FB60 rolls royce engine
i had a strange phonecall from an old friend tonight....
while doing some demolition and rebuilding of farm buildings this afternoon, he turned up an FB60 rolls royce engine with a borg warner box attached (after googling; i suspect its 'model 8' borg warner) and twin SU's, it looks clean and turns over by hand, the owner said it was running a couple of years ago. apparantly the old boy wanted to fit the block to his landrover, but couldnt find anyone to take on the task
i know the FB60 is a development of the B40/B60 engine used by the military, but was it ever used in any other production car other than the Princess 4 litre? (and the austin healey 4000 prototypes)
is there a 2wd manual box that would mate with the fb60 engine?
I bet my neighbour would give your mate some groats for it.
GR8 4 DAIMLER FERRETS.
i was thinking of using it myself, perhaps in a scimitar, but want a manual box
Is the Vanden Plas 4 Litre R the same car as the Princess? Mate of mine is bangering one (and it's biscuit two tone) but I think that had a BW35 on it.
yes, same car
from description given, this autobox is not a 35
yes, same car
I imagine it was designed from the ground up to work with a slushmatic. I can't see an APC requiring a manual box. It might be a case of making up an adaptor plate and seeing how you go.
