The temp sensor is on the passenger seat (there’s no sensor fitted now, as you saw in the video walk around thing I sent), the file with the history is in the footwell, there’s three keys (the new-looking one only works one way round as I recall), plus two immobiliser fobs. It needs a damn good clean, tyre pressures checking and (of course) an MOT. I don’t think I’ve done more than start it up for well over a year. Windows are sloooooow! I hope you give it the TLC it deserves, there’s a lot of memories in that car.
Share this post
Link to post
Well bought, I thought I recognised this form @motorpunk's thread back in the MX5nutz days- I had an '89 in SilverStone on a G reg at that time too. You'll be able to tell if it's a properly early one if there's only one hole in the slam panel, IIRC they changed to 2 holes about 6 months into production.
Share this post
Link to post
It's in good hands. It'll get the attention it deserves. My mate has a body shop. I wonder if he wants any plumbing done.
Sent from my SM-G975F using Tapatalk
Share this post
Link to post
It's here. What a laugh to drive. The temperature sender is fitted snd working now. I think the exhaust baffles needs a haircut.
Partner has nicked the keys and she's away.
I forgot how good they are.
182092bcffc4ab29318dd654af236c52.jpgb521b4ff5f2eeca661b6c91f36828924.jpgc0c691c28fe048afb8af40dc7d2219e6.jpg8221f1bf0f33563a5bf0a35a01064b47.jpgf010fc56b97dfe8e8944246a78466ed0.jpg
Share this post
Link to post
even Doggo seems to approve
exhaust looks interesting - can you just pull all that out and enjoy it being noisy ?
That's the plan.
Share this post
Link to post
TADIS. Cleaning the switches can help a lot and so does lubricating the window regulator with white grease. Remember having to do the same on the MK1 I had, back when it was "only" 20 years old.
Share this post
Link to post
Typically it's pissed down here more or less since it was dropped off. I was hoping to get stuck into it today.
The old sony radio that came with it has a really good sound. I suspect the speakers have been upgraded.
There is a mountain of paperwork with it and it looks to have every mot certificate from new,
Share this post
Link to post
I cut a small bit of aluminium sheet the same size as the switch unit, and put two of these in.  Work brilliantly
https://cpc.farnell.com/unbranded/js-511clc/toggle-switch-dpdt-on-off-on/dp/SW03353?mckv=sZIH9ErmR_dm|pcrid|224682624125|kword||match||plid||slid||product|SW03353|pgrid|49734256791|ptaid|pla-371789919038|&CMP=KNC-GUK-CPC-SHOPPING&gclid=Cj0KCQjw_ez2BRCyARIsAJfg-kteA88XsxjgUtJRfpY6jdNbDxZa6bTHxPvor2jVBuHt7rbaWSlIxuIaAoGZEALw_wcB
Share this post
Link to post
The switches work, it's just the windows are a bit slow.
If it stops fecking raining I'll lube up the window channels before I have a go at removing the door cards.
Share this post
Link to post
18 minutes ago, loserone said:
Don't, it's /always/ the switches.
About 5-10 years ago I had the door cards off and lubed the channels, I don’t think I’ve ever touched the switches.
Share this post
Link to post
4 minutes ago, Tickman said:
AVO I cleaned out the old misguided attempts to fix the slow windows from the channel
That's probably fair
Share this post
Link to post
I can't understand how it could be the switches. Surely they either work or don't work?
Share this post
Link to post
If you have the door crads off, use a 12v cordless drill battery to see if the motors run quicker if you apply power directly. I tested the windows off my breaker car and with only a 7.8v battery, they ran up and down quicker than any I've seen before.
(Edit) of course, they might just have been a set of unusually good window runners ?
Share this post
Link to post
Free money!
Using my tools of choice, I can't seem to get the switches off without damage.
Any ideas?c01f5ea3912ff66262dda85a299285af.jpg6039c038d92f87a8e4bb5bb47e655eca.jpg
Share this post
Link to post
