Best way to move wheels from Stamford to Tamworth
I have seen a set of steel wheels going free for my new Dolomite but they are in Stamford and it will an age before I have the time to go and collect them. Has anyone found a cheap way to move a set of wheels around?
Or if anyone regularly travels near Stamford and the midlands and would be happy to move them for a small fee/ beer tokens.
I looked at Paisley for getting my Ford wheels down to Kent from Bub, but dug around and found quite a lot of negative feedback about the company. I wonder if they are cheap for a reason!
just found the same myself. I may have to look for a set closer to home as it's not worth forking out a lot on as I only need some to roll it round while I get mine sorted. Might have to do them one at a time if the worst comes to the worst.
Is it all downhill?
TS
I live near Stamford and can store if required
that may help, thanks
I've used them loads of times, and they never fail to do the job quickly and reliably. Yes, the gaffer is a stereotypical grumpy Scotsman, but the actual delivery side of things is spot on. In fact, I've just had a set of alloys delivered this afternoon - they were delivered within 24 hours of being collected from the previous owner. Best bang for your buck if you need wheels delivered.
is it based on distance or weight?
Neither, from my experience. They do a specific deal for 4 wheels with tyres (provided they're not stupid size, like 20" or something) for £28* flat rate anywhere in the UK mainland.
*It was £28 last time I used them, a couple of years back now.
Recently increased to £32.99 (set price regardless of weight) for set of wheels up to 17" to UK mainland addresses. Still not a lot else out there which provides a quick, reliable service, in my opinion.
I travel from Boston to Tamworth about once a month ?
Do you go near Stamford on your way? Happy to buy you some beers for your trouble
I go past Stamford (from Peebo) up to see the Midlands AS crew a fair bit.
If they're not covered in shit I don't mind getting them and dropping them at some services up the M6 the next time I'm heading up.
I go past Stamford (from Peebo) up to see the Midlands AS crew a fair bit.If they're not covered in shit I don't mind getting them and dropping them at some services up the M6 the next time I'm heading up.
That would be brilliant, PM incoming.
