Oil stop leak additive, any thoughts?
As Station has rightly said, all the Wynns oil stop leak does is thicken the oil in the sump.
I think its coming from the camshaft oil seal, but to be honest the thought of having the belt off etc to replace a £4 seal is a bit much.
Just in case you're tempted, I can report that moulding a supplementary external camshaft seal from half a tube of silicone sealant, has absolutely no beneficial effect. As proved by the previous owner of the van!
Hi, From what I understand it attacks.. reacts affects the oil seal and makes it swell and grip tighter...ooer :oops:
Try a bit on the ole dick.....if it works throw it in your engine :shock:
Years ago they used to lob a handfull of sawdust in there :-D used to work in gearboxes,
or was that when the dog leaked on the kitchen floor...........................either way it worked...sort of :?
