Cobblers's VW T25 Syncro Doka - More shaft issues
cobblers
 Share
This was sold new in an area in Sweden where until recently at least they did not salt the roads in the winter. And the climate is dry inland climate so cars rust little there so this is a good buy! Østersund, Sveg and Strømsund are towns and villages where the dealer Berners had branches.
Link to comment
Thanks for this info! - I had presumed it must have been something along those lines as it has no right to be such a solid van for something that had been used for 260000km.
Link to comment
And have a little more for you. ångermanålvens vattenregleringsföretag was the first owner and gets it in translation to and become a water regulation company. And it was stationed i believe in Strømsund.
Hope you understand place names and such as I write as we Norwegians and Swedes have letters that are the same, but different in appearance.
Link to comment
Yes, they're getting quite silly now - seeing the way the values are going it was definitely a case of now or never. I sold my Caravelle GL a few years ago for (iirc) £3k. Similar vans are approaching 5 figures now.
When I started seeing them on album covers and stuff I realised that they were no longer the "only vw van I could afford" which is how I've always viewed them.
Link to comment
10 hours ago, HMC said:
Presumably this body design is more refined than a “normal” T25 as the passenger compartment is more isolated from the engine compartment, if you follow me.
The body design does lend itself to being a bit quieter than a panel van, but the tyre design puts paid to that! It's a noisy old bugger, and the syncro drivetrain does seem to transmit a bit more driveline whine into the cabin too.
These flat 4 engines are actually really smooth and even in a panel van, on idle you'd often be excused for not knowing it's running, and once you're moving it's quite a strange noise that I could only really compare to a large fan or something. It's actually really hard to judge the engine RPM while driving, to the point where I am making serious negotiations into buying a set of clocks with a revcounter, for a predictably extortionate price.
Link to comment
That's how I always saw the LT, and even they are creeping up. Although I was never specifically after a VW, just tempted by the sound of the engine! Seems like they're accepted as part of the T25 'scene' now as I always get a wave (rarely from Bays or Splits).
Link to comment
I went on some "off roads" today for a bit, and have got used to driving LHD stuff to the point where it only feels a little bit like I'm either having a stroke or in that episode of red dwarf where everything is backwards
The fox suspension does seem to be quite tolerant of leathering it through big potholes and whatnot.
Link to comment
I've never had a gripe with t25 brakes, they've always seemed plenty. IIRC the synchro brakes are even smaller than the normal ones for some reason, but it stops perfectly well. The tyres probably help if anything - they've got such a lot of rolling resistance that you barely need the brakes at all.
Link to comment
I thought I'd have the ECU apart on this (because that's my thing, I suppose) and make sure it's healthy, plus add an immobiliser.
It was a bit corroded on the end and had just the beginnings of water ingress:
1897837970_2021-08-1617_56_37.thumb.jpg.82bfca4a1a9cda174ff8b1da5a77e9d5.jpg324334260_2021-08-1617_55_40.thumb.jpg.9420428e1ea534e9e5f8e795410f1d50.jpg
Someone has been here before:
That's the transistor that drives the idle air control valve, if I remember correctly. I had to replace it on the last T25 I owned.
The aly casting was a bit grotty:
So I spent a few minutes in the media blaster and cleaned it up nice, before etc prime and some nice grey paint
No major horrors inside, a few minor dry joints and one very bad one:
I went over anything suspect looking,
and added a remote immobiliser
Not my neatest work, but it's very much a case of "Cobblers's kids shoes" when I spend all day making a real nice job on other peoples stuff (that they will never ever look inside) and then rush my own stuff because I've only got half an hour to get it finished.
Anyway the immobiliser just cuts power to the ECU internally after the ignition key has been off for more than about 20 seconds. A remote control button re-enables it.
Jobs a goodun:
Also I've been looking at truck bed cover things for this, so I can use it to go camping with some ease if it snows a lot ever again. There's just one for sale, it's £730, the pictures are shite, it's missing all the fitting hardware, the latches and hinges are fucked and it needs quite significant fibreglass repair and complete repaint
I'll give it a miss.
I'll see if I can measure up to find one off something else that'll fit.
Link to comment
  • cobblers changed the title to Cobblers's VW T25 Syncro Doka - More shaft issues
 Share
  • Similar Content
    • By Zelandeth
      So...we've got:
      1989 Saab 900i Automatic.
      1985 Sinclair C5.
      2009 Peugeot 107 Verve.
    • By Fumbler
      To mark the genesis of my fleet project thread I here present my new car: a 1997 Nissan Micra Shape-
      It really looks that good. There is a reason for this: its previous owner was an old lady who loved the thing so much so she made every effort to keep it in good shape. It originally came from Fleet in the GU postcode which suggests to me it was bought by the present dealer at auction, hence arriving down here in Kent. Before seeing the car I checked its MOT history and its only fails were thanks to broken stoplights, which shows me that it was very well cared for. I suppose an example of this was that on the last MOT, an advisory was a corroded rear silencer. The silencer on the car when I saw it was new. Methinks the lady wanted to keep it as good as possible. It was kept in a garage and so all the bumpers and black trim are very black and the tyres are in very good condition. Spare never used! Also included a free Dettol first aid kit from 1997.
      This car has 15000 genuine miles on the clock. We clocked over 15000 during the test drive! The lady owner really only trundled around her village in it and the MOT shows that it only did some meagre miles between tests. This, of course, came at a price. We saw a cherry red Micra from 2002 at the same dealer. Paint was shoddy and when they washed it the boot had massive sections of bare metal and it wasn't very happy. This car, however, is in fabulous condition and there was no contest between the two cars- it really is that good, inside and out. Immaculate interior, driver's airbag, cassette player... all there and all functioning (apart from cassette thanks to new battery and failed display). This meant that I bought it for £1600, £100 over what was my uppermost limit, but I knew I wouldn't see another like this that was in as good shape for a fair while. It was priced very ambitiously, at £1990, so I'm content in the fact I managed to slash a few hundred off the price. There wasn't that much paperwork though. All the dealership received was the logbook with 3 service stamps from 1998, 1999 and 2000, the radio key pass, a National Trust sticker, and the original paperwork holder. I suspect the old lady died and had her car auctioned, and the massive file of paperwork is now someone's egg carton, along will everything else she owned.
      As always, this car isn't exactly in showroom condition. While the inside is great and the floor is solid, and the underseal is in great shape, the not undersealed parts need a small looking at. Mainly the rear of the driver's side sill. It's really the only bubbling on the car. I suspect a well aimed stonechip managed to fester over the wintery salted roads, making it rust even more. It's around the size of a 5p piece, and will give me the opportunity to spray the insides of the sill with some chain oil to prevent any further corrosion. Behind the fuel tank there are a few rusty joints- places where the spraygun cannot get paint onto- which some Vactan and Dynax should put to rights. Alternator belt looks original because of the cracking and Nissan badges and will need doing soon as well as the front plate. As much as I like the 90's font and original dealer surround, the dishevelled R and general water ingress is a persistant MOT advisory. It could be the MOT station being strict (and most likely is considering there's a Saxo down the road with far worse blackening), however for the sake of peace of mind and all that, I'll get a new one made. The rear has already been replaced indicating this has happened before.
      All in all, I think this is a nice plucky motor. I'll have it by the end of the week; just got to sort out tax, insurance, and it's going to have an MOT. As part of the deal it's getting the MOT and an oil and filter change which will be something ticked off the list. It has some love scratches and chips here and there, but it drives well, is stiff and controllable, and should make out to be a nice summer project!
    • By BorniteIdentity
      This week, for the first time ever, I felt old. I have sciatica which swaps from one side to the other, arthritis in one hand and what I think is the beginnings of IBS. On top of that it took me 2 weeks to remember a registration number that once would take me 2 seconds, and I forgot my parent's wedding anniversary.
      I'm only 32.
      Shit. No I'm not. I'm 33. I forgot that too. (Genuinely)
      So, it's about time I committed some of my tales to paper. Well, a shonky server... but that's the best you can do in 2016.
      First up, a list of the cars I've owned (as best as I can remember) in chronological order.
      Main Cars
      1985 VW Polo Formel E. C158 TRT. This was given to me even before I passed my test.
      1991 Rover Metro S. J801 TAC. Bought about 3 months after I passed my test as I was convinced the Polo was about to shit its gearbox.
      1987 Volvo 360 GLT. D899 CBJ ___ Managed three months in a Metro before the small car and smaller petrol tank became a bore.
      Ford Mondeo and Honda Civic Coupe by Bornite Identity, on Flickr
      1999 Ford Mondeo Zetec. V384 DBJ. Still the most I've ever spent on a car. It was 3 years old and cost, from memory, about £8,000. Just think of the Rover R8s you could buy with that now!
      1987 Volkswagen Golf GTI 8v by Bornite Identity, on Flickr
      1987 Volkswagen Golf GTI D79 CVV. I very nearly bought a MK1 Golf 1.1 but was persuaded, by my father amusingly, to buy this one from a different friend. From memory I gave about £500 for it, and sold it to some racers later that year for about £300. Amusingly, 16 year later I'd sell the Hartge wheels that came with the car for £530.
      1999 Toyota Avensis CDX by Bornite Identity, on Flickr
      1999 Toyota Avensis CDX. V781 GDP. By far the best car I've ever had. Bought in 2002 for £5300, it had previously been a company car at British Telecom. I ran it from 62,000 to 174,000 before it became surplus to requirements. A German chap bought it on ebay for about £500 and drove over to collect it. Hero.
      2001 Ford Mondeo Zetec by Bornite Identity, on Flickr
      2001 Ford Mondeo Zetec. Y821 EEB. I should have loved this car. I gave £500 for it in 2008 which was stupidly cheap by anybody's standards. It needed 4 tyres (which actually was nice to pick good ones for once) and a coil spring. Sadly, it was just bill after bill after bill. I sold it and promised to never own another Ford. I nearly succeeded.
      1998 Nissan Almera by Bornite Identity, on Flickr
      1998 Nissan Almera GX Auto. S58 NLO. My late Grandfather's car and, upon reflection, my first proper attempt at bangernomics. I bought it for £500 in 2008 from the estate and ran it for well over a year and 30,000 miles. It was also my first automatic which, whilst a bit dumb, did lock up into overdrive and give a good 36 mpg no matter how it was driven.
      2004 Ford Fiesta 1.25 LX and 2006 Ford Focus 2.0 Ghia by Bornite Identity, on Flickr
      2004 Ford Fiesta Zetec. AG53 BWL. My wife's car which I ran for a couple of years when I bought her a Focus as a wedding gift.
      2003 Rover 75 by Bornite Identity, on Flickr
      2003 Rover 75 Club SE. AX53 BFA. This is where my career as a serial car buyer really began. Ignoring all of the warning signs I decided to press a K Series into a daily 100 mile commute, which it did with aplomb. This wasn't actually the car I set out to buy, the one I'd agreed to buy OVERHEATED ON THE FORECOURT whilst I was doing the paperwork. Consequently I couldn't leave fast enough and bought a different car later that day.
      2004 Toyota Avensis T30-X by Bornite Identity, on Flickr
      2004 Toyota Avensis T3-X. KT53 DWZ. Sensible head back on, I decided to get back into something I trusted when my 3rd son was born. This was a lovely car, but not without its problems. The VVTi oil burning issues are well documented and do frequently occur. Ironically, this was less reliable than the Rover it replaced! Despite fearing the worst and 3 months off the road, the new owner has just MOTd it.
      1999 Toyota Avensis SR by Bornite Identity, on Flickr
      1999 Toyota Avensis SR. V263 GDP. Back into bangernomics territory again. The last MK1 Avensis I had was the best car I'd ever had, so I hoped to replicate it with another T22 Avensis. This one came up for sale in my favourite (and rare) colour with a numberplate sequential to my previous car - so it was meant to be. I still have this now, and tomorrow it will tick around to 185,000 miles having been bought by me at 100,500.
      Side Bitches
      1974 Morris Mini 1000 by Bornite Identity, on Flickr
      1974 Morris Mini 1000. GEL 517N. Well, I always wanted one - and was young, free, single and well off at the time (2003). A memorable trip to buy it when I called my new girlfriend by my ex girlfriend's name 20 miles into a 200 mile weekend away. She's never forgiven or forgotten but we're still friends. Oh - and married.
      1977 Ford Capri II GL by Bornite Identity, on Flickr
      1977 Ford Capri II 1600 GL. SMY 675R. I can't remember why I bought this, other than I thought it'd be amusing. It was bought from Norwich for £350 and was perfectly well behaved for the 8 months that I had it (other than a flasher unit expiring). I remember being shocked just how much the windscreen would ice up inside, and duly sold it in November to a guy who was going to drive it daily! It's still alive and now, apparently, black! (Update - it's now silver!!!)
      1989 Volvo 340 DL by Bornite Identity, on Flickr
      1989 Volvo 340 DL. G67 AVN. I bought this for £80. Unbelievable. It was utterly bloody perfect. I wanted to do a banger rally which is why the guy gave it to me so cheap. I'm still yet to do that rally, but no longer have the car. I sold it for about £300 to a family who were clearly down on their luck who, I hope, still have the car.
      1996 Toyota Granvia by Bornite Identity, on Flickr
      1996 Toyota Granvia. N775 JEV. My wife and I decided to increase our numbers further and, with our 4th son on the way, larger transport was required. We quickly realised you can either have 4 children and no apparel, or apparel and no children. After trying a very tired Mercedes Viano, the Granvia was found for 1/4 of the price and it's still here 2 years later. I can safely say that we'll never sell it - it really is another member of the family.
      1993 Mercedes 190e by Bornite Identity, on Flickr
      1993 Mercedes 190e. L795 COJ. I've admired these cars since I was a child. In fact, one of the very few toy cars I still have from my childhood is a Mercedes 190e. Regular readers of "Memoirs from the Hard Shoulder" will know what a PITA this car has been since day 1, but I get the feeling it's a keeper. We'll see!
      1983 Ford Sierra Base 1.6 by Bornite Identity, on Flickr
      1983 Ford Sierra Base. GVG 510Y. Not explicitly my car, but it should be documented here for reference. Oh - and the V5 is in my name. The story is online for all to read as to how five of us acquired what is believed to be the only remaining Ford Sierra Base. Make a brew and read it, it's a fantastic story.
      1982 Ford Sierra L by Bornite Identity, on Flickr
      1982 Ford Sierra L. LCR 503Y. I accidentally won this on ebay for £520. Upon reflection, I shouldn't have sold it - but short stop of saying I regret it. I could never get truly comfortable driving it and, in fairness, I could scratch my Sierra itch with the base if I wanted. Sold it at a stupid profit of £1250. It is believed to be the oldest remaining Ford Sierra in the UK.
      1979 Volvo 343 DL by Bornite Identity, on Flickr
      1979 Volvo 343 DL. DBY 466T As you'll see above, I'd had a 360GLT as a younger lad and fancied one of these earlier cars. The variomatic is, frankly, terrible but amusing. This car has just 8000 miles on the clock and inside was absolutely timewarp. Sadly, the huge bill for the Mercedes 190e cylinder head rebuild meant I had to sell this car shortly after acquiring it. Since then I've had a bit of money luck, and now realise I didn't need to sell it after all. Typical.
      I think that's it. My arthritis is playing up even more now. I've left out a few cars that were actually my wife's, but if I find pictures will add them in at a later date. I'll run this as an ongoing thread on cars and what's happening.
      Current SitRep:
      Purple Avensis: Just about to click over 185,000. Minor drama this week when an HT lead split but otherwise utterly fantastic, fantastically boring and boringly reliable.
      Granvia: Just done 1000 miles in a month around Norfolk, 6 up with suitcases. 31mpg achieved on the way up which is good for an old tub with a 3.0 Turbo Diesel on board. ODO displaying 175,000 which is a mix of miles and kilometers. Say 130,000 miles for argument's sake.
      Mercedes: Being a PITA. It's had the top end completely rebuilt after the chain came off. Now needs welding to pass another MOT and the gearbox bearings are on strike. It's about to go into the garage for winter until I can stomach it again. 151,000 miles on the clock.
      Sierra bASe: Still on sabbatical with AngryDicky who only took it bloody camping in cornwall! Legend.
    • By rickvw72
      Hi all, I’m going to try to keep this updated as a diary of work done on my old Fourtrak.
      I bought this a few years ago but have only recently got going on it properly, with several other projects on the go, times been scarce.
      Ill start with the main job, the rear crossmember. When I bought the truck this tube had snapped on the drivers side. This ruptured the brake pipes, and ruined all the already tired suspension bushes.
      So, out with the crossmember...
      The original is round tube, the new 3mm wall box section, it actually holds the anti tramp bars.
      Yes the Fourtrak has a 5 linked rear suspension, and an LSD. Because race car!
      I didn’t take many pics at this time, so I’m trying to improve this and maybe a thread will motivate me to document it.
    • By Shirley Knott
      Greetings all.
      After lurking here for a short while, frankly liking what I see and enjoying the various shite, the site has well and truly struck a chord with me. I'm a serial buyer of ropey sub £1k vehicles, don't have to but genuinely enjoy it.
      I feel like I might (Just might) have found my 'spiritual' home here
      I've been posting across the web on owner specific forums (Usually using either my JoeyEunos or RandomPrecion handles) for a while now, but from here-on-in I will pull my threads together and merge them here into one ghastly topic.
      My current steeds...
      Lupo 1.7 SDI
      SAM_5560 by
      and the work/story so far...http://forums.clublupo.co.uk/index.php?/topic/102863-joeyeunoss-sdi-beater/
      Golf Mk4 SDI
      SAM_5531 by
      and the thread.... http://uk-mkivs.net/topic/597074-project-slow/
      Early (1989) Mk1 Eunos (This one was recently sold)
      SAM_4656 by
      the thread...http://www.mx5nutz.com/forum/index.php?showtopic=213274
      Other shite I've owned and moved on in the last year include this ropey Passat...
      SAM_6011 by
      and this legendary £300 Fiesta Finesse...
      Festa by
      Cars I'd like to own/actively looking for in the forthcoming weeks/months/years...
      Rover 75 (Dizzler)
      Peugeot 405 (XUD)
      Mk1 Octavia (Estate/dizzler, pre pd or SDI)
      Honda CRV (Gen1)
      Volvo 240/850
