Dyslexic Viking Posted October 5, 2022 Author Share Posted October 5, 2022 Got a problem with the bolt for the cam now. I can't get it loose. I had it out yesterday when I was cleaning and it was hard to get out then but I screwed it in without a problem and didn't tighten it too hard. But now it is impossible to get out and this is made worse by the fact that the bolt is 6mm and it is tight there. I'm going into civilization tomorrow so will take this to the local garage and see if they can help as I'm out of ideas. CreepingJesus 1 Link to comment Share on other sites More sharing options...
Dyslexic Viking Posted October 6, 2022 Author Share Posted October 6, 2022 17 hours ago, Dyslexic Viking said: Got a problem with the bolt for the cam now. I can't get it loose. I had it out yesterday when I was cleaning and it was hard to get out then but I screwed it in without a problem and didn't tighten it too hard. But now it is impossible to get out and this is made worse by the fact that the bolt is 6mm and it is tight there. I'm going into civilization tomorrow so will take this to the local garage and see if they can help as I'm out of ideas. Visited the local garage today and don't know what's wrong but he wasn't as helpful and nice as he used to be. So they couldn't or possibly wouldn't help. So I have to figure this out myself. The bolt is 6 mm as I have said and a 6 mm socket just slips and does not get hold of the bolt head. I have tried other sockets, also 5.5 mm, but none of them fit. I have also had to grind down the outside of the socket to get it on the bolt head because it is tight. So I think I'll have to see if I can find some tool I can buy that can loosen it. But attaching pictures of the bolt in case anyone has any suggestions and ideas. Link to comment Share on other sites More sharing options...
Mr Pastry Posted October 6, 2022 Share Posted October 6, 2022 Bad luck with that. It seems to me that if you do get the bolt out, it may not be re-useable, so you will need another one, and it is not a conventional bolt. The thread in the cam may also be damaged. The easiest option might be to swap the complete assembly off another pump if you can find one. Dyslexic Viking and CreepingJesus 2 Link to comment Share on other sites More sharing options...
MorrisItalSLX Posted October 6, 2022 Share Posted October 6, 2022 You could cut a slot in the head of the bolt and remove it with a flat blade screwdriver, and probably reuse it afterwards as such. tooSavvy, mk2_craig, loserone and 1 other 4 Link to comment Share on other sites More sharing options...
tooSavvy Posted October 6, 2022 Share Posted October 6, 2022 3 minutes ago, MorrisItalSLX said: You could cut a slot in the head of the bolt and remove it with a flat blade screwdriver, and probably reuse it afterwards as such. Toppo idea..... Replace with hex cap head or a Star... 🤔 Loving this car..... Dyslexic Viking 1 Link to comment Share on other sites More sharing options...
Dyslexic Viking Posted October 6, 2022 Author Share Posted October 6, 2022 46 minutes ago, Mr Pastry said: Bad luck with that. It seems to me that if you do get the bolt out, it may not be re-useable, so you will need another one, and it is not a conventional bolt. The thread in the cam may also be damaged. The easiest option might be to swap the complete assembly off another pump if you can find one. Yes, this is bad luck. And I have thought about it and it is probably as you say that the threds are damaged, this is perhaps due to the fact that it has been mounted incorrectly. And the bolt is a special bolt and it is probably not possible to get it out without destroying it. So I've been looking for this part and managed to find a complete one for sale in Greece that wasn't expensive so I bought it. So that should fix this. mk2_craig, auntiemaryscanary, RayMK and 5 others 8 Link to comment Share on other sites More sharing options...
rusty_vw_man Posted October 6, 2022 Share Posted October 6, 2022 You've got nothing to loose now then getting a bit more violent with this one! It looks like it is above the level of the casing, so if this were me I'd get get a set of mole grips on it - a set with decent teeth to get a good grip, a bit of heat and some decent penetrating oil. Your sketch suggests the bolt passes through the shaft all the way into the rear of the cam, so hopefully you could get some penetrating oil in from the rear as well.... If it still wasn't moving I'd be tempted to weld a stubby bolt to it - the heat of the weld will probably shock it free, and would give you a better head to get a good grip on. Once its out you could probably find or fashion a new bolt. Dyslexic Viking 1 Link to comment Share on other sites More sharing options...
Dyslexic Viking Posted October 6, 2022 Author Share Posted October 6, 2022 28 minutes ago, MorrisItalSLX said: You could cut a slot in the head of the bolt and remove it with a flat blade screwdriver, and probably reuse it afterwards as such. It's a good idea, but the bolt is so tight that this probably won't work. And there is a high probability that the threads are broken. So I bought another one. MorrisItalSLX 1 Link to comment Share on other sites More sharing options...
Dyslexic Viking Posted October 6, 2022 Author Share Posted October 6, 2022 5 minutes ago, rusty_vw_man said: You've got nothing to loose now then getting a bit more violent with this one! It looks like it is above the level of the casing, so if this were me I'd get get a set of mole grips on it - a set with decent teeth to get a good grip, a bit of heat and some decent penetrating oil. Your sketch suggests the bolt passes through the shaft all the way into the rear of the cam, so hopefully you could get some penetrating oil in from the rear as well.... If it still wasn't moving I'd be tempted to weld a stubby bolt to it - the heat of the weld will probably shock it free, and would give you a better head to get a good grip on. Once its out you could probably find or fashion a new bolt. I might try to get it loose but will wait until the second part has arrived. Because if I destroy this and the other one I have bought should turn out to be the wrong part, then I have a big problem as this part is not something that is easy to find and I was lucky to find another one. But these are good suggestions you have here. Link to comment Share on other sites More sharing options...
Jenson Velcro Posted October 6, 2022 Share Posted October 6, 2022 Would an Irwin bolt extractor fit on there? Can’t think of a reason for it in that location but is it a left handed thread? Dyslexic Viking 1 Link to comment Share on other sites More sharing options...
Dyslexic Viking Posted October 6, 2022 Author Share Posted October 6, 2022 6 minutes ago, Jenson Velcro said: Would an Irwin bolt extractor fit on there? Can’t think of a reason for it in that location but is it a left handed thread? I don't know as I am not familiar with that tool. So had to check it up. And threds are normal. Link to comment Share on other sites More sharing options...
MorrisItalSLX Posted October 6, 2022 Share Posted October 6, 2022 The added bonus of buying a replacement is it will confirm the theory that the original one was fitted upside down. Dyslexic Viking 1 Link to comment Share on other sites More sharing options...
Dyslexic Viking Posted October 6, 2022 Author Share Posted October 6, 2022 10 minutes ago, MorrisItalSLX said: The added bonus of buying a replacement is it will confirm the theory that the original one was fitted upside down. Yes that is a good point and I have thought about this. Just hope that it is the right way according to the manual, if not then I don't know what to believe. Link to comment Share on other sites More sharing options...
Popular Post Dyslexic Viking Posted October 21, 2022 Author Popular Post Share Posted October 21, 2022 In case someone has forgotten, this is work on the throttle part of the diesel pump since it turned out earlier that some parts were installed incorrectly. Today, something has finally happened with this one again. The new/used rear part of the diesel pump arrived today from Greece. I have also received a gasket set for the diesel pump. So this means I can finally make an attempt to fix what is wrong. And there is a difference between the cam on the part from Greece on the left and the one I have on the right. The one on the left is also mounted as we have assumed is the correct way, so then the manual is correct. And after checking where this bit is bolted to on the pump There are also other differences, the part from Greece on the left and my part on the right again. And after checking the manual, the part on the left is correct, so the one I have is mounted wrong. So it's not just the cam that was mounted incorrectly, the part it rides on is also mounted incorrectly. So someone really messed things up on this one. So I chose to use the new parts and after a thorough cleaning, this was put back together and mounted on the diesel pump. And after a little adjustment on the throttle linkages, I started it and it runs perfectly. So it was backed out to let the engine run a bit. And the throttle is much more responsive now and I feel I can increase the revs much more than before. So I think this is fixed now. And I didn't give it full throttle in the video below. 20221021_133318.mp4 Popsicle, JakeT, loserone and 47 others 50 Link to comment Share on other sites More sharing options...
Nullzwei Posted October 21, 2022 Share Posted October 21, 2022 Great success! That engine sounds as a sweet as a nut for a nigh on 60 year old motor. Dyslexic Viking and LightBulbFun 2 Link to comment Share on other sites More sharing options...
Yoss Posted October 21, 2022 Share Posted October 21, 2022 Brilliant. Glad to see some progress. I really look forward to updates on this car. LightBulbFun and Dyslexic Viking 2 Link to comment Share on other sites More sharing options...
Popsicle Posted October 21, 2022 Share Posted October 21, 2022 Fantastic, glad you've been able to sort it out. Dyslexic Viking 1 Link to comment Share on other sites More sharing options...
Nibbler Posted October 21, 2022 Share Posted October 21, 2022 Thumbs up👍 This is one of my favourite threads, keep up the good work! Dyslexic Viking 1 Link to comment Share on other sites More sharing options...
busmansholiday Posted October 21, 2022 Share Posted October 21, 2022 So, over the snowie winter months all you have to do is track down the idiot who rebuilt the pump wrongly and ask him why. Dyslexic Viking, Nibbler and CreepingJesus 1 2 Link to comment Share on other sites More sharing options...
auntiemaryscanary Posted October 21, 2022 Share Posted October 21, 2022 Great stuff, your dogged determination has paid off. The engine sounds lovely. Dyslexic Viking 1 Link to comment Share on other sites More sharing options...
hairnet Posted October 21, 2022 Share Posted October 21, 2022 beast sounds better than bekos hdi Dyslexic Viking 1 Link to comment Share on other sites More sharing options...
Zelandeth Posted October 21, 2022 Share Posted October 21, 2022 Sounds very similar to my OM.601 - though given the shared heritage I guess that's not massively surprising. Dyslexic Viking 1 Link to comment Share on other sites More sharing options...
Rusty_Rocket Posted October 21, 2022 Share Posted October 21, 2022 Sounds amazing! Well done! Dyslexic Viking 1 Link to comment Share on other sites More sharing options...
Zelandeth Posted October 21, 2022 Share Posted October 21, 2022 Also worth noting, if that pump has had the throttle travel that limited for a long time, don't be at all alarmed if you get an almighty cloud of black smoke out the back first time you give the engine any real revs under load. Epic levels of clag are pretty inevitable as all the accumulated soot is blown out. A few full acceleration runs now you've got full fuel available will probably do it the world of good. auntiemaryscanary, LightBulbFun, Dyslexic Viking and 2 others 5 Link to comment Share on other sites More sharing options...
hairnet Posted October 21, 2022 Share Posted October 21, 2022 bjorn nyland will beat down your door if you do Dyslexic Viking 1 Link to comment Share on other sites More sharing options...
Dyslexic Viking Posted October 21, 2022 Author Share Posted October 21, 2022 Thanks everyone. And I would like to know why this was put together wrong, but we will probably never know. I just hope that idiot hasn't been inside the rest of the diesel pump. And it will be exciting how this behaves now that this has been fixed. And I hope that I'm lucky and the weather cooperates so I can drive it one last time before the road salting starts. But I am very surprised at how well liked this and the thread are, I would never have imagined this. So this is just great, so thank you all for that, I just hope that I manage to keep the thread interesting. mercedade, mk2_craig, danthecapriman and 15 others 15 3 Link to comment Share on other sites More sharing options...
junkyarddog Posted October 21, 2022 Share Posted October 21, 2022 It is possible that those modifications may have been deliberate to reduce fuel consumption,and also performance. It's common enough here with tractors to turn the pump down a bit to burn less fuel. Probably unlikely in your case,but you never know. Dyslexic Viking 1 Link to comment Share on other sites More sharing options...
jon.k Posted October 21, 2022 Share Posted October 21, 2022 That sounds so much smoother than I would have expected for a diesel of that time. Nice work! Dyslexic Viking 1 Link to comment Share on other sites More sharing options...
Dyslexic Viking Posted October 21, 2022 Author Share Posted October 21, 2022 (edited) 23 minutes ago, junkyarddog said: It is possible that those modifications may have been deliberate to reduce fuel consumption,and also performance. It's common enough here with tractors to turn the pump down a bit to burn less fuel. Probably unlikely in your case,but you never know. It is possible but I doubt it. What I think happened is that someone who didn't know what they were doing worked on the pump. I can add that I didn't know what I was doing at the diesel pump at the start either, but I wanted to learn and check that I did things correctly and the person who had done things wrong could also have done that. Edited October 21, 2022 by Dyslexic Viking juular, Dave_Q, GagaStan and 5 others 8 Link to comment Share on other sites More sharing options...
auntiemaryscanary Posted October 22, 2022 Share Posted October 22, 2022 Please, please take it out for a good drive on the roads before they start salting. The smile you will get will last you all through winter. If you are at all worried about any breakdown then don't drive far from home (10km in any direction?). Your dad can always then tow you home with a tractor! LightBulbFun, Crackers, Popsicle and 2 others 5 Link to comment Share on other sites More sharing options...
