One small step for chod, a giant leap for Renaultkind..Help
Radiator...'99 Trafic diesel......having dealt with two leaks elsewhere in the cooling system caused by water freezing it now time to address the dribble from the radiator core.  I have the ability to solder various metals so would like to know if the core is some type of copper before I attempt to remove radiator, cut away some fins, crimp close and solder up its hole???    This is obviously NOT* a pole where I will tally the YES and NO votes before dismantling the front of the van
Unlikely to be any copper content in a radiator of 1999 vintage, it will be an aluminium core and placca end tanks
Vectra minge penny bodge/fix.... wrapping turns of copper wire [err... thickish?] around exposed tube leak (after pulling away fins) & solder copper wire to itself [making a sleeve jacket], then RadSeal.
..my local Pizza driver guy says it got him a fair few miles out of it - subsequent frontal remodelling  :? had the repair rendered obsolete...
TS
Won't K-Seal help or is the leak too heavy?
Is your soldering gear powerful enough before you go to the trouble of removing all the stuff?
500W with solid 1/2 inch copper bit or if stressed paraffin blow lamp and 3/4 inch square iron, big tin of flux and a solid bar of 40/60 solder?
Hmm, I think Mr_Bo11ox is very likely to be right and that it is plastic and aluminium and therefore you can't solder it.  Most cars stopped copper in the early 80s, really a generation before this car.
I have had some luck with encapsulating the problem area in a big blob of araldite before.
