Marm's Motors: swap completed
Marm Toastsmith
Forgot to ask in light of finding more crossmember woes on my car- have the engine undertrays been removed yet? They block the crossmember drains and give the inevitible crust in that area a kick start.
Link to comment
Good tip - I'll have a little look. I still haven't been under it at all, just been driving it (and loving it).
Link to comment
Good! The nice thing is that if the car doesn't have PAS, a holed crossmember isn't an MoT fail, or so I've heard.
Link to comment
This one does have PAS, pretty much the only concession to luxury, which is OK by me. MOT history doesn't mention any corrosion so I'm  blindly confident that it will be allright.
Link to comment
With the undertrays on they won't be able to see it. You'll only know about it once they fall off, due to the bolt holes being friction drilled into the thin mild steel. Usually corrosion starts at either end as they're the lowest point of the crossmember.
Link to comment
Sounds as if it will pass the MOT then. 👍
TBH I'll probably not go looking for rust problems on this car. The discovery of holes is rarely a cause for celebration. Out of sight, out of mind, it's a £200 micra, and while I intend to look after it, it doesn't need to be pristine. ;)
Link to comment
Micra oil leak is a bit worse than expected - it marks its patch fairly quickly. Hopefully it's rust-proofing the front crossmember, too.
  • Sad 3
Link to comment
Never mind the oil leak, the level's still fine after a week and a few hundred miles, but I ought to stick this back. Someone's made a go of it before and glue is visible. It's more of a hard plastic than rubber and apparently just trim, not a seal.
Wondering what kind of adhesive to use... the best thing would be something thin-ish that sets fairly slowly I think, so I can apply it and then push the trim back into place. I suppose it also needs to be fairly water resistant... any ideas?
Link to comment
More pressingly: sometimes the starter clicks but doesn't turn the engine over. So far, trying again has invariably solved the issue, but this evening, with the engine warm(ish), it took three tries, which has made me a bit nervous.
Seller reckoned the battery might be on its last legs and had charged it recently. I noticed the clamps were loose, they are tight now, but it hasn't made any difference...
  • Sad 1
Link to comment
It might seem expensive but you want Tigerseal here. The stuff is great and its black so it wont look too bad either.
Link to comment
I would put (a small amount of) money on it being the starter motor at fault.  I've changed two recently with exactly the same symptoms.  If you have a helper to hand and the starter is accessible, keep turning off and on until it does the click thing then, without letting the key turn back from the start position have them give the starter a whack (either directly or via a breaker bar etc).  If it suddenly starts turning then you've definitely found the culprit.
Link to comment
Having had a look underneath I think there's a good chance it's gearbox oil, which it appears is a bit of a PITA to check. At least if it's leaking there's still some in there...
Link to comment
Is the rear screen bonded in and the rubbers just a out trim?
If it is id sack the trim off and  back fill the void with tigerseal,
Cheaper alternatives are available,
Body+, and simply brand pu sealant are good and usually half the price of tiger. Any black poly sealant would do the trick.
Link to comment
4 hours ago, marm said:
First tank - pretty much thrashing it everywhere, mix of fast A-roads, windy b roads, and town driving.
You get a low fuel light? How decadent!
Link to comment
1 minute ago, marm said:
Wondering if I should treat myself to a code reader... Any suggestions?
Aldi sometimes do one. Cheap but works nicely.
https://www.aldi.co.uk/auto-xs-car-fault-code-reader/p/707370407397200
It isn't in stock, but there's tons of clones about.
Link to comment
1 hour ago, marm said:
Turns out it also has an engine management light. Wondering if I should treat myself to a code reader... Any suggestions?
I don't know if they upgraded the ECUs in these to OBDII. There's a window in the centre console that allows you to look at a bank of LEDs attached to the ECU. When you turn the key they'll flash a combination which will give you the the issue. I think the owner's manual has a list of combinations and the Haynes manaul definitely does. That being said, it could be the manifold lambda sensor that's gone wrong- it doesn't have any others downstream IIRC. Mine doesn't anyway but it's a few years older.
Link to comment
If nothing running wise has changed it. Id Disconnect battery, and it may not return.
Is this the first tank of E10 fuel in the motor now?
Link to comment
It's running fine, as ever. I treated it to a bit of premium on the collection mission but it's had at least 2 tanks of E10 run through it in my ownership.
Link to comment
Owners manual suggests taking it to a Nissan dealer but apparently it's non urgent as long as the light's not flashing. I'll have a look in the Haynes book later.
Link to comment
The light went out for a few days. At the exact moment I said to Mrs M, "that light's gone out", it came back on again.
Powering this new light seems to be using up all the petrol.  Not so much MPGs on this tank. Otherwise it's not noticeably affecting the running of the car.
I haven't even looked in the Haynes manual yet. But I did shell out for Tescos finest E5 premium.
Link to comment
Had a look in the Haynes manual - couldn't find anything regarding engine management light/fault codes.
Google says being a later coil pack equipped model it's OBD2 so I guess I'll buy a reader
https://www.ebay.co.uk/itm/Car-OBD2-OBDII-V-309-Fault-Code-Reader-Engine-Diagnostic-Scanner-Reset-Tools-P3-/393863802907?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
Haven't looked for the socket yet...
Link to comment
Should be in the fusebox that's to the right of the steering wheel
Link to comment
Took some interior trim off and banged/pushed out the dent from inside. It looks better in the flesh but worse in the fotos. Can't decide whether to fill it and attempt a half decent paint job or just rub down and brush some rustoleum on (I have a tin of white). Sprayed a load of Dynax S50 in the cavity for good measure in case of paint/seam sealant damage.
EF8DEF52-A7CF-4295-9FDB-8647D6494237.thumb.jpeg.848e67354c8a777cafd9312f4960e4e4.jpeg40B469F0-0D0A-455F-AC21-C918DEE65C56.thumb.jpeg.5530bb36e5050e8a098826b7a491eba1.jpeg908E0391-05C1-4F1A-8909-5550530BFD67.thumb.jpeg.89b22408ee5e1d83b3c3bc67142a3bb3.jpeg
More satisfying still was finally getting round to hoovering it out. It was filthy but came up well.
12EBAA0E-40AC-48F5-BB7F-EBD095B4DAAE.thumb.jpeg.5052de3d66c1b68e2d956c5d7d47d166.jpeg77D2E29D-4BD8-4045-88AE-C8D3DAB060BE.thumb.jpeg.0346f451a2612fd3cdbdcb5b8e0c60f9.jpeg
Link to comment
Running perfect on expensive premium/high octane/e5  fuel and the EML light has gone away too. Be interesting to see if economy is any better...
I suppose it needs it because it's a Sport.
Link to comment
