Cobblers's VW T25 Syncro Doka and other 4WD VW transporters - MEDIC
cobblers
 Share
4 hours ago, cobblers said:
Diesel heaters are just ace.
Can I just ask you an Afterburner question - to operate it using my phone when I'm out and about, I think I have to put the wifi into station mode, connect it to a mobile hotspot with a second phone, then access it over the internet that way. I've done this sort of thing with a home router and port forwarding, so guessing it should be similarly straightforward, but I wondered whether I had to use MQTT (which I know nothing about!)
Link to comment
MQTT is 9000 times easier than port forwarding, but like anything else on the afterburner, the documentation makes it seem harder than it is.
I seem to recall I followed a youtube video telling you how to get it to work, and it was all sorted in minutes. Roughly you go to the http://afterburner.mrjones.id.au/mqtt.html webpage and put in the ID of your afterburner and "broker.hivemq.com" then bookmark the page and now you have a webpage which controls your heater from any device on the internet, so long as the heater has some way of accessing the net (even if it's via port blocked mobile routers etc)
heres mine, I'm at home and my camper is 30 miles away at work with the afterburner connected to either the 4g router or the wifi at work depending on how close I parked to my unit.
If it gets to 2.5c the heater will turn on in frost mode and warm the whole van up to 15c (I used to have it stop at 6c but then it would do three cycles a night, it's better off just getting it nice and warm and not coming on for the day)
Link to comment
That's what's been putting me off! Cheers for that, must admit there've been a few times when it'd be great to come back to a nice warm van. Probably most of them outside any kind of mobile signal, but still...
Link to comment
Quite curious about these diesel heaters.. are they a bit "all or nothing" ie do you get you van hot with them and then rely on insulation rather than keeping them ticking over all night? How much electricity do they consume? I guess the glow plug draws a fair bit?
Link to comment
As standard, they will tick over on minimum output all night, but with any remotely well-insulated van, the temperature will keep on rising. The Afterburner controller mentioned above will turn off the heater if this happens, and back on again if the temperature drops. Glow plug draws something like 10 amps for maybe 30 seconds, under 1 amp continuous on low.
Link to comment
What he said /\
They are roughly 700-1000w on their lowest setting, which can be too much for small vans overnight unless it's absolutely freezing. You can crack the windows open a little which is a bit of a waste of fuel, but helps dry the van out etc.
I like to sleep with the van pretty cold (13c) so In my big moderately insulated peugeot boxer I only really run the heater overnight when it's freezing or very close to, and I leave the roof vent open just a touch.
When I'm up and plodding around in the van, I set it to 22c and it has no problem keeping that maintained accurately. The coldest I've camped is -7c for 3 days and the heater spent most of the  time on about 50-75% power. The warmest I'll run the heater permanently on is about 10c outside.
The main power draw and noise is starting and stopping them, so you're better off wasting heat out of the window in order to keep it ticking over on low.
Link to comment
  • cobblers changed the title to Cobblers's VW T25 Syncro Doka
Rotated the tens 90 degrees so it opened onto the bed at the back. Much better this way round, it makes putting it up and taking it down quicker, and I can tie the guylines into the load anchors on the back of the van, so it's all secure.
Takes 7 minutes to put up, 9 minutes to take down which is quite reasonable.
I'm pretty pleased with it. They do an annex that zips on underneath, but it's 2.1m high, I'd only need the top half of it but it would make a nice enclosed area to put my boots in, a couple of camp chairs and do the cooking.
Might give it a try tonight if I can find my thick sleeping bag!
Link to comment
  • 1 month later...
After driving for about ten miles with the handbrake on, my back brakes were totally shafted. Finally had a bit of time today to get em sorted. Quite a war getting the drums off, there is nothing to get hold of to pull them so I sent a tap in and wound them off. Worked well!
Drums were mint and have zero lip, but the shoes were very cooked.
Did the fronts while I was at it.
Can't believe how much better the pedal is, it's like a different van. I've even put a new bulb in the handbrake warning light so I don't do it again.
I've had an intermittent high idle, so I went round looking for air leaks.
Look at this fucking mess!
Those vacuum pipes have been on there for two months! Supposedly din fuel hose! 20220402_155605.thumb.jpg.7bf80255636f4c0239ce2b6095b3811a.jpg
What a bag of shit, I'm going to give the seller a right gobfull.
At last I've come away camping in it. Dropped on really well with the camp spot - I'm on a farm and the guy usually has one small field for campers, but since he's got no cows on at the moment he said I could go wherever the hell I wanted. So I went through the ford.
It's only about 18 inch deep if that. And here we are :
Views not bad either
I've got my long johns for tonight, it'll be minus two apparently.
Link to comment
It always surprises me how small the brakes on the T25 and LT are compared to the Mercedes T1.
Great to see the van being used properly though.  Really hope we get out with ours this year.  I do need to get to the bottom of why she's down on power though.
Link to comment
Just been catching up on a years worth of this thread. That is one awesome vehicle right there, and to see it fully roof tented up and camped in is excellent too!
Link to comment
Yes, it was quite a cold one! My "definitely safe" chinese gas heater made my eyes sting and the condensation made everything wet, so I sacked that off. I won't be using it again.
Had the best nights sleep I've had in about a decade.
Have you ever smelled a video? Well you'll be able to smell this one. Fantastic!
Link to comment
16 hours ago, cobblers said:
Much better design than my early air cooled T25, the brake disc doubles as part of the hub and has the wheel bearing in it! Makes changing the discs much more involved! 🙄
looks like you’re taking good care of this one, nice work.
Link to comment
All the 2wd T25s are like that as far as I'm aware, this has a different front hub setup because of the driveshaft etc.
I was worried brake parts would be tricky to get for a syncro, but they were all on the shelf at brickwerks. I can't really knock that place, they are priced reasonably and have good stuff in stock.
Apparently there's a load of brake upgrades available that bolt on (both front and rear) so while I was tempted, it stops fine really and many of these upgrades would need bigger wheels.
Link to comment
I use brickwerks too, also use campervanculture.com they do loads of OE quality westfalia parts, but specialise in syncros and off grid camping stuff, really good service too.
Link to comment
1 minute ago, mat_the_cat said:
Another vote for Brickwerks too, who are happily doing more and more LT parts. You can actually email them and get a prompt reply too, which is always welcome.
A lot of people are very upset that you can't ring them, but I 100% support them on this emails only thing. I'm trying my best to steer my business this way. The constant phone call interruptions cost me at least a few hours of productive work every day, whereas if it was all emails I could just schedule a couple of email sessions and get them all done in half an hour.
Link to comment
Makes total sense to me too. The time lost by switching focus to the call, or other interruption, and then getting your mind back to where it was before is far greater than most people seem to think. I've tried to encourage people to phone only if it's urgent, and then reply to my emails at the end of every working day when I could allocate time efficiently.
Link to comment
Glow  plugs surely only needed on start up, and within a few seconds the generator will surely have recharged the battery ?
Link to comment
The heater has its own glow plug to ignite the diesel, so it's more efficient electrically to leave the low consumption blower fan running continuously, than it is to regularly keep turning it on and using the glow plug.
Link to comment
  • cobblers changed the title to Cobblers's VW T25 Syncro Doka and other 4WD VW transporters
15 minutes ago, garbaldy said:
Nice thread which I will keep looking in on now, are panels easily available?
This was First spot in the flesh and it wasn't exactly as clean as described.
nowt better than a well used old van. Most panels are available, but a lot are klokkerholm garbage that seem to have been designed using google earth!
Link to comment
  • cobblers changed the title to Cobblers's VW T25 Syncro Doka and other 4WD VW transporters - MEDIC
 Share
  • Similar Content
    • By Zelandeth
      So...we've got:
      1989 Saab 900i Automatic.
      1985 Sinclair C5.
      2009 Peugeot 107 Verve.
    • By Tommyboy12
      What do you get after 16 hours and 800 miles of driving on a Sunday to collect two cars? Well @sharley17194 picks up a 1997 Citreon AX from the depths of the Lakes on the North West coast past Keswick. However, we actually started the day by driving to just near Cromer on the East coast to pick up this!
      An Austin Montego poverty spec estate with a 1.3L A-series engine! Yes you did read that bit right! Yes I know the DVLA lists the model as 1.6... Yes its correctly registered as 1.3L. No I dont know if its a factory 1.3L! 😂
      My favourite part of all this??? (Apart from the doom blue colour and the absolutely terrible interior!) 281,000 miles on the clock!
      Collection went really well and the below posts follows my initial assessment of what is quite frankly the best car I have ever purchased.
    • By dome
      This evening I venture forth into hitherto unknown lands (Kirkintilloch) to collect my latest acquisition.
      Which, naturally, has issues.
      I have purchased my first line of defence.
      Which appears to have antigravity properties
      More will follow this evening...
    • By captain_70s
      Hullo,
      I'm a masochist from Leeds who is running two rusty, worn out Triumph Dolomites as my only transport in rural Aberdeenshire. You might recognise me from various other forums and Facebook groups. Realistically I need to buy a modern car of some sort, but instead I find myself looking at £300 Citroen BXs and Triumph Acclaims on Gumtree and thinking "yeah, that'd fit right in with the rest of the broken cars I can't afford".
      On to the cars, the main attraction being my 1976 1850HL "50 Shades of Yellow" that I bought for £850 and is currently my daily driver, here is a picture of it before I sanded off some surface rust and sprayed it badly in the wrong shade of yellow with rattle cans:
      Within a month of purchase I managed to plant it in to a steel fence backwards after a botched gear change on a wet roundabout and ruined the N/S rear wing, although judging by the other dent that's packed with filler it looks like somebody had already done the same. I also managed to destroy a halfshaft and one of my Sprint alloys (good for an extra 15hp) in the incident, so now it's sitting on it's original steelies but painted black (good for an extra 5hp).
      It's only broken down on me twice. once with some sort of fuel delivery related problem which may or may not have been an empty fuel tank and once when the thermostat jammed shut and it overheated and blew out some O-rings for the cooling system. It has recently developed a taste for coolant and oil which is rather annoying, although it's done 89,300 miles which is about 80,000 more miles than BL engineering is designed to last, I'm keeping my eye on eBay for replacement engines...
      I tried to keep ahead of the rust a bit by rubbing down the arches and re-painting them, but apparently rattle can paint isn't great when you are spraying it at -5C, it also highlighted how although my car might have been Inca Yellow in 1976 it's now more of a "cat piss" sort of shade. So I ended up with the wrong shade of yellow which has rust coming back through after 5 weeks. Did I mention I'm incompetent?
      The other car is the first "classic" car I bought, so I can't bear to sell it. It's a '77 Dolomite 1300 and it cost £1400 (about £400 too much) and has been nothing but a pain in the arse:
      It looks much prettier (from 100 yards) but that's most due to the darker paintwork hiding the rust. It lives a mollycoddled life in my garage, where it somehow still manages to rust, and is utterly rubbish. 0-60 is measured on a calendar, top speed is 80ish but at that point it uses more oil than petrol, it rarely ventures over 50mph and if you encounter an incline of any sort you can kiss that sort of speed goodbye, along with about £20 of 20W50 as it vanishes out of the exhaust in the form of blue smoke.
      One of the PO's had clearly never heard of the term "oil change" so it developed into brown sludge that coated everything internally with the next owner(s) blissfully pouring fresh oil on top of it. This lasted until about 600 miles into my ownership when there was muffled "pop" from the engine bay and the car became a 3-cylinder. The cause was catastrophic wear to the top end causing a rocker arm to snap:
      As this was my first classic car I'd assumed it was supposed to sound like the engine was full of marbles, it wasn't.
      I put the engine back together with second hand bits declared it utterly fucked and promptly did another 5000 miles with it. After about 3500 of those miles the oil burning started, valve seals have gone so it's been relegated to my parent's garage as a backup car and something to take to local car shows as the 1850 is now embarrassingly ugly. I'm keeping my eye on eBay for replacement engines (deja vu, anybody?) Oh, I also recently reversed it into a parked Ford Fiesta and royally fucked up the rear bumper, rear panel and bootlid. Did I mention I'm incompetent?
      There have been two other cars in my life. My first car, a 2008 Toyota Yaris 1.0 an it's replacement a 2012 Corsa 1.4T. I didn't really want either of them, but it's a long story involving my parents and poor life choices. Ask if you want to hear it!
      So that's a brief summary of my current shite. If you want more pictures or details of anything do say as I've got photos of almost everything I'd done with the cars.
    • By Tickman
      First some background:
      I was brought up with no car interest, a car was transport and nothing more which resulted in a selection of poor cheap cars being the cars of my youth.
      Fast forward many years (just over 9 years ago) and I have a wonderful* Vauxhall Vectra estate to carry us about. Unfortunately it is crap and throws fault codes at us with nothing being there when it is checked (even at Vauxhall)
      As Mrs T is the main pilot of this chariot with the two little miss T's on board, it has to go.
      The hunt is on for the new steed to safely and comfortably carry the family around. I have a company car at the time so big journeys are not an issue.
      ebay is my weapon of choice to find the new family car. It has to be good value cheap for no other reason than I am tight.
      Weeks of research with lots of cars that are too expensive and too far away for easy collection end up in my watch list.
      Finally a possible is spotted in Fife. I go and have a look and find a poor looking but solid car. One previous owner and lots of history.
      The auction was to end on the Saturday at midday, we were going to be out! I decided on how much I was willing to gamble on it and on the Saturday morning I put in my max bid but straight away it went to my max bid, I was winning but it had three hours to go with no room for me to go up! We went out anyway.
      I spent the next three hours kicking myself for not bidding more while we were out as it was the first car I had seen that fitted my criteria. Fate was in charge.
      On returning home I go straight on ebay to find 'Congratulations.............'
      For the grand total of £500 I had just won this fine vehicle!
      It has 5 months MOT and after fitting seat belts in the rear for the girls car seats it is pushed into daily service.
      My gamble and subsequent use results in a perfectly reliable car that actually does what it is supposed to do.
      Even more importantly Mrs T loves it so a win all round.
      All my cars have names (most are earned over a bit of time) and this one is called 'Gwendolen' ( G reg car and from Wales originally. I hate the name but I am not going to argue)
      That sums up part one, more will be along later (probably much later)
