Cobblers's VW T25 Syncro Doka and other 4WD VW transporters - MEDIC
cobblers
 Share
There's a guy selling the whole pvc /canvas back end cover kit and kaboodle reporduction brand new but it's well over a grand! I need to put some more miles on this MOFO before spending that kind of money on it, just to see what other massive bills it throws at me!
EG It's dripping coolant off the engine block at the moment, which isn't ideal but I used it to knock a few grand off the price on account of there being a fairly real chance of it needing the heads off, which involves snapping the studs and basically just sending the engine off for a rebuild.
Link to comment
Plates came, they are very good. I put the front one in the middle, and also took the "112i" badge off because I didn't like the look of it.
I went for my weekly mooch round various areas we want to move to, on the complete off chance that there's a "for sale" or "to let" sign outside a house. No luck as usual, but I took the van "OFF ROAD" on a little green lane. Didn't take the piss because I was on my own and would be well in the shit if I got stuck.
The diff lock works, thankfully!
The suspension is pretty great TBH, you can beast it through big massive ruts and it doesn't feel like you're going to snap owt.
One casualty from my trip:
Bastards! I noticed a clicking when I was out there, but daren't pull it out til I got home. It's a good job too because it pissed air out.
And that's how we leave it today, on a bottle jack with the wheel in the back of my Caddy.
I absolutely love this van and have just ordered a few hundred quid of service bits and whatnot.
Link to comment
I decided I wanted a revcounter, and this is what many many hundreds of pounds worth of "VW T25 revcounter" looks like nowadays. Described as "Good condition for age". These clocks alone cost more than my first entire T25
1603896785_2021-08-2412_26_05.thumb.jpg.3190e0b18a6178a8609563fd6be3b44b.jpg731706902_2021-08-2412_26_09.thumb.jpg.b3547bb14a1b690b2567c4cccac505a3.jpg
Now I repair this sort of shit for a living, but these are pretty fucked by absolutely any metric. Yes, they're par for the course and a lot of clocks are about this bad, but by no stretch could you call them "good condition".
The seller reckoned only the temp gauge doesn't work (ironically this is a dead easy fix - just because of the missing nut in the last picture) but the oil pressure warning and backlighting are also fucked, and the main connector housing is missing so it'll just fall off continuously.
I'm going to give the seller some grief over them and try and get some money back because they're falling to pieces and missing parts. I don't want to send them back because there are literally no others available anywhere.
Link to comment
45 minutes ago, Asimo said:
PS. Loose the pineapple-spotlight roof bar thing?
The spotlights don't have wires or bulbs in them so they're going to at least be replaced.
I will probably keep the roof rack to sling my spare tyre on, on account of there being a diff and some driveshafts in the way of where one would normally go.
Link to comment
I made the best out of a few sets of clocks, and set about fitting them to the van.
It was so filthy inside that everything I took off needed cleaning, so a quick wipe round the dash turned into a full on seats and cab mat out jet wash fest.
The cab mat took four passes of neat TFR, stuff scrubbing brush and hot water jet wash to get it clean.
Most of the day, three cans of interior shampoo and half a litre of Autoglym vinyl and rubber care later:
It's a much nicer place to be. The seats would still benefit from a wet vac, but it's worlds better than it was.
I also snowfoamed the minging engine bay, and put a new fanbelt and a few pipes on
Here's a quick picture I got someone else to take  to check the revcounter calibration:
it's running about 10% too high, which is pretty good considering it was running 110% too high to start with, and I had just tweaked the adjustment pot by ear. According to calculations, 50MPH indicated should be 2700RPM. However with these tyres, 50mph on the speedo is about 57mph actual.
Link to comment
Steering wheel arrived, from a B2 passat. It's very very similar to a proper VW Caravelle PAS wheel, but at 20% of the price.  And now my disklok fits!
Unfortunately the rubber at the top has gone "bendy" and come away from the frame. Has anyone had success injecting some glue in to bond it back on? It's not terrible but I'd like to improve it.
Link to comment
1 hour ago, cobblers said:
It's "gelande" which is german for terrain which I reckon is like "off road" mode, basically its a mega low gear for crawling about to save you slipping the clutch. Like a low range sort of thing. It feels about 60% of first gear and it seems to go over absolutely anything at just a slight tickle of throttle
Hence the G in G-wagon.
Link to comment
The same thing happened to my Scirocco and as an interim 'fix', I've just fitted an old style vinyl steering wheel glove.
Link to comment
Have you had your broken instrument cluster apart completely?
Random question because if it has the blue main beam indicator I'd be really curious to see whether it's an LED or incandescent lamp just with a filter.
VW used very, very early silicon carbide based LEDs on a handful of models - the only place out in the real world I've ever heard of them actually being used.
Obviously as a bit of a lighting geek they're something that I've been looking for forever!
Link to comment
has it actually ever been verified that VW did indeed use Silcon Carbide blue LED's anywhere
or is it just one of those rumours floating around that no ones actually been able to verify like the top speed of a Model 70 LOL
because as im sure you know those Early blue LED's where stupidly expensive at several pounds for a single one
so id be quite surprised if Volkswagen used them given their immense cost, but I am very curious to know myself for the same reasons! :)
as like you I have also heard about it, but I dont think iv personally seen it verified yet
but back on topic sorry! LOL the Van is very cool I look forward to seeing how you continue get on with it :)
its pretty cool to see a Non camper one and one that is 4x4/AWD at that too, looks quite badass/serious :)
Link to comment
That's what I found too, when dismantling the clocks in a scrapyard in the late 90s, purely to try and obtain a blue LED for less than the £8 that RS wanted. Had I ever found one, I suspect the breakers yard would be mightily pissed off with me for ruining a set of clocks for just one LED! I wonder if any did have the elusive LED...
Link to comment
Mr Cobblers,
I have a 1986 Scirocco and 11 years ago, I fitted it with a diesel mill.  Relatively straightforward but I’ve been 11 years without a rev counter.
I understand the diesel rev counter takes its signal from the W terminal on the alternator.  I’ve run a wire from there into the dash but at this stage, my skills are found wanting!
Could I employ your services to right this wrong?!
Please help!
Link to comment
12 hours ago, cobblers said:
@Coprolalia has done the same and is sending me his petrol clocks to tweak to diesel spec - a few resistors need changing to calibrate it to read from the W terminal output instead of an ignition coil negative.
I’ll try and get the clocks out and post them to you over the winter!
Thanks for the help!
Link to comment
  • 1 month later...
I had horrific CV joint noise that had very rapidly got worse, the PO mentioned something about fitting a new shaft recently but because it's lifted, the stock shafts struggle and aftermarket ones are shite to start with.
I bought some porsche 944 CV joints which for some reason are a direct fit, and also allow a lot more articulation.
This driveshaft has a 2018 date code on it, and the van has done about 1000 miles since then:
What crap! That said most of the damage is because it's twisted too far.
The porsche joints are a bit wider, proper OE german made and will hopefully last more than 1000 miles.
Drives a lot better for it!
Link to comment
Well this morning the rear heater matrix chose the one time I have ever sat in the back of the van to explode and fire a gallon of hot coolant all over my legs and feet. Not too bad I suppose, I was parked outside work so it couldn't really have been in  a better place, and I was wrapped up with thick trousers and boots on so I wasn't injured.
I presumed parts would be unobtanium and expected to have to blank the heater off, but a new OE matrix and valve were £60, so I'll replace it. It does come in handy for an extra bit of heat on really cold days.
The failure was obvious:
Link to comment
A guy on another forum got me a bit worried about the matrix popping, that the coolant system could be pressurising up, I checked it all and the pressure cap works fine and hadn't let anything off, but I was still a bit worried.
The new matrix came and it fitted easy and bled up without issue. I've borrowed the tyres off my work van for this for now, and I took it for a good 60 mile run in all conditions and at high loads to get the cylinder pressures up. Thankfully it seems absolutely fine.
Found this lovely road about two miles from my house - I think I'll be here regularly:
Bumped into two groups of walkers and they were both incredibly pleasant, which was a nice surprise after my last encounter where I thought someone was going to try and do a citizens arrest  😅
Link to comment
Sweet! Not sure how I missed this thread originally, think I was away.
One of these has been on my radar for a while but I don't suppose I will ever get the chance unless I sell something else first. Such a cool vehicle and probably one of the most capable 4x4 vans around without spending insane money even now.
Let me know if you fancy some lanes around Derbyshire way sometime :)
Link to comment
After the debacle with the exploding heater matrix, I thought I best go over the cooling system a bit and make sure it wasn't pressurising up etc, so I gave it a good hard run and then left it idling outside work for 45 minutes with the fan cycling, it seemed fine however as I was nosying round the back end I noticed a crack in the header tank:
They all do that sir etc, but I've had one of these explode on me before while stood just next to it, so I was very keen to get away from it!
While sat watching the engine ticking over, I noticed a slight "chuff" noise and one of the HT leads seemed to be rattling. Sure enough, one of the spark plugs was finger tight.
I treat it to some new boujie genuine VW spark plugs and a not so boujie non-genuine header tank. I've also got a radiator to fit, because the threaded bleed nipple on the existing one is siezed.
WBX 4 LYFE BRO!
Link to comment
  • cobblers changed the title to Cobblers's VW T25 Syncro Doka and other 4WD VW transporters - MEDIC
 Share
  • Similar Content
    • By Zelandeth
      So...we've got:
      1989 Saab 900i Automatic.
      1985 Sinclair C5.
      2009 Peugeot 107 Verve.
    • By Tommyboy12
      What do you get after 16 hours and 800 miles of driving on a Sunday to collect two cars? Well @sharley17194 picks up a 1997 Citreon AX from the depths of the Lakes on the North West coast past Keswick. However, we actually started the day by driving to just near Cromer on the East coast to pick up this!
      An Austin Montego poverty spec estate with a 1.3L A-series engine! Yes you did read that bit right! Yes I know the DVLA lists the model as 1.6... Yes its correctly registered as 1.3L. No I dont know if its a factory 1.3L! 😂
      My favourite part of all this??? (Apart from the doom blue colour and the absolutely terrible interior!) 281,000 miles on the clock!
      Collection went really well and the below posts follows my initial assessment of what is quite frankly the best car I have ever purchased.
    • By dome
      This evening I venture forth into hitherto unknown lands (Kirkintilloch) to collect my latest acquisition.
      Which, naturally, has issues.
      I have purchased my first line of defence.
      Which appears to have antigravity properties
      More will follow this evening...
    • By captain_70s
      Hullo,
      I'm a masochist from Leeds who is running two rusty, worn out Triumph Dolomites as my only transport in rural Aberdeenshire. You might recognise me from various other forums and Facebook groups. Realistically I need to buy a modern car of some sort, but instead I find myself looking at £300 Citroen BXs and Triumph Acclaims on Gumtree and thinking "yeah, that'd fit right in with the rest of the broken cars I can't afford".
      On to the cars, the main attraction being my 1976 1850HL "50 Shades of Yellow" that I bought for £850 and is currently my daily driver, here is a picture of it before I sanded off some surface rust and sprayed it badly in the wrong shade of yellow with rattle cans:
      Within a month of purchase I managed to plant it in to a steel fence backwards after a botched gear change on a wet roundabout and ruined the N/S rear wing, although judging by the other dent that's packed with filler it looks like somebody had already done the same. I also managed to destroy a halfshaft and one of my Sprint alloys (good for an extra 15hp) in the incident, so now it's sitting on it's original steelies but painted black (good for an extra 5hp).
      It's only broken down on me twice. once with some sort of fuel delivery related problem which may or may not have been an empty fuel tank and once when the thermostat jammed shut and it overheated and blew out some O-rings for the cooling system. It has recently developed a taste for coolant and oil which is rather annoying, although it's done 89,300 miles which is about 80,000 more miles than BL engineering is designed to last, I'm keeping my eye on eBay for replacement engines...
      I tried to keep ahead of the rust a bit by rubbing down the arches and re-painting them, but apparently rattle can paint isn't great when you are spraying it at -5C, it also highlighted how although my car might have been Inca Yellow in 1976 it's now more of a "cat piss" sort of shade. So I ended up with the wrong shade of yellow which has rust coming back through after 5 weeks. Did I mention I'm incompetent?
      The other car is the first "classic" car I bought, so I can't bear to sell it. It's a '77 Dolomite 1300 and it cost £1400 (about £400 too much) and has been nothing but a pain in the arse:
      It looks much prettier (from 100 yards) but that's most due to the darker paintwork hiding the rust. It lives a mollycoddled life in my garage, where it somehow still manages to rust, and is utterly rubbish. 0-60 is measured on a calendar, top speed is 80ish but at that point it uses more oil than petrol, it rarely ventures over 50mph and if you encounter an incline of any sort you can kiss that sort of speed goodbye, along with about £20 of 20W50 as it vanishes out of the exhaust in the form of blue smoke.
      One of the PO's had clearly never heard of the term "oil change" so it developed into brown sludge that coated everything internally with the next owner(s) blissfully pouring fresh oil on top of it. This lasted until about 600 miles into my ownership when there was muffled "pop" from the engine bay and the car became a 3-cylinder. The cause was catastrophic wear to the top end causing a rocker arm to snap:
      As this was my first classic car I'd assumed it was supposed to sound like the engine was full of marbles, it wasn't.
      I put the engine back together with second hand bits declared it utterly fucked and promptly did another 5000 miles with it. After about 3500 of those miles the oil burning started, valve seals have gone so it's been relegated to my parent's garage as a backup car and something to take to local car shows as the 1850 is now embarrassingly ugly. I'm keeping my eye on eBay for replacement engines (deja vu, anybody?) Oh, I also recently reversed it into a parked Ford Fiesta and royally fucked up the rear bumper, rear panel and bootlid. Did I mention I'm incompetent?
      There have been two other cars in my life. My first car, a 2008 Toyota Yaris 1.0 an it's replacement a 2012 Corsa 1.4T. I didn't really want either of them, but it's a long story involving my parents and poor life choices. Ask if you want to hear it!
      So that's a brief summary of my current shite. If you want more pictures or details of anything do say as I've got photos of almost everything I'd done with the cars.
    • By Tickman
      First some background:
      I was brought up with no car interest, a car was transport and nothing more which resulted in a selection of poor cheap cars being the cars of my youth.
      Fast forward many years (just over 9 years ago) and I have a wonderful* Vauxhall Vectra estate to carry us about. Unfortunately it is crap and throws fault codes at us with nothing being there when it is checked (even at Vauxhall)
      As Mrs T is the main pilot of this chariot with the two little miss T's on board, it has to go.
      The hunt is on for the new steed to safely and comfortably carry the family around. I have a company car at the time so big journeys are not an issue.
      ebay is my weapon of choice to find the new family car. It has to be good value cheap for no other reason than I am tight.
      Weeks of research with lots of cars that are too expensive and too far away for easy collection end up in my watch list.
      Finally a possible is spotted in Fife. I go and have a look and find a poor looking but solid car. One previous owner and lots of history.
      The auction was to end on the Saturday at midday, we were going to be out! I decided on how much I was willing to gamble on it and on the Saturday morning I put in my max bid but straight away it went to my max bid, I was winning but it had three hours to go with no room for me to go up! We went out anyway.
      I spent the next three hours kicking myself for not bidding more while we were out as it was the first car I had seen that fitted my criteria. Fate was in charge.
      On returning home I go straight on ebay to find 'Congratulations.............'
      For the grand total of £500 I had just won this fine vehicle!
      It has 5 months MOT and after fitting seat belts in the rear for the girls car seats it is pushed into daily service.
      My gamble and subsequent use results in a perfectly reliable car that actually does what it is supposed to do.
      Even more importantly Mrs T loves it so a win all round.
      All my cars have names (most are earned over a bit of time) and this one is called 'Gwendolen' ( G reg car and from Wales originally. I hate the name but I am not going to argue)
      That sums up part one, more will be along later (probably much later)
