puddlethumper Posted June 24, 2022 Author Share Posted June 24, 2022 It looks like we will be moving to Stirling on Monday and Tuesday because the first show is on Thursday, instead of Wednesday, and only an hour away. Off to Dublin tomorrow driving the Tranny pickup with a horse box full of lighting and lecky stuff. If it wasn't for the Circus Vegas wrap I'd look well pikey. I've got bugger all to do till tomorrow so I'll show you the machinery on site. There is a low loader that hauls them around. I haven't got a photo of the hammer for the pins which might interest someone. Actually I've just noticed it's in the first pic. Pneumatic thingy. To think that before these it would a big manual bugger and when you consider the pins are 4ft long and all that's above ground after is about 6inches it was big muscle time, and the four main uprights are now electrically winched up which, obviously, makes it easier. Still hard work getting the canvas up.. I'll do a bit more later but at the moment the offy and food are calling. Crackers, Dan_ZTT, Split_Pin and 9 others 12 Link to comment Share on other sites More sharing options...
Dan302 Posted June 24, 2022 Share Posted June 24, 2022 I'm really enjoying the behind the scenes photos/write up from the circus, absolutely fascinating thank you. Matty, eddyramrod and LightBulbFun 3 Link to comment Share on other sites More sharing options...
jon.k Posted June 24, 2022 Share Posted June 24, 2022 Yes, thanks puddlethumper. Checking back all the time to see the updates. Matty and puddlethumper 1 1 Link to comment Share on other sites More sharing options...
puddlethumper Posted June 24, 2022 Author Share Posted June 24, 2022 2 hours ago, Dan302 said: I'm really enjoying the behind the scenes photos/write up from the circus, absolutely fascinating thank you. Cheers Dan. There is more to come as you can imagine. Haven't done much on the people yet. I hate the word soap opera but I reckon you could make one from this. Dan_ZTT, Dan302, Max Thunder and 1 other 4 Link to comment Share on other sites More sharing options...
High Jetter Posted June 24, 2022 Share Posted June 24, 2022 Ooh, do tell! Link to comment Share on other sites More sharing options...
puddlethumper Posted June 24, 2022 Author Share Posted June 24, 2022 For the performers and crew that don't have there own caravan or other accommodation there are three bunk house trailers with a number of bunk rooms each. Not luxury of course but good basic stuff with lecky, water, and I think some sort of cooking apparatus so you can make your coffee/tea, snacks breakfast etc. I haven't seen inside one yet but that's the sort of facilities you get. I'll see if I can get a pic. Max Thunder, Dan_ZTT, Dirk Diggler and 3 others 6 Link to comment Share on other sites More sharing options...
High Jetter Posted June 24, 2022 Share Posted June 24, 2022 So you're in comparative luxury? Link to comment Share on other sites More sharing options...
puddlethumper Posted June 24, 2022 Author Share Posted June 24, 2022 In the first pic, on the right, is a shower unit which has in the back two washing machines and a tumble dryer which was my job to get in and get water and lecky to. Another thing I put together was a tap to garden hose frame where six caravans/RV's etc can plug in. There are now three of these and there may come a fourth. Going to see how it goes with three first. Basically there is a certain way everything is laid out, with the exception now and again. It's sort of horse shoe shape where the front is the open bit and the rest is an inner and outer circle with enough room to get a vehicle around. Although it doesn't always completely work out. With these tap things I can put one half way down each side and across the back and nearly everyone can get water. The catering wagons get a separate one for now. This is all about making things quicker and more efficient. From the standpipe to these will be 20mm plastic pipe and the one nearest will be a straight through to either the next two or split to the others. Anyway here's a pic of the one from today. rainagain, garbaldy, Split_Pin and 5 others 8 Link to comment Share on other sites More sharing options...
puddlethumper Posted June 24, 2022 Author Share Posted June 24, 2022 3 minutes ago, High Jetter said: So you're in comparative luxury? Depends what you consider comparative. Link to comment Share on other sites More sharing options...
puddlethumper Posted June 24, 2022 Author Share Posted June 24, 2022 1 minute ago, puddlethumper said: In the first pic, above on the right, is a shower unit which has in the back two washing machines and a tumble dryer which was my job to get in and get water and lecky to. Another thing I put together was a tap to garden hose frame where six caravans/RV's etc can plug in. There are now three of these and there may come a fourth. Going to see how it goes with three first. Basically there is a certain way everything is laid out, with the exception now and again. It's sort of horse shoe shape where the front is the open bit and the rest is an inner and outer circle with enough room to get a vehicle around. Although it doesn't always completely work out. With these tap things I can put one half way down each side and across the back and nearly everyone can get water. The catering wagons get a separate one for now. This is all about making things quicker and more efficient. From the standpipe to these will be 20mm plastic pipe and the one nearest will be a straight through to either the next two or split to the others. Anyway here's a pic of the one from today. Link to comment Share on other sites More sharing options...
High Jetter Posted June 24, 2022 Share Posted June 24, 2022 1 minute ago, puddlethumper said: Depends what you consider comparative. No wife? puddlethumper 1 Link to comment Share on other sites More sharing options...
puddlethumper Posted June 24, 2022 Author Share Posted June 24, 2022 Just now, puddlethumper said: Tried to edit and did badly. When I said the first pic on the right I meant the crew quarters one. Link to comment Share on other sites More sharing options...
paulplom Posted June 25, 2022 Share Posted June 25, 2022 10 hours ago, puddlethumper said: For the performers and crew that don't have there own caravan or other accommodation there are three bunk house trailers with a number of bunk rooms each. Not luxury of course but good basic stuff with lecky, water, and I think some sort of cooking apparatus so you can make your coffee/tea, snacks breakfast etc. I haven't seen inside one yet but that's the sort of facilities you get. I'll see if I can get a pic. They look like police cells. Link to comment Share on other sites More sharing options...
puddlethumper Posted June 25, 2022 Author Share Posted June 25, 2022 2 hours ago, paulplom said: They look like police cells. We keep performers and crew locked up in case they run away from the circus. Dan_ZTT, Matty, mat_the_cat and 2 others 5 Link to comment Share on other sites More sharing options...
puddlethumper Posted June 25, 2022 Author Share Posted June 25, 2022 I know you all love* a guessing game so here's one. How much per week, in expenses, do you think it costs to have this show on the road ? Link to comment Share on other sites More sharing options...
Matty Posted June 25, 2022 Share Posted June 25, 2022 5 figures. That's the closest I'll get at this game! puddlethumper 1 Link to comment Share on other sites More sharing options...
doug Posted June 25, 2022 Share Posted June 25, 2022 Keep the posts coming. Loving this thread.Sent from my SM-A127F using Tapatalk Link to comment Share on other sites More sharing options...
High Jetter Posted June 25, 2022 Share Posted June 25, 2022 3 hours ago, puddlethumper said: I know you all love* a guessing game so here's one. How much per week, in expenses, do you think it costs to have this show on the road ? No idea how many cast & crew to pay, so hard to guesstimate. £15k? Link to comment Share on other sites More sharing options...
puddlethumper Posted June 25, 2022 Author Share Posted June 25, 2022 7 minutes ago, High Jetter said: No idea how many cast & crew to pay, so hard to guesstimate. £15k? I haven't counted but I reckon 30 maybe 35 people being paid. Link to comment Share on other sites More sharing options...
High Jetter Posted June 25, 2022 Share Posted June 25, 2022 Maybe nearer £20k then? Link to comment Share on other sites More sharing options...
DodgeRover Posted June 25, 2022 Share Posted June 25, 2022 On 6/24/2022 at 11:00 PM, puddlethumper said: For the performers and crew that don't have there own caravan or other accommodation there are three bunk house trailers with a number of bunk rooms each. Not luxury of course but good basic stuff with lecky, water, and I think some sort of cooking apparatus so you can make your coffee/tea, snacks breakfast etc. I haven't seen inside one yet but that's the sort of facilities you get. I'll see if I can get a pic. Used to call those the dog boxes, mostly only the single guys used them everybody else had something of their own. Link to comment Share on other sites More sharing options...
DodgeRover Posted June 25, 2022 Share Posted June 25, 2022 12 hours ago, puddlethumper said: I know you all love* a guessing game so here's one. How much per week, in expenses, do you think it costs to have this show on the road ? Absolutely shit loads, I'm assuming the acts are on a % of the door money and the rest are on a wage? Link to comment Share on other sites More sharing options...
puddlethumper Posted June 26, 2022 Author Share Posted June 26, 2022 Pneumatic pin hammer and anchor point for the main supports. mk2_craig, garbaldy, GMcD and 7 others 10 Link to comment Share on other sites More sharing options...
puddlethumper Posted June 26, 2022 Author Share Posted June 26, 2022 The Dublin trip has been put off till Thursday then back Friday. I didn't think it would happen just before a move. Probably won't be much news for a couple of days. Max Thunder 1 Link to comment Share on other sites More sharing options...
puddlethumper Posted June 26, 2022 Author Share Posted June 26, 2022 Here's a pic of Ivors yard and the donkeys. Folklore says it's good luck to have a donkey with the markings of a cross on its arse which his Jack and Jenny have. May be there's a connection with a cross on a donkeys arse and God. A bit odd. The little one is only a few months old and rather cute. garbaldy, Coprolalia, Dan_ZTT and 4 others 7 Link to comment Share on other sites More sharing options...
puddlethumper Posted June 26, 2022 Author Share Posted June 26, 2022 No more guesses on cost per week ? OK. It's £60,000 a week. Dyslexic Viking, Matty, Sheefag and 2 others 5 Link to comment Share on other sites More sharing options...
puddlethumper Posted June 26, 2022 Author Share Posted June 26, 2022 Here's a pic, particularly for@DodgeRover, but for others as well .of a two trailer set up. Dyslexic Viking, Max Thunder, Low Horatio gearbox and 5 others 8 Link to comment Share on other sites More sharing options...
CreepingJesus Posted June 26, 2022 Share Posted June 26, 2022 Really enjoying reading this! Couple of observations... DAF fuel gauges - they all do that. I had an XF years ago with an 'eco' LPG kit fitted, which made it 120L of gas, 85L of diesel. Notwithstanding that the LPG was a nightmare to fill (and I had a couple of lovely gas burns up my right arm) if the gas gauge went red, the diesel gauge went orange pretty soon after. Although I also had a CF that the needle just swung about at random. A dipper of thick steel wire did a better job! Fuel gauges aren't one of DAF's strengths apparently. Stand pipes - I used to move water into festival sites, about 20,000L a go. We used to get the metered pipes off local councils, but the old fireman's stand pipe did the bulk of the work. In a quarter of the time. Was that what Scottish Water's man's problem was? I know we kept an eye out for council clipboard warriors in the hedges, cos the fireman's pipe wasn't exactly legit for our purposes. puddlethumper 1 Link to comment Share on other sites More sharing options...
puddlethumper Posted June 26, 2022 Author Share Posted June 26, 2022 6 minutes ago, CreepingJesus said: Really enjoying reading this! Couple of observations... DAF fuel gauges - they all do that. I had an XF years ago with an 'eco' LPG kit fitted, which made it 120L of gas, 85L of diesel. Notwithstanding that the LPG was a nightmare to fill (and I had a couple of lovely gas burns up my right arm) if the gas gauge went red, the diesel gauge went orange pretty soon after. Although I also had a CF that the needle just swung about at random. A dipper of thick steel wire did a better job! Fuel gauges aren't one of DAF's strengths apparently. Stand pipes - I used to move water into festival sites, about 20,000L a go. We used to get the metered pipes off local councils, but the old fireman's stand pipe did the bulk of the work. In a quarter of the time. Was that what Scottish Water's man's problem was? I know we kept an eye out for council clipboard warriors in the hedges, cos the fireman's pipe wasn't exactly legit for our purposes. I'm not sure whether Water man thought it was theirs or took it for, very, safe keeping. Didn't ask. He was back with it within a few minutes. Just glad to get it back. Max Thunder and CreepingJesus 2 Link to comment Share on other sites More sharing options...
garbaldy Posted June 27, 2022 Share Posted June 27, 2022 Thank you @Split_Pin for putting me onto this thread 😉 @puddlethumper Is this the circus that's coming to Kelso soon ? Excellent thread keep up the good work 👍 puddlethumper 1 Link to comment Share on other sites More sharing options...
