Conrad D. Conelrad Posted March 9, 2021 Share Posted March 9, 2021 Ghosty, if you’re stuck with this floor hole I can pop round with my welder and make it worse. chodweaver, Mally, Noel Tidybeard and 12 others 7 8 Link to comment Share on other sites More sharing options...
M'coli Posted March 9, 2021 Share Posted March 9, 2021 [Sickboy]It should preshent no sherious difficultiesh... [/Sickboy]* The metal's full thickness here, it's just fatigued and not corroded. * sporty-shite 1 Link to comment Share on other sites More sharing options...
Ghosty Posted March 9, 2021 Author Share Posted March 9, 2021 A steel plate has been sourced for MOT purposes. We don't have any rivets short enough though... Also, the boot lock is broken and needs replacing. That's not on the MOT list though. M'coli 1 Link to comment Share on other sites More sharing options...
Mally Posted March 9, 2021 Share Posted March 9, 2021 Presume pop rivets? Knock the ally off the mandrel saw it shorter, put it back on..... Short rivet. Solid rivet ? just cut it down. Ghosty 1 Link to comment Share on other sites More sharing options...
Supernaut Posted March 9, 2021 Share Posted March 9, 2021 Why has nobody suggested just getting it welded at the same garage that's MOT-ing it? As in; do all the other stuff then make a perhaps temporary repair to the seat to take it to a garage, and get them to check it over for an MOT and weld whatever plate is needed. No messing about taking it to different places here there and everywhere. Lacquer Peel, SiC, stripped fred and 2 others 5 Link to comment Share on other sites More sharing options...
Ghosty Posted March 9, 2021 Author Share Posted March 9, 2021 That costs too much - £50/hour in labour and I'd either have to pay for the interior to be stripped or keep carting the car about so I can add/remove interior. bigfella2 1 Link to comment Share on other sites More sharing options...
captain_70s Posted March 9, 2021 Share Posted March 9, 2021 I mean are you flipping it for profit or fixing it? If the former I doubt disclosing it's flaws and pop riveting plates into the floors in the public domain is a sensible resale strategy... davehedgehog31, BeEP, bigfella2 and 1 other 4 Link to comment Share on other sites More sharing options...
stripped fred Posted March 9, 2021 Share Posted March 9, 2021 If you're going to do it properly then it needs welding. You might get away with it but it's better to know it's safe, even if it costs a bit more. brownnova and bigfella2 2 Link to comment Share on other sites More sharing options...
twosmoke300 Posted March 10, 2021 Share Posted March 10, 2021 Some of the dodgy “ repair “ ideas on here at the moment involving seat and seat belt mounts worry me . In next weeks episode we show you how to use body filler in a grease gun to remove that annoying slop in ball joints and then the best way to apply it to rusty brake pipes ! Matty, SiC, Arthur Foxhake and 8 others 5 1 5 Link to comment Share on other sites More sharing options...
castros_bro Posted March 10, 2021 Share Posted March 10, 2021 As it's a Pug 106 1527cc diesel do you want to sell it to me before you do lots of work ? Link to comment Share on other sites More sharing options...
brownnova Posted March 10, 2021 Share Posted March 10, 2021 2 hours ago, twosmoke300 said: Some of the dodgy “ repair “ ideas on here at the moment involving seat and seat belt mounts worry me . For clarity... my removal of the rear seats to avoid a fail for seatbelt mounts was literally in order to avoid getting it trailered at great cost to garages for quotes as I knew it couldn’t go out travelling to specialists until after lockdown. No one has or will ride in the rear seats until it’s properly welded. stripped fred, Ghosty and St.Jude 3 Link to comment Share on other sites More sharing options...
twosmoke300 Posted March 10, 2021 Share Posted March 10, 2021 Didnt even mean your one 😆 brownnova 1 Link to comment Share on other sites More sharing options...
Ghosty Posted March 10, 2021 Author Share Posted March 10, 2021 5 hours ago, castros_bro said: As it's a Pug 106 1527cc diesel do you want to sell it to me before you do lots of work ? It's a petrol one, lol. Link to comment Share on other sites More sharing options...
Ghosty Posted March 10, 2021 Author Share Posted March 10, 2021 Minor update today. I figure I'll probably get it welded. Couple of packages came today, so for all but a few minutes work, here's a before and after. Supernaut, reb, theshadow and 14 others 17 Link to comment Share on other sites More sharing options...
Rod/b Posted March 10, 2021 Share Posted March 10, 2021 Is it just the photo or is that rear strip a different profile? Link to comment Share on other sites More sharing options...
Ghosty Posted March 10, 2021 Author Share Posted March 10, 2021 8 minutes ago, Rod/b said: Is it just the photo or is that rear strip a different profile? They're the same. The front one is dirty and hanging off a bit. Link to comment Share on other sites More sharing options...
M'coli Posted March 10, 2021 Share Posted March 10, 2021 Right, I've been thinking about the seat ratchet, and need convincing that it's ok. If you've repaired the mount, bolted it in and the ratchet works fine (by that I mean emergency-stop-proof) then good stuff, but if not may I suggest...? ...unbolting the passenger seat and bolting the driver's seat in its place - it'll have to face the rear seats for the brackets to line up - and see if it'll stay in place when you imitate an emergency stop (perhaps using both legs to replicate the strength you suddenly seem to possess in one leg when you're panicking!) And see if it holds? It's just a thought. Ghosty 1 Link to comment Share on other sites More sharing options...
Ghosty Posted March 10, 2021 Author Share Posted March 10, 2021 That's not a bad idea - I'll most likely need to take it out anyway. Link to comment Share on other sites More sharing options...
Ghosty Posted March 11, 2021 Author Share Posted March 11, 2021 Bit more done today. I changed the thermostat, changed the lives round on the radio so it keeps its memory (mechless, and actually a nice little radio), fixed a vacuum leak, and pulled the seats out: I followed @M'coli's advice: The seat ratchet works about half the time, but it doesn't feel right. I think I'll have to find a replacement. 500tops, stripped fred, privatewire and 2 others 5 Link to comment Share on other sites More sharing options...
rickvw72 Posted March 11, 2021 Share Posted March 11, 2021 Lift the carpets while your there, floor fractures around seat bolts and if really bad, around the handbrake. I used to buy and sell these, at a rate of about three a week at times. Welded that many it is silly, and that was about 10 years ago. Ive spoke out about wob and rivet repairs in the past. We shouldn’t encourage it. If it’s split, fractured or rotten, it needs welding. End of discussion really. (I’m a Motor vehicle lecturer who delivers mot training and mot refresher training, before im accused of armchair expertry again.) Great little cars when fixed though. Good fun. captain_70s, Lacquer Peel, twosmoke300 and 7 others 10 Link to comment Share on other sites More sharing options...
Ghosty Posted March 11, 2021 Author Share Posted March 11, 2021 17 minutes ago, rickvw72 said: floor fractures around seat bolts That's why the interior's out. I think I'm getting a welder tomorrow. Saabnut and Andyrew 2 Link to comment Share on other sites More sharing options...
rickvw72 Posted March 11, 2021 Share Posted March 11, 2021 Practice on some thin steel before trying a 106. The metal is really thin and can blow through easy. stripped fred and Ghosty 2 Link to comment Share on other sites More sharing options...
Ghosty Posted March 12, 2021 Author Share Posted March 12, 2021 Yay for more easy stuff. CV boot. The boot is fine - I suspect it's a replacement? However someone had attempted to hold it in place with a cable tie, I'm sure you can work out how well that worked. Replaced it with a jubilee clip, it's secure now. Rear light replaced as the lens was broken. Very easy - the light mounts on two thumbscrews, just clip in the bulb holder and stick it back in. One of the thumbscrews is hidden behind a vent so you need a screwdriver to get to it. Otherwise, did a bit of polishing, and cleaned up the rubbing strips, they were slathered in mastic for some reason and held in place with a variety of inappropriate screws. Stuck some rivets in the holes instead. The car's never going to be perfect, and the damage was already done (and all the trim clip holders are broken), so I don't feel too bad about it. It's really quite close to an MOT now. stripped fred, LightBulbFun, BL Bloke and 7 others 10 Link to comment Share on other sites More sharing options...
Mally Posted March 12, 2021 Share Posted March 12, 2021 Cable ties are supplied with some boot kits. Have you checked the jubilee clip revolves without catching? Lacquer Peel, Sigmund Fraud, mercedade and 2 others 5 Link to comment Share on other sites More sharing options...
twosmoke300 Posted March 12, 2021 Share Posted March 12, 2021 I was about to post the same thing Link to comment Share on other sites More sharing options...
Ghosty Posted March 18, 2021 Author Share Posted March 18, 2021 WIN. Can't take full credit as my dad is the sort of person that starts watching you do something then loses patience and snatches it away, but yeah. Just waiting for the replacement seat rail to arrive and it's MOT time. brownnova, Coprolalia, chodweaver and 7 others 10 Link to comment Share on other sites More sharing options...
Tepper Posted March 18, 2021 Share Posted March 18, 2021 Great little cars these. I picked up a ropey 106 XS fairly early in my motoring adventures, as I gave it death down the road leaving the seller's house the fault with the front seat mountings was revealed and the whole seat/base reclined bigtime, causing something of a brown trouser moment. The seller had clearly tried to bodge this, so I turned round and went back. She clearly just wanted the thing gone, so gave me some money back (pretty decent of her, I'm not sure I'd even ask now). I spent the money on beer, not welding, and continued to thrash the tits off that car making sure to hang on to the steering wheel during application of beans to prevent the seat rocking back. The back mounts were sort of functional, but came loose, so the seat just rocked back rather than becoming completely detached. Good times, hope you or the new owner enjoy this one as much as I did. chodweaver 1 Link to comment Share on other sites More sharing options...
mercedade Posted March 18, 2021 Share Posted March 18, 2021 10 hours ago, Ghosty said: WIN. Can't take full credit as my dad is the sort of person that starts watching you do something then loses patience and snatches it away, but yeah. Just waiting for the replacement seat rail to arrive and it's MOT time. Looking good. Does the handbrake warning light still work? 😀 Ghosty 1 Link to comment Share on other sites More sharing options...
Talbot Posted March 18, 2021 Share Posted March 18, 2021 You've still got to do something about that handbrake travel! It really should not double as a rocket launcher through the sunroof. .. and without being too much of a doom merchant, I'm not so sure about the jubilee clip on the CV boot. Cable ties do work if they are installed properly, especialy the flat steel "fold back" type ones. You might find the jubilee clip works, but you might also find you've introduced rather too much out-of-balance mass. Like this is what I mean: Arthur Foxhake, Tickman and Ghosty 3 Link to comment Share on other sites More sharing options...
Ghosty Posted March 18, 2021 Author Share Posted March 18, 2021 8 hours ago, mercedade said: Does the handbrake warning light still work? 😀 Yes Link to comment Share on other sites More sharing options...
