Cobblers's VW T25 Syncro Doka and most of a Syncro Panel Van as well.
cobblers
 Share
9 hours ago, cobblers said:
MOT the other day, and it sailed through with just the yearly "play in rear wheel bearings" advisory that every T25 gets, and this one has had since it was imported.
I had to change the track control arm bushes because they had worked their way out to one side:
Apparently it's a thing that they do. It took a big lorry type ratchet strap to pull the arm across to get it back in place, not sure it the suspension lift is to blame but I will investigate this weekend.
Got all the new, bigger tyres on. I've cut the front arches to make them fit and feel guilty for it, but I did it to exact vw 16" syncro spec and kept the bits I lopped off in case I want to weld em back on.
They're about 35mm taller than what was on before but it hasn't really made much difference to how it drives, and they aren't particularly noisy either - they look great too.
I've got 4 people lined up to buy the 5 year old old BFGs for the same as these new yokos have cost!
Lets see the trimmed bit!
Link to comment
fitted the poly bushes to the radius rods, I've seen loads of horrors where the hole in the body was worn, or the adjuster threads are rotten etc. Luckily mine is perfect on both counts! I also spread the "v" out when putting it all back together so that it wasn't putting so much pressure on the tca bushes
It's driving a bit strange since new bushes, so with all that work done I checked the tracking:
Yep! that needs a tweak!
I got the arch cut bits cleaned up, painted, covered in dinotrol and fitted the spats to cover it up:
They look decent, took a little tweak to get them to fit where I was putting them, and it was very nerve-racking taking a powerfile to them as they were a flipping fortune!
Took it for a good run to check if they scraped, and I couldn't get them to.
One for you @twosmoke300 😄
Roof tent is coming off tomorrow so I can take it to get all the front end alignment sorted out properly, the tracking is OK but the camber and caster are all to cock.
It also needs the prop sorting again, the bearing fit loctite I used to make up the slightly loose UJ bearing fit into the housing has failed. FFS!
Link to comment
It nearly let me down this morning - A few splutters not far from home turned into running like an absolute bag of shit 8 miles later, doing 15mph flat out. Good job it was 6am sunday morning!
It got me in to work, but only just! I had to wind it up to my parking spot on the starter motor.
Had a poke round and soon spotted that the rotor arm was a mess, blackened, the epoxy had cracked and the end wiper bit was loose too. Dizzy cap was a mess too. What a load of shit! They're only 1600 miles old, if that!!!
Link to comment
  • 3 weeks later...
Well, after a full dose of "replacing all the ignition components" it still wouldn't run right, and in fact got worse and worse every time I tried to start it. Misfire seemed to mainly be on 1 and 2 as when I pulled the leads off them, not a lot happened.
I was at a loss, but clutching at straws I fired a load of the iso alcohol down the airbox and it started up fine! FFS!
I took a fuel pipe off to check for fuel flow it fired a load of air and petrol at me. So despite the gauge showing 1/4 of a tank (and the fact that I'd put £30 in the day before) it was empty. A jerry can of fuel in and it was running good as gold, infact better than before because it was definitely overdue those ignition bits.
Anyway with the MOT passed last week, I went on to fix some bits that should definitely have been picked up on the mot 😅
The prop that I'd replaced the UJs on last year seemed to be giving a bit of driveline vibration, so I checked it and as I was worried about, a couple of the bearings were a loose fit in the yokes. I stuck em in with bearing fit, but they have fretted loose and the whole rear joint could be moved up and down 3mm!! So I bit the bullet and ordered a brand new, heavy duty propshaft made with standard parts with grease nipples etc:
Then I went at the front inner CV joints as they've been very baggy for some time, plus the boots were some dodgy diy replacements.
that's better:
And I made a mount for the spare wheel (the bigger tyre won't fit under the back seat). It's just a quick thing chucked together with stuff I had to hand:
I've since swapped it over to mount the wheel on the drivers (near) side as on the first drive I was reminded how much you need a good "over the right shoulder" view when driving a LHD vehicle on our roads.
Also I decided to put a stereo in it. There was a bit of a cockup on amazon and I managed to buy one of these new Blaupunkt Bremen "80s" styled bluetooth head units for £260+ tax from amazon EU, it ended up at £310 landed which is less than these stereos seem to be selling for 2nd hand. It looks nicely at home.
My speakers however, are a little less subtle.
I've had these on the shelf for years, bought them when I thought they were being discontinued - they're just perfect for a noisy van as they're really efficient and kick out way more bass than they have any right to.
The old doorcards were a bit grotty, so I remade these from 6mm ply. Rather than carpet them (which would look out of place IMO) I got some UPOL Raptor tinted to match the front doorcars (RAL7005 Mouse/Navy Grey)
I need to get some less shiny hardware for them, or just put these in the media blaster to take the polish off.
Link to comment
  • cobblers changed the title to Cobblers's VW T25 Syncro Doka and other 4WD VW transporters - Shaftfest + Stereo fitment
that's better:
I have said it before and I will say it again. This thing is just too good.
Those spats finish off that corner without ever knowing anything was done. Door cards look ace in raptor. You would think they were metal or plastic. How well do you think it will last on the wood? I have a couple of items in my van that could do with some sort of paint/covering so this could be the trick.
I must have missed it but do you have the full fox kit on this?
Also I love those stereos but are they charging a bit of a premium to get something that look period correct? I have seen them fitted before but know nothing about them but keep seeing them mentioned?
Link to comment
Supposedly the raptor works fine on wood, I used a few coats of 2k grey primer on them to start with but mainly to get the colour "something like" as I wasn't sure if one bottle of raptor would be enough. Turns out it was plenty - its 2k so once you've put the hardener in you have 30 minutes to use it, unfortunately I had to chuck half the bottle away!
It has the fox remote-reservoir fully adjustable extended travel shocks and gowesty lift springs on, a previous owner fitted it all at massive expense. It's good, but I don't think I could personally have justified £3.5k on it!!
The stereos are definitely well overpriced for what they are - the sound quality is decent, build quality decent but they're nothing special, other than simply looking the part. I had considered buying an old period correct stereo and modifying it to add aux-in and bluetooth, but even rough old blaupunkts are £100, plus £80 for the bits, half a days work etc ..
Link to comment
Good to know, will have to get some. Should wear better as well as I was only going to paint my stuff.
I thought I could make out a reservoir in the one pic. I can imagine them being good but pricey?
Yeah not worth your hassle I can see that. Got one of the Aux Bluetooth adaptors on the way for my standard Ford unit. Should be was easier to install on my new unit however.
Link to comment
I've just come to change the battery on this (I noticed the one fitted is too tall, and from 2015..)
The battery fitted seemed to be an American type of battery - I spent a lot of time over there when I was younger and recognised the "style"
Sure enough, there's a faded label on the side with a Reno, Nevada zip code, a partial name and a partial phone number...
Googling all the parts of these things brings up a 47 year old mans name and all the details match...
So it seems that the van (or the battery at least) probably spent some time in the Nevada - that would explain why it's packed with a very orange, dry dust inside and externally has that nice "dry" patina you don't get on vehicles that spend a lot of time wet. And it also explains how the KFG muds that came on it were absolutely hard as nails, and why there's quite a few imperial fasteners been used on the exhaust and such.
Looks like I'm going to have to do some digging!
Link to comment
  • cobblers changed the title to Cobblers's VW T25 Syncro Doka - Did it come from Nevada?
It’s always a joy to see this getting lavished with care :). Did you sound deaden the doors whilst you were there? It made a big difference to the sound of the speakers in my T25. Also, since you’ve got loads of space under the seat, they’d sound even better with a sub and a high pass filter!
Link to comment
It's costing me a fortune but it doesn't feel like a waste, it's fundamentally such a good shell and I really enjoy driving it.
I didn't sound deaden the doors, but they really do need it as the metal on the side panel resonates like a steel drum 😅 I have got a load of fancy sound deadening pads somewhere, but I've got a feeling they're in the attic of our old house that some friends are staying in at the moment.
Oh, I got some less gaudy speaker grilles:
Link to comment
Well, the plot thickens a bit with regards to where this truck has been.
Digging through the 8 pieces of paper I got with the van (that's all the history unfortunately) I found the export paperwork from Sweden, and it seems to show an export date of 03/2006:
Which, along with the dust and the battery with the Reno address on it, I was convince it went to the USA.
I tried to do a Carvertical check to see if there was any service records / inspection history from America, but whatever data source they use has nothing whatsoever for this van, not even the UK mots or owt. I even tried searching by VIN as well as the reg plate.
In the end I tried a CARFAX check as they're more US based and claimed to have some records for the VIN:
So, nothing in the USA at all. God knows how it ended up with an ill-fitting battery bought in 2015 in Reno.
Another thing is that it seems to have been left Sweden in 2013, but was only registered over here in 2016 - maybe it just stood around for years? Perhaps it was imported by someone who brings a lot of VWs in and they pinched the battery off something they'd imported from the USA, I suppose I'll never really know.
I do know the swedish reg plate though - DOM201, and I'm wondering if there's any online MOT history check type things over there. There seems to be one promising service where you can get the last owners address if you text the reg to 72503 (https://www.transportstyrelsen.se/sv/vagtrafik/Fordon/fordons-agaruppgift/Sms-tjansten-vem-ager-fordonet/), but obviously you'd need a Swedish phone to do this. Perhaps @Dyslexic Viking knows someone 🤞?
Link to comment
The picture looks like a Swedish registration certificate? And I don't think this one has been in the US as Sweden has a lot of imports of older American cars, so a previous owner probably took the battery from an imported car from the US that's my theory. And the dust can be gravel roads? As Sweden has many of these.
And I tried using my Norwegian phone number to send a text to the Swedish registration office that you have posted here, but it didn't work. So maybe some of our Swedish members can help?
Nibbler
Rightnider
Link to comment
Well, the info I wanted was staring me in the face - The bloody registration document. I got google translate out, and what I thought was the address where you'd send it off, was actually the owner:
"Byggservice" = Construction service
"Ånn Aktiebolag" roughly translates to "Ånn town corporation" so it was sort of owned by the town of Ånn,
However, Ånn is such a tiny little town with just 70 inhabitants , and it didn't actually change owner according to carfax from 1999 to 2013, so hopefully someone remembers it?
Link to comment
Two 4wd VW vans? Why not buy yet another.
Bought sight unseen from Edinburgh with some quite upsetting pictures, the price was right.
I was sort of convinced it was a scam advert, it was very cheap and the ad text seemed a little "off" but when the seller (who has owned it since 1998) showed me his spreadsheet detailing every penny he'd ever spent on it my mind ws put at ease, especially when he pointed out the 5 new "Tigar" tyres that have plenty of tread left. These are 17 years old and are falling apart.
I've always wanted another panel van t25 after regretting cutting mine up to put windows in years ago, and I've got a soft spot (soft fucking brain!) for a syncro, and this is both.
Seems un-buggered-about-with. It's a 1.6TD, which are pretty bloody agricultural so that might not stay (PD/1.8t?)
This will be a bit more "hands off" to start with - Our very own Ceri will be collecting it and deliverying it direct to DST who did the welding on the last one. This needs much the same (and more):
Dan is booked up into next year, but he seems OK with storing it there for a while. I'll pop up and we'll have a look over it and decide exactly it's fate - if it will make a very good van, then we'll make a very good van out of it. If it's too sore to be perfect then we'll make it safe and solid.
Please form an orderly queue for the wheeltrims.
Link to comment
  • cobblers changed the title to Cobblers's VW T25 Syncro Doka and most of a Syncro Panel Van as well.
Um... actually could I have the wheel trims?  They look fscking awful on there, but aren't a million miles off what my camper would have had.  Against a mostly white 80s coachbuilt backdrop they would look rather less out of place I reckon.
Assuming they'll fit.  The wheels on this thing having quite a chunky dish on them has made finding something that fits a challenge.
Link to comment
Nice buy 👍  I've still got a new turbo from mine which I ended up scraping 😳 shame as I loved that bloody van, glad I never seen that one or would have been tempted for sure.
I finally got my old doka started after a new ignition module, a little pez down its neck and it started first time running from a can, the fuel in its tank looks rather like Syrup,.    Only problem is it's ticking over around 4k revs and won't drop ☹️ more investigation required.
Link to comment
That’s lovely, if a bit crispy in places. Very jealous of anyone with 2 T25s, even more so that they are both synchros!
Link to comment
The person to really be jealous of is S.J Baxter of Brickwerks Ltd, who has seen this thread and put in the order for his second yacht 😄
9 minutes ago, Lacquer Peel said:
My dad had a few of these vans and they were constantly breaking down and unreliable. But they look amazing and hold a lot of appeal, maybe for their very individual looks.
Yeah, they're a bit needy. I genuinely can't explain why I like them so much? I just get a good vibe when driving one, and find them just that right level of  "not too complex to work on" but "not too prehistoric" to drive every day.
Link to comment
That made me snort. I try not to think how much money he’s had off me over the years!!
This is it for me - had older (supposedly cooler?) VWs that were  just too slow and agricultural to use everyday, whereas these keep up pretty well with modern traffic. But they are free of complex electrics,  and the engines are all basic, so they are easy to work on and fix. Parts are also pretty easy to get next day (apart from the current shortage of main bearings for engine rebuilds). Strangely practical. All round could springs also means it rides quite well for a van…..
Link to comment
5 minutes ago, garbaldy said:
And not forgetting that weird feeling of sitting over the front wheels,.  My old van had 340k on it when I disposed of it.
The first time I rode in one was so strange hanging out front. In fact, I think I have just worked out why I like them.
When I was at school, about 15/16? an older brother of a mate of mine had a red Multivan Carat, when the other 19/20 year old lads had fiestas and stuff. He used to go camping in it, pick girls up and tackle them thoroughly in comfort, pack a load of band gear into it and whatnot. All the while I was pretending I wanted to drive fast in an XR2 or whatever.
I remember we all went out somewhere together and I was sat in the back of this van while we drove along the motorway, I had the table out in front of me and a bottle of beer in my hand, the air conditioning was on and it just felt pleasurable and I think from that point on I just associate them with good times.
Link to comment
And you thought:
"Now if only I could somehow sleep outside of this thing, like on the roof, this would be the perfect vehicle"
Link to comment
 Share
  • Similar Content
    • By 320touring
      A long time ago, in a galaxy far away, The Burd and I went to see the Skizzer to start getting a MK1 Golf Convertible that had been off the road for 10years..
      After a couple of sessions in deepest darkest Wales , coupled with some sterling help and fettling by Skizzer himself, it was time for us to head down and bring the thing back up.
      This went well:
      New tyres were procured and fitted
      The in-game tank pump was pulled out and a new filter fitted
      Then I got in touch with my Inuit side, using brand new* magnets to undertake "tank shite" fishing
      A full check over and a couple of test drives showed it fit to play.
      We set off for sunny Oswestry, only to have both front calipers sticking after 120 miles. Some water and time to collect down saw them free off and cause no further problems.
      Upon getting just past Tebay, it started running rough - nicking into Todhills rest area and luzzing in 10L of fuel had it running bang on for the next 70miles before it died.
      This was the final scene on the way home.
      I got to bed at 00:45, and left it to sit until today.
    • By SiC
      So to recap. After a painfully long time (well a month) I finally bought a MGB GT.
      I've always fancied one and after seeing one at a local garage (which turned out to be a bit shit) the urge sprang up again. Anyway after a lot of searching I ended up with this. Seems pretty straight and underneath don't appear to not been welded too much. Worst point that I've found in the leaf spring mount. I'm not going to cover all the different things and stuff just yet as its already in the thread, so I shouldn't make this too long!
      I've not owned a car this old and never something with a carburettor. So I don't quite know what I'm doing with a lot of this, and will have plenty of questions! Part of the reason why I bought it was so I had something that I could fiddle with and learn on. As the other thread got a bit long, I thought it would be a better idea to split and start here.
    • By Zelandeth
      So...we've got:
      1989 Saab 900i Automatic.
      1985 Sinclair C5.
      2009 Peugeot 107 Verve.
    • By robinmasters
      Yes, one of those. You've seen the car before, and I've already used up my best jokes (so I'll repeat them).
      An epic journey, including:
      - THREE COUNTIES
      - THAT LONDON
      - TRAINS
      - SHANKS' PONY
      - And possibly a pastry-encased but disappointing meal
    • By captain_70s
      Hullo,
      I'm a masochist from Leeds who is running two rusty, worn out Triumph Dolomites as my only transport in rural Aberdeenshire. You might recognise me from various other forums and Facebook groups. Realistically I need to buy a modern car of some sort, but instead I find myself looking at £300 Citroen BXs and Triumph Acclaims on Gumtree and thinking "yeah, that'd fit right in with the rest of the broken cars I can't afford".
      On to the cars, the main attraction being my 1976 1850HL "50 Shades of Yellow" that I bought for £850 and is currently my daily driver, here is a picture of it before I sanded off some surface rust and sprayed it badly in the wrong shade of yellow with rattle cans:
      Within a month of purchase I managed to plant it in to a steel fence backwards after a botched gear change on a wet roundabout and ruined the N/S rear wing, although judging by the other dent that's packed with filler it looks like somebody had already done the same. I also managed to destroy a halfshaft and one of my Sprint alloys (good for an extra 15hp) in the incident, so now it's sitting on it's original steelies but painted black (good for an extra 5hp).
      It's only broken down on me twice. once with some sort of fuel delivery related problem which may or may not have been an empty fuel tank and once when the thermostat jammed shut and it overheated and blew out some O-rings for the cooling system. It has recently developed a taste for coolant and oil which is rather annoying, although it's done 89,300 miles which is about 80,000 more miles than BL engineering is designed to last, I'm keeping my eye on eBay for replacement engines...
      I tried to keep ahead of the rust a bit by rubbing down the arches and re-painting them, but apparently rattle can paint isn't great when you are spraying it at -5C, it also highlighted how although my car might have been Inca Yellow in 1976 it's now more of a "cat piss" sort of shade. So I ended up with the wrong shade of yellow which has rust coming back through after 5 weeks. Did I mention I'm incompetent?
      The other car is the first "classic" car I bought, so I can't bear to sell it. It's a '77 Dolomite 1300 and it cost £1400 (about £400 too much) and has been nothing but a pain in the arse:
      It looks much prettier (from 100 yards) but that's most due to the darker paintwork hiding the rust. It lives a mollycoddled life in my garage, where it somehow still manages to rust, and is utterly rubbish. 0-60 is measured on a calendar, top speed is 80ish but at that point it uses more oil than petrol, it rarely ventures over 50mph and if you encounter an incline of any sort you can kiss that sort of speed goodbye, along with about £20 of 20W50 as it vanishes out of the exhaust in the form of blue smoke.
      One of the PO's had clearly never heard of the term "oil change" so it developed into brown sludge that coated everything internally with the next owner(s) blissfully pouring fresh oil on top of it. This lasted until about 600 miles into my ownership when there was muffled "pop" from the engine bay and the car became a 3-cylinder. The cause was catastrophic wear to the top end causing a rocker arm to snap:
      As this was my first classic car I'd assumed it was supposed to sound like the engine was full of marbles, it wasn't.
      I put the engine back together with second hand bits declared it utterly fucked and promptly did another 5000 miles with it. After about 3500 of those miles the oil burning started, valve seals have gone so it's been relegated to my parent's garage as a backup car and something to take to local car shows as the 1850 is now embarrassingly ugly. I'm keeping my eye on eBay for replacement engines (deja vu, anybody?) Oh, I also recently reversed it into a parked Ford Fiesta and royally fucked up the rear bumper, rear panel and bootlid. Did I mention I'm incompetent?
      There have been two other cars in my life. My first car, a 2008 Toyota Yaris 1.0 an it's replacement a 2012 Corsa 1.4T. I didn't really want either of them, but it's a long story involving my parents and poor life choices. Ask if you want to hear it!
      So that's a brief summary of my current shite. If you want more pictures or details of anything do say as I've got photos of almost everything I'd done with the cars.
