1951 Lanchester LD10
vulgalour
 Share
Crikey the state of that wiring! It's going to be amazing with the new loom in 👍
It's like stripping down old pre ww2 acuum cleaners, always amazing they ran at all. Old Hoover cleaners get bonus death points though as the main loom runs under where the main carry handle of the cleaner is. Pick it up whilst plugged in and nudge the perished loom and zzap! (on an entirely metal vacuum)
Link to comment
The ribbed lens is the nicer looking, it's true, it's a shame we don't have another one.  That said, the flat lenses do seem to produce a visibly brighter light, probably due to the dimple they have where the bulb sits acting like a rudimentary magnifying lens.
Link to comment
They've got the 3-rib L464-3 on eBay- someone in Michigan has a hoarde of them for $80 a pop, there's also someone doing cast resin replicas for $45 in Washington.
That isn't bad considering they suffer from Expensive Marque Tax (Rolls Royce etc).
Phil
Link to comment
  • 4 weeks later...
There's less corrosion than expected on them, the trouble is the brass pins were both bent.  When we refit, we'll run a drill through the hinge holes to get them back to the proper shape in case there's corrosion and straighten or replace the pins.  I'll have to get a set of drifts/punches too since a screwdriver isn't the ideal tool for doing pins with.
Link to comment
Looking good!  That looked like hard work running that lot in, but you've made the car much more usable.  It's pleasing to see the bootlid so intact after 70 years, I reckon that there was a trim of some description over the lock/latch mechanism, there are some small holes for some sort of fixing around the access panel, and loose items in the boot might find their way into the bootlid/jam the latch if it were left open.  That's just a theory, but perhaps a small sheet of painted ply was put over that hole...
It's probably too late now, but wire lube is handy for getting a loom into reluctant grommets and small access holes.
https://www.screwfix.com/p/ideal-yellow-77-wire-cable-pulling-lubricant-950ml/44462  <-- 950ml will probably last you a few lifetimes
We use a similar thing at work, the stuff we use turns into a glue when dried (it's not a very strong glue, but it helps hold things in place).  A small dab of fresh lube will loosen things up if the wires need to be moved in the future.
Keep up the good work!
Link to comment
I'm not sure whether or not the lube would have helped.  With the wiring going through wood that would have absorbed any sort of fluid, and the wiring being cloth covered with no sort of finish over the cloth making it absorbant, it might have actually made it worse to use a lubricant.
However, now you mention the sheet of ply I wonder if there was a sheet of black millboard like the bits the boot interior hinges go through rather than ply since it would have probably blended in with everything else.  It wouldn't take much to damage millboard and have it fall off and be lost.  Someone has been into the bootlid before to put fresh wiring in it (and not very well done at that, it's not like the under-dash stuff) so perhaps they were the one that lost the trim panel that might have been there?
Link to comment
Good point, I forgot that your loom was cloth covered pvc wire and that the Lanchester has a wooden frame.   That is one job you shouldn't need to do again though!
Link to comment
We finally get the first new pieces of wiring into the Lanchester.  This is one of those jobs that is a lot easier in theory than in practice, especially when it's a job you're new to.  First job was to remove the boot lid.  Someone has had this off before, both hinge pins were only in half way so Pat and I assumed that they were the sort of hinges you had to knock the pins out of to get the boot lid off.  First one came out without too much hassle.  A skinny screwdriver and a hammer were all that were needed.  One brass pin removed, and looking just a little bit bent.  We'll tidy it up before reinstalling it.
The second pin put up more of a fight.  So much so that after ten minutes of solid hammering, application of lubricant, changing of positions... it was clear it wasn't coming out easily.  Later on we learned the pin itself was actually bent.
Of course, it was only after the pin being so stubborn about coming out that we were encouraged to look for hinge fixings and we found the two nuts that are sunk into the wooden frame.  Once those were unbolted, the boot came off no bother.
As with many things on this car, the boot lock mechanism is a fairly basic thing.  Pat and I aren't sure whether or not there should be a trim over this area.  We'll likely make something out of black millboard or similar to match what's already used in the boot since it seems a bit strange to leave this area exposed and there are some vacant holes in the aluminium surround that are in about the right place for fixings that might hold a trim in place.
The boot has been re-wired at some point, badly, and not in the same sort of materials as has been used at the front of the car.  Here we've already removed the wiring, but you can see the grommet it should pass through, and the puncture in the aluminium skin that needs dealing with.  The aluminium trim on the inside of the boot lid is held on with dozens of tiny once-chrome-plated flathead screws.
Pat and I had spent quite a lot of time trying to figure out what bits of the wiring loom went where.  The wiring diagram we have for the car seems accurate except for the colours.  The colours of the original loom don't match the new wiring loom, and neither looms match the diagram, so that really slowed us down on figuring out what went where.  Additionally, the modified sections don't match the old loom, the new loom, or the diagram.  To further confuse matters, the only help provided for the new loom is in the form of a colour key on the website of the company that provided it.  There's no indication of which physical section of the new loom is for which section of the car, ie: rear lights, engine bay, dashboard, etc.  So there was an awful lot of guesswork involved.  One clue was the plastic sleeving on the wiring since this is used in areas where the wiring is both exposed to the elements and in an area it's likely to chafe on metal.  Parts of the loom that are just plain cloth wrapped in the black and purple are usually (but not always) interior sections.  Here are the new and old sections of the rear lights wiring.
To fit the new wiring, I thought it best to remove the intermediate boot floor.  In theory, this should just be a case of undoing some screws and lifting the board out.  The rubber mat had thankfully not been glued down and is likely not the original.
There's a small hatch set into the main board, it wasn't clear what this was for at first since even though it's about the size of a battery, the battery lives under the rear seat.
When you look through the hole you see two pressed steel plates with a rubber skirt, this is obviously a part of the floor that's removable for some reason and the rubber skirt is to keep the weather out.
The fixings for the plates were missing and none of the fixings that came with the car were the right sort.  Anyway, what's underneath here then?
Ah yes, the fuel tank, or more specifically, the fuel sender.  This gives you easy access to the main fuel feed line that starts at the top of the tank and runs all the way down the chassis to the front of the car.  It also gives access to the only wire going to the fuel sender.  We know the fuel sender works so we didn't disturb any of this at the moment.
We also found out where the occasional smell of fuel was coming from.  The large diameter hose that joins the filler neck in the wing to the filler neck of the tank has perished and split.  We'll be replacing that before the car hits the road proper.
Next to remove the plywood board.  This is held down with quite a few bolts (or are these machine screws?) with cup washers.  They all came undone fairly easily.  The board required a good tug to get it free and once out it gave much better access to the boot floor proper.  The main obstacle to getting the plywood out easily is the millboard that the side hinges bolt to, something I can't remove because the fixings seem to have rusted solid and I can't get heat into them without damaging things.  A case of working around them for now.
The awkward thing to remove where the bolts for the spare wheel stops.  These are two brackets that are shaped so that your spare wheel doesn't push too far back into the space.  My arms are only just long enough to reach to get a tool on the nut on the underside and use a screwdriver on the top side.
All that finally out and we could get a proper look at what was waiting underneath.  Honestly, I was expecting quite a lot of rot and mess in here so I was very pleasantly surprised.
The intermediate floor is held in by quite a crude angle iron frame that's welded to the car body.  I'm pretty certain this isn't a modification, I've seen plenty of cars of this era with the same sort of boot floor, I've just never seen the underlying structure.  The welding is not pretty, but then I get the impression with cars like these that what isn't seen doesn't matter, rather like a glorified kit car.
I did find some suitable screws for the fuel tank cover plates.  These were a perfect fit on the thread length and pitch, and even on the button heads, and while crossheads probably aren't 'correct', they do the job.  They came from the spare door latches for the Princess.
Then the floor could be tidied and more closely inspected.  Happily, all the areas we couldn't see before are really solid.  Aside from paint being worn away and effectively flash rusting there's absolutely nothing of concern back here.  Everything will be cleaned back, giving some rust treater, and then painted with some black enamel to keep it good before the boot area is reassembled in the future.
Daylight could also be shone on the areas of concern Pat and I did know about.  Really, these are the worst bits (that we know of) on the car and because of how simple the shapes are and how good the access is, they held no concerns for me when it comes to repairing them.  In the future I shall chop out the rot, weld in (or possibly panel adhesive in) some fresh steel and this will all be sorted.  It's far enough away from the wooden framework to not cause me any concern and the steel is substantial enough on this car that I can't see it giving me too much grief.  I've welded a BX, so this should be no bother.
Then the momentous occasion of fitting the very first section of brand new wiring.  Now, I will point out that when I did this job my welder was not working, otherwise I would have done the welding first.  I opted to fit this piece because it's very easy to remove if I have to and should give a really good morale boost given that it should be a nice easy item to complete.
I spent a little bit of time with a file tidying up the screws that hold the P clips in place, a couple of the slots had got a little chipped when removing them.
I then checked what grommets had been provided with the loom and found out there were only two very large ones.  I'd later learn these were for the bulkhead.  No grommets are provided to replace the four required in the boot.  This was one of the items that really annoyed me with this loom, they're so cheap it would have been nice just to have had a couple provided as a courtesy.  Instead, I had to go and get some since I had none in that were suitable.
Then it was just a case of offering up the P clip behind the angle iron frame after threading them onto the wire, push the bolt through from the bumper side, and screw the nut on from the boot side.  Took no time at all to get this section installed.
Pat was then free to help with the interior wiring instalation.  Initially I attempted the sensible thing of carefully pulling the new wiring through with the strings I'd carefully run when removing the old wiring.  It was tough going, the new loom didn't want to go through that easily, and then one of the strings broke.  It took a while before Pat and I finally figured out that the new loom won't actually pass through the guide holes in the frame of the car in the same way the old wiring came out.  I'll explain why that is later in this post.  What we ended up having to do instead was install the wiring in the cabin in a very strange way.
You have to start in the middle.  The hole for the original wiring in the headlining needed to be opened out a bit, then the wiring for the passenger side semaphore could be fed through first, blindly finding the guide holes in the frame, until you reach the metal section just behind and above the B pillar.  There's a hole that runs diagonally down and forwards through the wooden frame that allows the wires to then emerge above the semaphore.
You then have to feed the entire rest of the loom that runs all the way into the boot, through the small hole where the interior light lives.  This is a chore.  One spur will follow the same sort of route to the semaphore on the driver's side as it did on the passenger's side.  The other long run then has to be fed through the guide holes in the roof frame, which is metal, all the way over the top of the rear door and behind the trim panel alongside the rear seat.  Pat did this, I'd lost my patience with burning my hand on the roof (it was a very hot day when we did this job).
Feeding the section down through the gap between the body and the seat was very difficult, it took us a very long time.  It would definitely have been easier to do this with the seat, headlining, and trim removed.  However, since we want to keep as much of the original materials as possible, removing the headlining was too risky.  If we damaged it we would likely have to replace the whole thing and while I have the skill to do that, it was something we wanted to avoid.  This was the price we paid for that.  With all of that run, I treated myself to installing the cleaned interior light (more on that in a future update), ready to be wired up later.
Getting the wiring through the tiny gap and guide hole in the frame hidden down the side of the seat took Pat and I more time than we care to think about.  It was a deeply unpleasant job.  Once done, the wiring then just needs to be run behind the millboard trim that the side hinges bolt into and it's done.
Amazingly, the headlining didn't stretch or tear, it's remarkably robust despite appearances. That meant I could tack it back into place using the same fine tacks Pat and I used when putting the door cards back together.  It felt a bit weird nailing interior into the wooden frame of the car, but that's how it was done so that's how we're redoing it.  There's another trim that goes over the top of this that needs longer tacks, a job for another update.
So why was it so hard to run the wiring?  This is down to the new loom itself.  The original wiring is constructed so that it's the wire, a cloth braid, and then a varnish of some sort to act as insulation.  The new wiring is the wire, a plastic coating, and then a decorative braid.  As a result, the new wiring ends up fractionally thicker for each wire.  That's not a problem until you get to the junctions and spurs where the wire is wrapped.  The new wiring is less flexible and bulkier and because the decorative braid is raw, it grabs the wooden parts of the frame that it goes through where the old varnished wiring would slide smoothly.  As a result, you can't pass sections of the new wiring through the old guide holes without opening them up a bit, something that's easy enough to do if the car is stripped down to bare bones, but impossible when you're working around interior trim as we are.  It's another courtesy item that would have been nice to be warned of with the kit since it does mean this new wiring isn't actually OEM replacement.  I shouldn't have to modify the structure of my car to fit something that's supposed to be like-for-like.
Speaking of like-for-like replacement that isn't, no spare bullet connectors are provided, that's something you have to buy extra.  At least one bullet connector has become partially detached during the process of installation and in a couple of places there aren't bullet connectors where there should be.  The semaphores require one bullet connector each that isn't there, and the rear lights are the same.  While the three connections on the rear lights only require one bullet connector, it seems remiss that it isn't on the loom.  I didn't have any in stock, couldn't order any for the same day, so I didn't get the rear lights connected up, sadly.
What I could do was install the new grommets I bought in an actual shop (the novelty) so at least the wiring could be kept nice and safe, ready to be connected properly later.  The old grommets were pretty dead.
So far our experience with the re-wiring has not been a fun one.  I'm very glad we didn't also decide to make the wiring ourselves, it would have been a nightmare.  The loom we bought is very nice, it's just annoying that there's a lack of practical courtesy with a few small items included like various grommets and spare connectors, especially for the price.  The total lack of any labelling on the components is also annoying.  Some of this is because it's the first time Pat and I have tackled a job like this, some of it is because it seems to be industry standard to cut these corners.  Personally, I'd like to see the company do better, especially since they're selling to the DIY market as well as to the restoration trade.
Link to comment
 Share
  • Similar Content
    • By Tommyboy12
      What do you get after 16 hours and 800 miles of driving on a Sunday to collect two cars? Well @sharley17194 picks up a 1997 Citreon AX from the depths of the Lakes on the North West coast past Keswick. However, we actually started the day by driving to just near Cromer on the East coast to pick up this!
      An Austin Montego poverty spec estate with a 1.3L A-series engine! Yes you did read that bit right! Yes I know the DVLA lists the model as 1.6... Yes its correctly registered as 1.3L. No I dont know if its a factory 1.3L! 😂
      My favourite part of all this??? (Apart from the doom blue colour and the absolutely terrible interior!) 281,000 miles on the clock!
      Collection went really well and the below posts follows my initial assessment of what is quite frankly the best car I have ever purchased.
    • By Fumbler
      To mark the genesis of my fleet project thread I here present my new car: a 1997 Nissan Micra Shape-
      It really looks that good. There is a reason for this: its previous owner was an old lady who loved the thing so much so she made every effort to keep it in good shape. It originally came from Fleet in the GU postcode which suggests to me it was bought by the present dealer at auction, hence arriving down here in Kent. Before seeing the car I checked its MOT history and its only fails were thanks to broken stoplights, which shows me that it was very well cared for. I suppose an example of this was that on the last MOT, an advisory was a corroded rear silencer. The silencer on the car when I saw it was new. Methinks the lady wanted to keep it as good as possible. It was kept in a garage and so all the bumpers and black trim are very black and the tyres are in very good condition. Spare never used! Also included a free Dettol first aid kit from 1997.
      This car has 15000 genuine miles on the clock. We clocked over 15000 during the test drive! The lady owner really only trundled around her village in it and the MOT shows that it only did some meagre miles between tests. This, of course, came at a price. We saw a cherry red Micra from 2002 at the same dealer. Paint was shoddy and when they washed it the boot had massive sections of bare metal and it wasn't very happy. This car, however, is in fabulous condition and there was no contest between the two cars- it really is that good, inside and out. Immaculate interior, driver's airbag, cassette player... all there and all functioning (apart from cassette thanks to new battery and failed display). This meant that I bought it for £1600, £100 over what was my uppermost limit, but I knew I wouldn't see another like this that was in as good shape for a fair while. It was priced very ambitiously, at £1990, so I'm content in the fact I managed to slash a few hundred off the price. There wasn't that much paperwork though. All the dealership received was the logbook with 3 service stamps from 1998, 1999 and 2000, the radio key pass, a National Trust sticker, and the original paperwork holder. I suspect the old lady died and had her car auctioned, and the massive file of paperwork is now someone's egg carton, along will everything else she owned.
      As always, this car isn't exactly in showroom condition. While the inside is great and the floor is solid, and the underseal is in great shape, the not undersealed parts need a small looking at. Mainly the rear of the driver's side sill. It's really the only bubbling on the car. I suspect a well aimed stonechip managed to fester over the wintery salted roads, making it rust even more. It's around the size of a 5p piece, and will give me the opportunity to spray the insides of the sill with some chain oil to prevent any further corrosion. Behind the fuel tank there are a few rusty joints- places where the spraygun cannot get paint onto- which some Vactan and Dynax should put to rights. Alternator belt looks original because of the cracking and Nissan badges and will need doing soon as well as the front plate. As much as I like the 90's font and original dealer surround, the dishevelled R and general water ingress is a persistant MOT advisory. It could be the MOT station being strict (and most likely is considering there's a Saxo down the road with far worse blackening), however for the sake of peace of mind and all that, I'll get a new one made. The rear has already been replaced indicating this has happened before.
      All in all, I think this is a nice plucky motor. I'll have it by the end of the week; just got to sort out tax, insurance, and it's going to have an MOT. As part of the deal it's getting the MOT and an oil and filter change which will be something ticked off the list. It has some love scratches and chips here and there, but it drives well, is stiff and controllable, and should make out to be a nice summer project!
    • By Zelandeth
      So...we've got:
      1989 Saab 900i Automatic.
      1985 Sinclair C5.
      2009 Peugeot 107 Verve.
    • By Peter C
      Woke up this morning, had a little time before I had to leave the house for work, had a quick look at what’s new for sale on Retro Rides and saw an ad for a W124 200E manual, located 15 miles from home. I had no intention of buying a car today but I had to have it! I called the seller and arranged a viewing.
      Faults:
      2 x rusty front wings (TADTS)
      1 x rusty rear arch
      Needs a polish
      Tracking is out because new track rod end was fitted for MoT
      Engine has oil leak/s
      Good points:
      It’s a W124 200E!
      5 speed manual transmission
      New clutch
      Brand new MoT
      Superb MoT history
      4 x as new Continental tyres
      Last owner for 15 years, her husband before that for 4 years
      Very tidy MB-Tex interior
      Drives well
      All electrics work
      The dealer kindly delivered the car to my house but I managed a pez station shot on route:
      Plans:
      Remove front wings, cut away rust and apply plenty of wob.
      In-situ similar repair for rear arch
      Clean and polish
      Service engine
      Adjust tracking
      Leave patina and enjoy the car as it is
      I will update this thread once progress is made.
      Hopefully these two will become good friends.
    • By dome
      This evening I venture forth into hitherto unknown lands (Kirkintilloch) to collect my latest acquisition.
      Which, naturally, has issues.
      I have purchased my first line of defence.
      Which appears to have antigravity properties
      More will follow this evening...
