensor dont they ?
steveo3002 Posted April 3, 2017 Author Posted April 3, 2017 yes its a cylinder head temp sensor , they fit in the metal and dont contact the coolant
SiC Posted April 3, 2017 Posted April 3, 2017 When running an OBD scantool in this state, does the temperature on the scantool match roughly what the dash is showing?
twosmoke300 Posted April 3, 2017 Posted April 3, 2017 It will have a normal coolant temp sensor too - have you checked / changed that ?
steveo3002 Posted April 3, 2017 Author Posted April 3, 2017 It will have a normal coolant temp sensor too - have you checked / changed that ?pretty sure it does not ...happy to be proved wrong though doesnt to my mind appear to be overly hot at any time
twosmoke300 Posted April 3, 2017 Posted April 3, 2017 Pm me your reg and I will check on autodata . Pretty sure that era of ford used the cyl head sensor as a backup/ early warning device but still had a normal wet sensor . I seem to remember one being near the plugs somewhere
steveo3002 Posted April 3, 2017 Author Posted April 3, 2017 When running an OBD scantool in this state, does the temperature on the scantool match roughly what the dash is showing? yes pretty much
