Morris Minor Ratrod - Big Rusty Holes
SiC
 Share
Day off yesterday. So went shopping.
Removed the brake shoes, smashing my finger in the process as they sprung back.
Removed this banjo bolt union. Not seen this done like this before. Usually the bleed screw is part of the cylinder.
Incidentally the copper pipes have printed text on them. To me this says they're not that old, probably this side of the millennium. Not sure if 08.23 means 2008 week 23?
Removing the cylinder was a bit fiddly. It helped undoing the half shaft and a lot of wiggling.
Again new cylinder required the same amount of fiddling.
Then the fight of the springs to get the shoes back in place.
Replaced the crush washer on the banjo.
Pulled out the half shaft and replaced the paper gasket. Old gasket had gone completely hard.
This bearing felt graunchy, so I may end up having to pull this again to replace this. Also one of the wheel studs is damaged and stripping the threads on the nut.
Half shaft back in, tightened all back up for now.
I'll film the other side as I need to make an effort with my YouTube channel.
Link to comment
This engine is the one listed on the V5.
This lump has the markings of 8G on the tag. Having a brief look on the internet, it mentioned this is a 848cc engine.
Except it's not.
I was having a bit deeper search today as I was curious. The tag actually says 8G9 R. The R being the important bit. Internet says that this means it's actually a 948cc goldseal unit. Presumably R means reconditioned? Just funky BMC numbering going on where I guess one department made up different rules to another.
Src: http://www.austina30a35ownersclub.co.uk/Engines.aspx
This makes sense as why would you put a 848cc engine in a car that isn't exactly known for being over powered. Also the lump has a big sticker on it saying BMC GOLD SEAL with flaking gold paint.
No idea how well it runs though. I might lob one of the spare carbs on sometime soon and fire it up. Also stick an oil pressure gauge into the side as well and see it's health.
With a bit of luck it's a nice runner that could make bring another Morris (or A35) with a sick engine back to life. Just need to find another cheap Moggie now.
Link to comment
Gold Seal was a big ‘brand’ for remanufacturing in the late 60’s through to the 80’s.
 I’m not 100% sure exactly when the brand was launched but if you rocked up to some secondhand chariot and it had been fitted with a Gold Seal engine it was much desirable.
But back then, engines could get well worn very easily, especially if Nurse Gladys Emanuel had been running round town on full choke with lots of short journeys.
Link to comment
On 7/18/2021 at 10:56 PM, SiC said:
What's this box? Not googled it, but I guess possibly a alternator regulator? Seems to have too many terminals for that though.
It says Lucas on it. 😬
I would burn it now before it decides to self-sacrifice itself later at a most inoportune moment.
Link to comment
19 hours ago, Mally said:
Gold Seal engine was factory reconditioned by BMC.
My dad bought one from Ratcliffes  for £55, back in the day.    Google 'Harry Ratcliffe mini racer'.
But went on to be a brand in the Unipart portfolio, also joined by Silver Seal
Link to comment
Similarly to Ever Ready, their old red "Silver Seal" batteries. Guaranteed to be rather mediocre performance and leak badly.
Rather like BL's efforts of the same name.
Link to comment
Yes, and annoyingly I can't remember the distinction, but Silver was to a lower spec than gold. (I'd have known back then, have Unipart prizes including a...wait for it...FOUNTAIN PEN!)
Link to comment
Correct, presumably a smaller qty of new parts.  I can’t ever recall any published specification that detailed exactly what was replaced.
I bought a crashed Marina 1.8TC Coupe once because it had a Gold Seal engine in it.  The lad had ‘had an off’ and hit a tree which didn’t do the Marina any good.  I broke it up, flogged a load of stuff and got my money back, so ended up with a free engine.
Link to comment
  • 3 weeks later...
I've been doing the brakes on this recently still. Just done the handbrake cable and both sides of rear cylinders. I intend to make this as a video, so I'll put that up once I've finished the fronts and master too.
However I noticed a large chunk of underseal. Pulled it off.
Oh
Took the interior out to have a look on the other side.
Took the wing off for a closer look.
Rained ferrous oxide
It's bad but at least there is some good metal there.
Panels are readily available but still going to be a hundred quid or so for them. As the bottom is already full of patches and this is a tatty car anyway, I think I might be naughty and just weld a new panel straight over the top instead of butt welding. I'll cut off most of the dead metal first but welding over the top will be a lot quicker.
It's not as bad as some cars as you can readily get to the other side of the panel. So I can put copious amounts of paint and rust proofer between them. Or cut back once attached. That's my excuse anyway as I don't want this to take too long for getting back onto the road. Plus welding over the top is an order of magnitude better than the fibreglass repair it had.
Link to comment
  • SiC changed the title to Morris Minor Ratrod - Big Rusty Holes
See, I can't weld.  I have absolutely no ambition to learn.  Like some have absolutely no desire to learn to play three manuals of a pipe organ, we require those who can to give us the enjoyment.  You can weld.  I'm not saying you owe it to the rest of us, but a fudge is most uncharacteristic of your approach to all things cars.
Ultimately, it's yours to do what you wish with.  I wouldn't blame anyone for taking the shortcut when life's short enough as it is.  But just be sure it won't reduce the enjoyment you get from the car, always knowing it's there.  Niggling away at you.
Link to comment
Used to be a Gold seal place opposite Cadbury in Brum....Loads of old Technical drawings in the window along with a Cutaway A series...
Probably a Kebab shop now though, last went passed in 1999
Link to comment
One mans bodge is another mans repair! It's no different to an MOT patch that many have done either really. Also a world of difference between welding a patch vs slapping some filler in a hole in a structural sill (that I've seen done on here).
It'll be strong and rigid, which is all that really matters.
Link to comment
I went to Moss today for a gander on their panels. They don't have the right hand side in but they had the left. At £135 (after their current 20% discount) I won't be buying from them either.
I was hoping I could get away with this, but this doesn't have the top section that I most need. Probably why it's a lot cheaper as less fabrication was needed.
https://www.moss-europe.co.uk/repair-panel-rear-wheel-arch-front-rh-aaa1429-3.html
Their full panel was identical to this. I think this is what I'll need.
https://www.morrisminorspares.com/body-inc-panels-trim-c21/panels-c31/rear-inner-wing-full-r-h-uk-made-p828422
I'll also probably need this for the lip:
https://www.morrisminorspares.com/body-inc-panels-trim-c21/panels-c31/rear-arch-repair-flange-r-h-saloon-conv-p828547
So it might actually be easier to rip all the patches off the bottom and weld that complete panel in. That's if it fits properly...
Welds on those patches actually seem pretty nicely done, so may put up a fight to get those patches off. Or I'll cut it right back and use them as a base to weld to. Too removal might lead to nothing to weld onto.
The rear panel is UK made and should be ok. That arch lip is Sri Lanka made and are a bit notoriously hit or miss on accuracy.
Link to comment
I’ve been thinking about using those Minor inner wing panels to replace the totally rotten rear inner wings on my Hampshire. I’m never going to find the correct panels for it.
The profile looks similar, but I’ve no idea on sizing etc. If you do buy one, do you think you could measure overall length and height for me so I can see if it will be anywhere near?
Please and thank you!
Link to comment
I've ordered an inner arch and repair lips yesterday. Not had the delivery confirmation but it should either arrive tomorrow or Friday.
Link to comment
As (i assume) you don't have seat belts fitted a lot of this rot isn't a concern for a Mot so fibreglass patches while not ideal will get you on the road quicker than a marathon weld fest.
Actually thinking aloud technically it doesn't require a mot so you can do as you please to get it on the road and give it a good shake down to see if it floats your boat and decide if you want to continue sinking time/money into it or move it on.
Link to comment
Apart from panels arriving today, but also a replacement wheel bearing set for the rear nearside axle and a stud+nut.
The arch panel fits really well. So much so, I'm pondering about removing all the patches and putting that whole panel straight on. Not sure of the structural strength if I do that?
Arch lip repair isn't such a good fit - that's a Sri Lanka panel and they are reportedly never are. However it's not far off and I do wonder what I can get away with given a outer arch panel will be going on anyway. There are some pitted sections where the panel doesn't cover, so I may have to get some patches in small areas still.
The metal on the Moggie is very thick though. Not sure of the thickness but much more than I've seen on other cars previously. Possibly a good 1mm/20 gauge or even thicker? I guess this is why these cars have often lasted so long. Should hopefully make welding new panels on less of a pain.
Link to comment
 Share
  • Similar Content
    • By Broadsword
      I think the Broadsword fleet has become sufficiently complicated to merit a combined thread so that gradually all new additions will appear in one place.
      As of Sunday 17th March the situation is interesting.
      Two Citoren Xantias (remember the white Xantia of Excellence is for sale people!)
      http://autoshite.com/topic/34699-w-reg-citroen-xantia-20-hdi-xantia-of-excellence-%C2%A3999/
      http://autoshite.com/topic/34596-citroen-xantia-double-madness-rust/page-2
      A turquoise XJR6 pending overdue-collection (need that gone now!)
      http://autoshite.com/topic/34003-jaguar-xjr6-double-madness-double-sold
      An XJS 3.6 manual project which will get in high gear soonish. Wont be a keeper but will be fun getting it back to something presentable. Drivers fantastic!
      http://autoshite.com/topic/34664-jaguar-xjs-36-manual
      A Range Rover P38, which is turning out to be really rather good.
      And to mix things up even more I'm off on a collection caper today. Had first refusal on it and was expecting it to come around in a year, but things soon changed and no way was I going to pass up on it. It may well render the second Xantia redundant as I've got a really good feeling about this motor.
      In the meantime here are some snaps of the Range Rover. As usual it was a car I said I would probably never buy due to their reliability*. I have said the same of Jag XJR, XJS, XK8 and I have had all of those now. Basically the moment I declare buying a particular car is impractical or improbable, I end up buying one.
      Things to note on the P38. It's a nice colour with tidy body. The EAS has been removed. It runs and drives lovely and it doesn't have enough electrical problems to hinder progress. The main one is the driver's side window not working, but that should be fixable. I've tried changing the outstation, that didn't fix it. Might be wiring under the seat. Other than that I bought it and took it for an MOT the very next day, and it passed. Since then it had what seemed like a battery drain, but since unplugging the RF thingy for the remote locking and putting on a proper lead-acid battery, which the car can actually charge, unlike the modern lead-calcium batteries, it has been perfect. I will treat it to a full service soon.
      Stay tuned for the latest collection later today!
    • By Zelandeth
      So...we've got:
      1989 Saab 900i Automatic.
      1985 Sinclair C5.
      2009 Peugeot 107 Verve.
    • By Fumbler
      To mark the genesis of my fleet project thread I here present my new car: a 1997 Nissan Micra Shape-
      It really looks that good. There is a reason for this: its previous owner was an old lady who loved the thing so much so she made every effort to keep it in good shape. It originally came from Fleet in the GU postcode which suggests to me it was bought by the present dealer at auction, hence arriving down here in Kent. Before seeing the car I checked its MOT history and its only fails were thanks to broken stoplights, which shows me that it was very well cared for. I suppose an example of this was that on the last MOT, an advisory was a corroded rear silencer. The silencer on the car when I saw it was new. Methinks the lady wanted to keep it as good as possible. It was kept in a garage and so all the bumpers and black trim are very black and the tyres are in very good condition. Spare never used! Also included a free Dettol first aid kit from 1997.
      This car has 15000 genuine miles on the clock. We clocked over 15000 during the test drive! The lady owner really only trundled around her village in it and the MOT shows that it only did some meagre miles between tests. This, of course, came at a price. We saw a cherry red Micra from 2002 at the same dealer. Paint was shoddy and when they washed it the boot had massive sections of bare metal and it wasn't very happy. This car, however, is in fabulous condition and there was no contest between the two cars- it really is that good, inside and out. Immaculate interior, driver's airbag, cassette player... all there and all functioning (apart from cassette thanks to new battery and failed display). This meant that I bought it for £1600, £100 over what was my uppermost limit, but I knew I wouldn't see another like this that was in as good shape for a fair while. It was priced very ambitiously, at £1990, so I'm content in the fact I managed to slash a few hundred off the price. There wasn't that much paperwork though. All the dealership received was the logbook with 3 service stamps from 1998, 1999 and 2000, the radio key pass, a National Trust sticker, and the original paperwork holder. I suspect the old lady died and had her car auctioned, and the massive file of paperwork is now someone's egg carton, along will everything else she owned.
      As always, this car isn't exactly in showroom condition. While the inside is great and the floor is solid, and the underseal is in great shape, the not undersealed parts need a small looking at. Mainly the rear of the driver's side sill. It's really the only bubbling on the car. I suspect a well aimed stonechip managed to fester over the wintery salted roads, making it rust even more. It's around the size of a 5p piece, and will give me the opportunity to spray the insides of the sill with some chain oil to prevent any further corrosion. Behind the fuel tank there are a few rusty joints- places where the spraygun cannot get paint onto- which some Vactan and Dynax should put to rights. Alternator belt looks original because of the cracking and Nissan badges and will need doing soon as well as the front plate. As much as I like the 90's font and original dealer surround, the dishevelled R and general water ingress is a persistant MOT advisory. It could be the MOT station being strict (and most likely is considering there's a Saxo down the road with far worse blackening), however for the sake of peace of mind and all that, I'll get a new one made. The rear has already been replaced indicating this has happened before.
      All in all, I think this is a nice plucky motor. I'll have it by the end of the week; just got to sort out tax, insurance, and it's going to have an MOT. As part of the deal it's getting the MOT and an oil and filter change which will be something ticked off the list. It has some love scratches and chips here and there, but it drives well, is stiff and controllable, and should make out to be a nice summer project!
    • By BorniteIdentity
      This week, for the first time ever, I felt old. I have sciatica which swaps from one side to the other, arthritis in one hand and what I think is the beginnings of IBS. On top of that it took me 2 weeks to remember a registration number that once would take me 2 seconds, and I forgot my parent's wedding anniversary.
      I'm only 32.
      Shit. No I'm not. I'm 33. I forgot that too. (Genuinely)
      So, it's about time I committed some of my tales to paper. Well, a shonky server... but that's the best you can do in 2016.
      First up, a list of the cars I've owned (as best as I can remember) in chronological order.
      Main Cars
      1985 VW Polo Formel E. C158 TRT. This was given to me even before I passed my test.
      1991 Rover Metro S. J801 TAC. Bought about 3 months after I passed my test as I was convinced the Polo was about to shit its gearbox.
      1987 Volvo 360 GLT. D899 CBJ ___ Managed three months in a Metro before the small car and smaller petrol tank became a bore.
      Ford Mondeo and Honda Civic Coupe by Bornite Identity, on Flickr
      1999 Ford Mondeo Zetec. V384 DBJ. Still the most I've ever spent on a car. It was 3 years old and cost, from memory, about £8,000. Just think of the Rover R8s you could buy with that now!
      1987 Volkswagen Golf GTI 8v by Bornite Identity, on Flickr
      1987 Volkswagen Golf GTI D79 CVV. I very nearly bought a MK1 Golf 1.1 but was persuaded, by my father amusingly, to buy this one from a different friend. From memory I gave about £500 for it, and sold it to some racers later that year for about £300. Amusingly, 16 year later I'd sell the Hartge wheels that came with the car for £530.
      1999 Toyota Avensis CDX by Bornite Identity, on Flickr
      1999 Toyota Avensis CDX. V781 GDP. By far the best car I've ever had. Bought in 2002 for £5300, it had previously been a company car at British Telecom. I ran it from 62,000 to 174,000 before it became surplus to requirements. A German chap bought it on ebay for about £500 and drove over to collect it. Hero.
      2001 Ford Mondeo Zetec by Bornite Identity, on Flickr
      2001 Ford Mondeo Zetec. Y821 EEB. I should have loved this car. I gave £500 for it in 2008 which was stupidly cheap by anybody's standards. It needed 4 tyres (which actually was nice to pick good ones for once) and a coil spring. Sadly, it was just bill after bill after bill. I sold it and promised to never own another Ford. I nearly succeeded.
      1998 Nissan Almera by Bornite Identity, on Flickr
      1998 Nissan Almera GX Auto. S58 NLO. My late Grandfather's car and, upon reflection, my first proper attempt at bangernomics. I bought it for £500 in 2008 from the estate and ran it for well over a year and 30,000 miles. It was also my first automatic which, whilst a bit dumb, did lock up into overdrive and give a good 36 mpg no matter how it was driven.
      2004 Ford Fiesta 1.25 LX and 2006 Ford Focus 2.0 Ghia by Bornite Identity, on Flickr
      2004 Ford Fiesta Zetec. AG53 BWL. My wife's car which I ran for a couple of years when I bought her a Focus as a wedding gift.
      2003 Rover 75 by Bornite Identity, on Flickr
      2003 Rover 75 Club SE. AX53 BFA. This is where my career as a serial car buyer really began. Ignoring all of the warning signs I decided to press a K Series into a daily 100 mile commute, which it did with aplomb. This wasn't actually the car I set out to buy, the one I'd agreed to buy OVERHEATED ON THE FORECOURT whilst I was doing the paperwork. Consequently I couldn't leave fast enough and bought a different car later that day.
      2004 Toyota Avensis T30-X by Bornite Identity, on Flickr
      2004 Toyota Avensis T3-X. KT53 DWZ. Sensible head back on, I decided to get back into something I trusted when my 3rd son was born. This was a lovely car, but not without its problems. The VVTi oil burning issues are well documented and do frequently occur. Ironically, this was less reliable than the Rover it replaced! Despite fearing the worst and 3 months off the road, the new owner has just MOTd it.
      1999 Toyota Avensis SR by Bornite Identity, on Flickr
      1999 Toyota Avensis SR. V263 GDP. Back into bangernomics territory again. The last MK1 Avensis I had was the best car I'd ever had, so I hoped to replicate it with another T22 Avensis. This one came up for sale in my favourite (and rare) colour with a numberplate sequential to my previous car - so it was meant to be. I still have this now, and tomorrow it will tick around to 185,000 miles having been bought by me at 100,500.
      Side Bitches
      1974 Morris Mini 1000 by Bornite Identity, on Flickr
      1974 Morris Mini 1000. GEL 517N. Well, I always wanted one - and was young, free, single and well off at the time (2003). A memorable trip to buy it when I called my new girlfriend by my ex girlfriend's name 20 miles into a 200 mile weekend away. She's never forgiven or forgotten but we're still friends. Oh - and married.
      1977 Ford Capri II GL by Bornite Identity, on Flickr
      1977 Ford Capri II 1600 GL. SMY 675R. I can't remember why I bought this, other than I thought it'd be amusing. It was bought from Norwich for £350 and was perfectly well behaved for the 8 months that I had it (other than a flasher unit expiring). I remember being shocked just how much the windscreen would ice up inside, and duly sold it in November to a guy who was going to drive it daily! It's still alive and now, apparently, black! (Update - it's now silver!!!)
      1989 Volvo 340 DL by Bornite Identity, on Flickr
      1989 Volvo 340 DL. G67 AVN. I bought this for £80. Unbelievable. It was utterly bloody perfect. I wanted to do a banger rally which is why the guy gave it to me so cheap. I'm still yet to do that rally, but no longer have the car. I sold it for about £300 to a family who were clearly down on their luck who, I hope, still have the car.
      1996 Toyota Granvia by Bornite Identity, on Flickr
      1996 Toyota Granvia. N775 JEV. My wife and I decided to increase our numbers further and, with our 4th son on the way, larger transport was required. We quickly realised you can either have 4 children and no apparel, or apparel and no children. After trying a very tired Mercedes Viano, the Granvia was found for 1/4 of the price and it's still here 2 years later. I can safely say that we'll never sell it - it really is another member of the family.
      1993 Mercedes 190e by Bornite Identity, on Flickr
      1993 Mercedes 190e. L795 COJ. I've admired these cars since I was a child. In fact, one of the very few toy cars I still have from my childhood is a Mercedes 190e. Regular readers of "Memoirs from the Hard Shoulder" will know what a PITA this car has been since day 1, but I get the feeling it's a keeper. We'll see!
      1983 Ford Sierra Base 1.6 by Bornite Identity, on Flickr
      1983 Ford Sierra Base. GVG 510Y. Not explicitly my car, but it should be documented here for reference. Oh - and the V5 is in my name. The story is online for all to read as to how five of us acquired what is believed to be the only remaining Ford Sierra Base. Make a brew and read it, it's a fantastic story.
      1982 Ford Sierra L by Bornite Identity, on Flickr
      1982 Ford Sierra L. LCR 503Y. I accidentally won this on ebay for £520. Upon reflection, I shouldn't have sold it - but short stop of saying I regret it. I could never get truly comfortable driving it and, in fairness, I could scratch my Sierra itch with the base if I wanted. Sold it at a stupid profit of £1250. It is believed to be the oldest remaining Ford Sierra in the UK.
      1979 Volvo 343 DL by Bornite Identity, on Flickr
      1979 Volvo 343 DL. DBY 466T As you'll see above, I'd had a 360GLT as a younger lad and fancied one of these earlier cars. The variomatic is, frankly, terrible but amusing. This car has just 8000 miles on the clock and inside was absolutely timewarp. Sadly, the huge bill for the Mercedes 190e cylinder head rebuild meant I had to sell this car shortly after acquiring it. Since then I've had a bit of money luck, and now realise I didn't need to sell it after all. Typical.
      I think that's it. My arthritis is playing up even more now. I've left out a few cars that were actually my wife's, but if I find pictures will add them in at a later date. I'll run this as an ongoing thread on cars and what's happening.
      Current SitRep:
      Purple Avensis: Just about to click over 185,000. Minor drama this week when an HT lead split but otherwise utterly fantastic, fantastically boring and boringly reliable.
      Granvia: Just done 1000 miles in a month around Norfolk, 6 up with suitcases. 31mpg achieved on the way up which is good for an old tub with a 3.0 Turbo Diesel on board. ODO displaying 175,000 which is a mix of miles and kilometers. Say 130,000 miles for argument's sake.
      Mercedes: Being a PITA. It's had the top end completely rebuilt after the chain came off. Now needs welding to pass another MOT and the gearbox bearings are on strike. It's about to go into the garage for winter until I can stomach it again. 151,000 miles on the clock.
      Sierra bASe: Still on sabbatical with AngryDicky who only took it bloody camping in cornwall! Legend.
    • By Foz
      A new day, a new project
      In a moment of madness I agreed to go half with my brother on a 1951 Morris Minor MM named Geraldine.  The madness is that I already have a "project" which I have already posted on here some time ago (not much has happend to that), and I still don't have a garage to store any of them in... anyway the Minor was delivered yesterday and we spent most of the day moving a shed and fence to get the car round the back of my house, there is nice hard concrete floor to work off of back there.
      Well, about the car.  its rotten as usual, the door bottoms have completely gone and I suspect there is some rot in the "internal" door mounting panels as you can hear crunching noises when putting force onto the doors themselves.  the rear floor pans have detached from the rest of the car just below the back seat and I think a rear suspension mount is going to be needing replacement.  Luckily most panels for this car you can buy to fix most of the problems.  the unusual thing is that the sills and front floor pans seem to be fine (I think they've been replaced before) and the chassis/outriggers seem ok, a little crusty here and there but from what I can see sicking my head under the car it seem ok (not great, not bad).
      On the plus side the car has had the 1098cc engine and gearbox from a Minor 1000 fitted and it runs and drives.  sadly no history with the car except the old style logbook.  Not sure if the engine has been converted to unleaded but I will be checking that when the engine eventually comes out.  Gears seem ok but again a full service will be carried out.
      Plan is to hopefully within the next year build a concrete sectional garage around the car (concrete base already there luckily) and buy a body roller to do a complete body restoration.  luckily the bumper mounts seem solid and so hopefully use these to mount it to body rollover jig.
      This will be our first restoration for us but I think you cant get any simpler than a minor and its a good car to "learn" on. (fingers crossed), Though if anybody has any knowledge to pass on  I would be eternally grateful.
      Well here's some pictures of where the car stands now, work wont start straight away (I still need to buy most equipment, welder etc)  but any progress will always be updated here.
