SBC help needed
My boss has a mastercraft ski boat running a chevy 350 does anyone know of a good forum for this engine.
It's got a tick from the top end, so we need info on engine i.d and clearances and torques etc for when we pull it apart.
Any info, or a point in the right direction would be appreciated.
Thanks, Rob.
A Formula 1 stock car forum, if such a thing exists, might help. I'm sure they will know all about mixing and matching yank V8s.
If it's got hydraulic lifters, give it a good flush out. What oil are you using, by the way?
Is this the fabled 350cid Diesel, or the run of the mill petrol?
No forum necessary. There isn't a thing to know about the SBC that I don't know.
First thing to do is adjust the rockers.
This (odd as it sounds) is done while the engine is running.
- Buy a set of new rocker cover gaskets.
- Let engine run until it reached operating temperature.
- Switch off engine.
- Remove 1 rocker cover.
- Stick a length of cardboard in at the outside of the cylinder head to avoid too much spillage.
- Start engine.
- One by one, loosen the nut of each rocker until you hear it knocking, then tighten until it's quiet, then another 1/4 turn.
- Once done, switch off the engine, replace the rocker cover, and don't be one of the twats that doesn't use a torque wrench to tighten the bolts.
- Repeat the above for the other side.
