ModernShite EGR
I need advice on EGR which is both Auto and definitely Shite!
I've an A180cdi and am considering EGR delete. Too modern to just blank off so have to go ECU route.
Any recommendations and would I still be better blanking it after?
If all goes to plan I'm hoping to run this until it's into proper Autoshite territory so look on any answers as futureproofing the forum.
Sent from my X17 using Tapatalk
No remappers or ECU gurus jumping in on either do or don't. Oh the dilemma!
I've looked into it on my e46 330d and its a bit of a pain in the ass as it'll throw up an eml light. If I do I'll be getting a delete kit and blanking it off completely, mainly to get clearer airflow into the engine.
Although, at the same time as getting that programmed out I can get a cheeky remap. then maybe a decat. And then...
You may have to delve into model specific forums to find out about yours.l though. I'm sure it'll be covered.
Years back i blanked the egr on my focus with a plate that had 6mm hole in it.
This was suposed to fool the ecu into thinking the egr was still functioning.
It cured the intermittant sticking egr and smoke/loss of power but every now and again the engine system fault message is displayed and a p0400 code generated but no full mil light or lop
There is a garage in maidstone called red oak who do a lot of egr delete mapping,may be worth a call just to see if its doable.
Id be careful EGR blanking a modern diesels, even with a remap. Quite a few of them use the recirculated gasses to stop the turbine cooking itself.
Damn emission controls!
Aye, that sounds like an expensive issue whilst trying to evade an expensive issue
Thanks all for useful replies. Tried A class club but more they're more interested in syncing i-phones or go faster carbon!
