Removing bonded front screens?
Any advise on this,all trims etc are removed,so is the dash etc,so nothing in the way,but how do i start,my dad has the cutting wire.
Disclaimer: I've never done this, so this is just theory and a very quick Google.
Push the wire through the bond material and then, using it like a cheese wire, pull-and-saw through the bond all the way around the screen. Sounds like hard work, but straightforward. Caution is advised at corners where it's more likely you'll damage the glass.
Get started as best you can with an assortment of stanley knives, pointy things and swearwords. Don't "wedge" anything in or you'll crack the glass, just attack the glue until you can make space to poke the wire through, then just get someone on each side and saw it out. Once you get the wire through it's dead simple really.
