Ford diesel engine idle question
One for all you oil burners out there - I'm helping a mate sell on his 2004 Focus Tdci. Car is in pretty good condition but I have noticed that it idles and starts like a pig when cold. Once warm, even slightly warm, it is fine but obviously, when selling on to a punter they will not necessarily think that it is nothing to worry about - if fact, I would say that it could be a deal breaker especially as they sound like a sack full of spanners in a cement mixer at the best of times. White smoke on start up clears when warm.
I wonder if this is the ford 1.8 tdci issue of a poor signal from the crank shaft sensor - a common issue apparently but surely that would cause the issue even when hot?
MAF clean? another option I suppose.
Any ideas?
Bung a set of glowplugs into it first - if it only does it when cold it's most likely a dud one making it start on 3 until it warms enough for the last one to fire. The white smoke is the unburnt fuel from the misfiring cylinder.
If that doesn't fix it, google has a whole world of pain waiting just a search away.
LOL - THIS is EXACTLY why I drive CHOD!
are you sure it's not the alternator? :shock:
Had issues with the Dual Mass on these- causes poor starting etc as the crank sensor takes its pickup from the flywheel...if the DMF is worn/broken up it gives symptoms like a worn distributor shaft, just like on an old Chevette!
