tom13 Posted February 15 Share Posted February 15 17 hours ago, JJ0063 said: So after our trip away I decided to order some parts as the aux belt is chirping and it’s doing my head in. The tensioner looks as though it’s worn and WD40 only stopped the belt for a couple of mins then it started again. New belt and tensioner on its way. There’s a common issue on the 2.4 where oil leaks from a gasket between the water pump and vacuum pump.. ours is leaking so whilst I’ve got the belt off I may as well just do it. New vacuum pump and gasket ordered. Other less important bits waiting for pay day… The side markers are not my favourite things but the Jumbo has 2 each side from factory, 2 of mine have missing covers and it’s either eBay specials or £40 each from Ford! Have you used the vactan before? Is it any good? I have the same stuff in my ebay basket. I wonder how much 1L would cover? Link to comment Share on other sites More sharing options...
JJ0063 Posted February 15 Author Share Posted February 15 9 hours ago, dave j said: Looks like a bargain! That toilet takes up a lot of space so I can see the benefit of removing it .. but next time you need a pee at 4am when you are camping you might think different! Thanks mate! Very happy with it. 5 hours ago, 3VOM said: Another reason for ramps. You don't want to park on an incline and find one part of your drainage system is now trying to run uphill. This is a very valid point! 1 hour ago, wuvvum said: I'm the same except when I've been on the beers the night before, which does occasionally happen when one is camping. I'm actually half tempted to nab your toilet. With that, the inverter-powered fan heater and a blow up mattress in the back of the Maxus I've got myself a fully equipped* camper. Please come and take it, I don’t know what to do with it! I’ve never used it but can only assume it works. I don’t have any of the fluid or whatever to try it. Can’t work out how it flushes but assume it needs some fluid to flush. (I’ve not shat or slashed in it) 1 hour ago, tom13 said: Have you used the vactan before? Is it any good? I have the same stuff in my ebay basket. I wonder how much 1L would cover? I have seen people use it on YouTube with good results. I’ve used Kurust before and it’s worked, this is essentially the same product. 1l will go a fair way - Im just planning on sanding back any spots first rather than just putting paint straight on. tom13, mercedade and wuvvum 2 1 Link to comment Share on other sites More sharing options...
JJ0063 Posted February 15 Author Share Posted February 15 Stumbled upon this pic, saved for paint inspiration. Dyslexic Viking, blakey79 and AnnoyingPentium 3 Link to comment Share on other sites More sharing options...
AnnoyingPentium Posted February 15 Share Posted February 15 Could always do it with blackboard paint like the 928 Jeremy Clarkson had in the £1,500 Porsche Challenge... just saying. Link to comment Share on other sites More sharing options...
JJ0063 Posted February 16 Author Share Posted February 16 47 minutes ago, AnnoyingPentium said: Could always do it with blackboard paint like the 928 Jeremy Clarkson had in the £1,500 Porsche Challenge... just saying. I did a Fiat Cinquecento in that about 12 years ago. I made a front splitter out of yellow striped danger tape. I’ll leave you to picture that, it was pretty special. I also painted a ZX Matt black too, only issue being I decided to use the paint left over from the Cinq, then ran out after doing less than half on a Sunday afternoon so had to drive to and from work all week with the car half painted. That one looked as good as you can imagine, too. AnnoyingPentium 1 Link to comment Share on other sites More sharing options...
mat_the_cat Posted February 16 Share Posted February 16 16 hours ago, dave j said: That toilet takes up a lot of space so I can see the benefit of removing it .. but next time you need a pee at 4am when you are camping you might think different! The sink can be a plan B, although we have a toilet in ours. We often sit in bed watching a film with a few drinks, so it's a PITA if we'd have to go outside before going to sleep. Link to comment Share on other sites More sharing options...
leafsprung Posted February 16 Share Posted February 16 I've always assumed that the majority of campervans are various shades of white and hearing aid beige so that in the summer you don't end up with an uninhabitable mobile sauna no matter how good your insulation is. Our loft conversion has 150mm of celotex in the rafters and we still have to move the nipper downstairs some nights over the summer as it get unbearably hot. catsinthewelder 1 Link to comment Share on other sites More sharing options...
JJ0063 Posted February 16 Author Share Posted February 16 1 hour ago, leafsprung said: I've always assumed that the majority of campervans are various shades of white and hearing aid beige so that in the summer you don't end up with an uninhabitable mobile sauna no matter how good your insulation is. Our loft conversion has 150mm of celotex in the rafters and we still have to move the nipper downstairs some nights over the summer as it get unbearably hot. Quite possibly but it looks poor at the moment and I need to treat some rust. I’ll chance it - lots of people have used this military paint with good results and never seen anyone complain about temps after. Link to comment Share on other sites More sharing options...
JJ0063 Posted February 19 Author Share Posted February 19 Shitter cubicle fully out, way more spacious now. Changed the aux belt, tensioner and vacuum pump the other day too. Next job is to remove the seat bench, going to create two separate seat boxes with a fixed table between them and then where part of the toilet cubicle was im going to make some sort of cabinet with drawers in - may even try and get a kitchen unit carcass with drawers. Side wall will be cladded. Oh and I also fitted a new set of runners on the side door, much easier to close now. wuvvum, Dyslexic Viking, AnnoyingPentium and 4 others 7 Link to comment Share on other sites More sharing options...
JJ0063 Posted February 20 Author Share Posted February 20 Seat box out, shortened and refitted. So much tiger seal holding all the fascia boards on. I’ve tried to re-use the wood but a few bits split so I may well just have this as a mock up and then replace when funds allow. Next job is to build another identical box seat and have one each side of a fixed table. privatewire, Dyslexic Viking and Popsicle 3 Link to comment Share on other sites More sharing options...
JJ0063 Posted February 21 Author Share Posted February 21 Just noticed I have no ESP light or ABS light on the dash. FML Lets hope it’s just a sensor and someone has been lazy and taped the bulbs or something. Gonna plug it in at the weekend. Quick google shows it to be a very common problem at least. Link to comment Share on other sites More sharing options...
wuvvum Posted February 21 Share Posted February 21 Another advantage of owning a Transit. I was in my local garage earlier booking MOTs, and I asked them if any of their diagnostic machines would be able to turn off the ABS light on the Maxus. The answer was "I doubt it, I've never been able to get into an LDV, they're a bit weird". JJ0063 1 Link to comment Share on other sites More sharing options...
Rustybullethole Posted February 22 Share Posted February 22 On 2/16/2022 at 10:13 AM, JJ0063 said: Quite possibly but it looks poor at the moment and I need to treat some rust. I’ll chance it - lots of people have used this military paint with good results and never seen anyone complain about temps after. I used a roller on mine in raf blue/grey came out just fine and no problems with heat in the summer though I did paint the tin top white as a nod to the potential issue. It’s a lot cooler than my old van though that was a minibus so more windows and less insulation. JJ0063 1 Link to comment Share on other sites More sharing options...
JJ0063 Posted February 24 Author Share Posted February 24 Thought I better have a look into the lack of ABS and TC lights.. At least it was only blu-tac. Picked it out and now at least have the lights working even if there is a fault. Need to get someone with some half decent diagnostics to plug it in but from what I’ve read it’s typically a wheel sensor.. let’s hope so anyway. Carl1981, loserone, Jamie and 1 other 1 1 2 Link to comment Share on other sites More sharing options...
cobblers Posted February 24 Share Posted February 24 bastards loserone and JJ0063 2 Link to comment Share on other sites More sharing options...
JJ0063 Posted February 24 Author Share Posted February 24 Picked up a piece of brand new worktop really cheap off Gumtree. Was going to get thinner lightweight stuff but this was so cheap for what it is and by the time I cut it to size and cut the hole for the sink and hob it won’t weigh much. Who says an e92 isn’t practical. Just need to try and find a single kitchen base unit with drawers in it now to go where the toilet was. If anyone has one and is in Norfolk then let me know! privatewire and cobblers 2 Link to comment Share on other sites More sharing options...
wuvvum Posted February 24 Share Posted February 24 9 hours ago, JJ0063 said: Picked it out and now at least have the lights working even if there is a fault. Need to get someone with some half decent diagnostics to plug it in but from what I’ve read it’s typically a wheel sensor.. let’s hope so anyway. I could come over and pick up the shitter and bring Foreskin Forscan with me - that should be able to talk to the ABS on a Transit that age. JJ0063 1 Link to comment Share on other sites More sharing options...
JJ0063 Posted February 24 Author Share Posted February 24 22 minutes ago, wuvvum said: I could come over and pick up the shitter and bring Foreskin Forscan with me - that should be able to talk to the ABS on a Transit that age. If you want the shitter on the basis I have no idea how and if it works, it’s yours. You plugging the van in to see if you can help diagnose it sounds like a fair trade to me. Im in Sporle near Swaffham if you know it. I’m about all day tomorrow and most of the weekend if you fancy it 👍 Link to comment Share on other sites More sharing options...
R114 Posted February 24 Share Posted February 24 10 hours ago, JJ0063 said: Thought I better have a look into the lack of ABS and TC lights.. At least it was only blu-tac. Picked it out and now at least have the lights working even if there is a fault. Need to get someone with some half decent diagnostics to plug it in but from what I’ve read it’s typically a wheel sensor.. let’s hope so anyway. One of our minibuses at work of a similar age had those two lit and I read the same about the sensor. In this case, one of the rear springs had broken and sliced through the sensor cable in the process. JJ0063 1 Link to comment Share on other sites More sharing options...
JJ0063 Posted February 24 Author Share Posted February 24 14 minutes ago, R114 said: One of our minibuses at work of a similar age had those two lit and I read the same about the sensor. In this case, one of the rear springs had broken and sliced through the sensor cable in the process. I have no idea how long the fault has been here so I think the best course of action is to see whether @wuvvum’s kind offer of Forscan when he visits picks up the fault or at least area of fault, I can then at least know what corner to get investigate. Hopefully a simple fix that someone over the years was just too lazy to sort. Link to comment Share on other sites More sharing options...
JJ0063 Posted February 25 Author Share Posted February 25 New proper work surface fitted rather than just painted ply did it a bit longer to give us a bit of work surface too. Just need to buy an end cap for it. Going to mount some kind of kitchen bin to the side of the cupboard under the bit sticking out. tom13, privatewire and Dyslexic Viking 3 Link to comment Share on other sites More sharing options...
wuvvum Posted February 25 Share Posted February 25 Sunday morning probably best for me if you're about then? JJ0063 1 Link to comment Share on other sites More sharing options...
Sunny Jim Posted February 25 Share Posted February 25 Me with my H&S hat on again! Do you enjoy a drink? Staggering out for a piss and stumbling into the corner of that worktop will hurt - maybe round it off? (I lived in trucks for a few years and have undertaken extensive research into the perils that can befall the inebriated in a confined living space.) mat_the_cat, Twiggy and mercedade 3 Link to comment Share on other sites More sharing options...
JJ0063 Posted February 25 Author Share Posted February 25 3 hours ago, wuvvum said: Sunday morning probably best for me if you're about then? I can be about no problem. I’ll PM my address shortly 👍 2 hours ago, Sunny Jim said: Me with my H&S hat on again! Do you enjoy a drink? Staggering out for a piss and stumbling into the corner of that worktop will hurt - maybe round it off? (I lived in trucks for a few years and have undertaken extensive research into the perils that can befall the inebriated in a confined living space.) As boring as it sounds, we are both tee total. The angle looks worse in the pic than it actually is, there’s still a massive doorway so hopefully we’ll be fine! Worst case I can just run the circular saw down it and chop the extra off but I thought it’d at least make sense to try it so there’s a bit more work surface. Sunny Jim 1 Link to comment Share on other sites More sharing options...
JJ0063 Posted February 27 Author Share Posted February 27 Started cladding today, have run out so need to grab some more to do the bottom. Also started a splashback for the worktop, going to do the left hand panel which is grey at the moment. We are going to Crufts in 2 weeks time and will be staying in this so need to tidy it up, make the other seat box, make seat pads, fit a table. I’ve sourced a set of kitchen drawers for the gap where the toilet was but the chap isn’t having his kitchen removed for another 2 weeks so I won’t have it in time but at least it’s another thing sorted. Sunny Jim, DVee8, HarmonicCheeseburger and 5 others 8 Link to comment Share on other sites More sharing options...
JJ0063 Posted February 28 Author Share Posted February 28 Undercoat started. Need some new brushes to cut in. Popsicle, Dyslexic Viking, cobblers and 1 other 4 Link to comment Share on other sites More sharing options...
JJ0063 Posted February 28 Author Share Posted February 28 YOLO tom13 1 Link to comment Share on other sites More sharing options...
catsinthewelder Posted March 1 Share Posted March 1 On 2/25/2022 at 7:28 PM, JJ0063 said: I can be about no problem. I’ll PM my address shortly 👍 As boring as it sounds, we are both tee total. The angle looks worse in the pic than it actually is, there’s still a massive doorway so hopefully we’ll be fine! Worst case I can just run the circular saw down it and chop the extra off but I thought it’d at least make sense to try it so there’s a bit more work surface. We used to have a minibus version of this at work and the sliding door stops were further forward than the van version if that would be any use? I always preferred to use the front doors for late night entry and exits in my old camper but a 74 VW does have a spectacularly noisy sliding door. JJ0063 1 Link to comment Share on other sites More sharing options...
cobblers Posted March 1 Share Posted March 1 Defender wheels fit these if you fancy beefing it up in the rim department and making it much worse on fuel and noisier. JJ0063 1 Link to comment Share on other sites More sharing options...
JJ0063 Posted March 6 Author Share Posted March 6 On 3/1/2022 at 1:01 PM, cobblers said: Defender wheels fit these if you fancy beefing it up in the rim department and making it much worse on fuel and noisier. Sounds like a brilliant idea 😂 Link to comment Share on other sites More sharing options...
