Prima injector pump. HELP!
After a quote of £130 to fix a leak jumped to £270 or £330 for a full refit "which it really needs" once they had it in and in bits, I'm after an injector pump for a turbo Perkins Prima - any leads on dead Montego TDs etc gratefully recieved.
This is titled as a lift pump. Sorry I know fuck all about diesels, so I don't know if this is the one you need.
http://www.ebay.co.uk/itm/PERKINS-PRIMA ... 336db58301
that is just a standard fuel pump - I guess what is needed is an injector pump (that injects the fuel into the engine)
Cheers, Ash, that's not what I need but hopefully I'm sorted thanks to a kind fellow Shiter!
