Problems with Photobucket
I have ben unable to post full size photos from photobucket recently, only thumbnails. I have used up all of my very limited knowledge but get nowhere. Is it me or them? help me please :(
Under the 'Upload images & videos' button there's a small link for 'more options' - click that and adjust the image size settings.
Where are you getting the img code from? If you haven't set any of the sizes, it should be automatically to a normal size. When you scroll over the album thunbnail, there should be a drop down menu, you need the IMG code in the list, I think it's the forth one down...
Is it me or them?
If this picture of my two Wolseleys comes out OK, it's you. :)
Posted Image
Thanks chaps, Keef's Wolseleys are on my screen ! the drop down menu on the photobucket is there ok and I have reset it and been through their help system to see what I can do, but nothing :( I can select the img code but cannot get past there, may be something in my computer is wrong so I will investigate.
So you have the line highlighted? RH click on it with your mouse, choose copy from the menu. Type a message and the RH click and choose paste. What happens?If the mouse doesn't work use ctrl+C and ctrl+V.
testing...testing
Posted Image
Well that seemed to work!
Can you all see the communications device fitted in this :)
Posted Image
That's obviously where you have been going wrong. You can't send a picture on one of those things you have to use a modem connected to your PC. :D
Thanks Keef..I could only get noises like a fax machine on that.
wow top shite that nissan, i'd bin the phone tbh (mind i dont carry one here) :lol:
TBH that Prince was a bit of a shed, that phone is probably an r/t judging by the switchgear. The engine had been swapped for a vauxhall 3.3 too, and I think the owner wanted a lot for it :(
