Tell me which oil i should use
I tend to rag the arse of my gsa shitroen and do quite a lot of long hard miles. I notice when its cold it sound lovely and quiet, after i have done a few miles it develops a more tappy sound. Presumably i need a thicker oil that doesnt thin too much as it heats? What oil/grade/brand should i buy? TIA. L
I would think a 20/50 would be orig spec. Halfords used to do their own brand Classic 20/50 but as it isn't any good for push bikes I expect it is no longer available.
Just checked and surprisingly its still on sale.
Valvoline mineral 20/50 Race oil proper zdp content holds racing etypes and rover v8 engines together even when showing 0 oil pressure at idle.
Fantastic stuff, also cuts oil consumption on the engines I've used it in.
I own a VW T2 where arguments about oil are legendary.
Thirty monograde vs 20W50 ad infinitum...
My local VW specialist has just oil changed me to 5W40?
It's a mineral oil and may be worth a try as an alternative to 20W50 which is a very old fashioned narrow band?
Fuck knows, I'm just an end user.
whats in it now...might be failing to stay in spec as it gets hot
Most of the GS guys I know use 10w40 without issue. I use this also without issue. From memory it's one if the recommended grades in the GS handbook.
Important thing is to use a good quality filter brand such as Purflx. You can buy a spigot adaptor from Chevronics to allow fitting of the more modern BX/Xantia fitment Purlux filters as the GS specific ones are no longer available.
Cheapest place for Purflux filters is GSF when they have their money off weekends.
