Brake Pad Question
Yo
If I needed brake pads, but the trained chimps at Euro have supplied brake pads with a wear sensor, will anything bad arise from just chopping the wear sensor cable off them? I can't be arsed to drive 15 miles back to swap them, but if it's gonna mean at some point I slam headlong through a shopping centre through catastrophic brake failure, I might.
Tar.
If you don't need the wear sensors then I can't see that removing the unwanted items will cause sudden Armageddon when you use your brakes! :lol:
Hi you won't do any harm lopping the sensor wire off the pads.
although your brake light may stay on :lol:
Fair enough, I'll print that reply out and keep it in the glovebox to be found by the accident investigator :)
in that case *death is certain and we the posters of autoshite accept no responsiblity for above posted comments* :lol::lol::lol::lol:
My printer is certain to run out of ink before getting to the disclaimer. Awww.
Thanks for the replies, I shall get Special Car Repair Tool #4 out (kitchen knife) and modify them.
