Christine Posted June 30, 2020 Share Posted June 30, 2020 Battery shot ? wanna haynes £5 posted ? Link to comment Share on other sites More sharing options...
bangernomics Posted June 30, 2020 Share Posted June 30, 2020 Big fuse popped? Link to comment Share on other sites More sharing options...
Robson3022 Posted June 30, 2020 Author Share Posted June 30, 2020 11 minutes ago, Christine said: Battery shot ? wanna haynes £5 posted ? I’ve tried two known working batteries so not that. Hopefully I won’t have it long enough to need the HBOL Link to comment Share on other sites More sharing options...
Robson3022 Posted June 30, 2020 Author Share Posted June 30, 2020 6 minutes ago, bangernomics said: Big fuse popped? Will that be the one behind the fuse box? Link to comment Share on other sites More sharing options...
Floatylight Posted June 30, 2020 Share Posted June 30, 2020 I had trouble with the fusebox on the zafira I briefly had, big problems when a bit of water gets in, there are about 4 layers of interconnections in it and the black it that sticks up is one of the ecu's..I would check the relevant fuses and if that fails under the allen/ tors bits and pull the top half out and put it somewhere to dry if you think you've spilled some water in..Google Astra J fusebox for th fear..Mine would wind the engine over and wouldn't stop, had to start pulling relays to get it to stop.Sent from my SM-A505FN using Tapatalk Link to comment Share on other sites More sharing options...
Floatylight Posted June 30, 2020 Share Posted June 30, 2020 P.s do not be tempted to separate the layers, so many wire links fell out..Sent from my SM-A505FN using Tapatalk Link to comment Share on other sites More sharing options...
Robson3022 Posted July 1, 2020 Author Share Posted July 1, 2020 Got in the Astra this morning and pressed the unlock button out of habit and it only worked. Got in, ignition, lights go go go it only started. Must have been some moisture somewhere!!! Free fix. Yes!!! It’s for sale but I won’t be putting it on here officially as I don’t know much about it. If anyone reads this and is interested send me a pm! paulplom and Floatylight 2 Link to comment Share on other sites More sharing options...
Robson3022 Posted July 7, 2020 Author Share Posted July 7, 2020 1 in and 1 out today! The disastra is going and I’m collecting this afternoon a fine* steed from this forum. I bet you can all guess what it is. Need to go on the OMGCOVID train across the border. Link to comment Share on other sites More sharing options...
Robson3022 Posted July 7, 2020 Author Share Posted July 7, 2020 It begins. Train taxi and essential kit Poo count 1 Jim Bell 1 Link to comment Share on other sites More sharing options...
Robson3022 Posted July 7, 2020 Author Share Posted July 7, 2020 First train station achieved. No delays Link to comment Share on other sites More sharing options...
Robson3022 Posted July 7, 2020 Author Share Posted July 7, 2020 Second station achieved DoctorRetro, purplebargeken and Jim Bell 3 Link to comment Share on other sites More sharing options...
DoctorRetro Posted July 7, 2020 Share Posted July 7, 2020 We need updates! Link to comment Share on other sites More sharing options...
Robson3022 Posted July 7, 2020 Author Share Posted July 7, 2020 Collected!! Forgot the Pez shot so take a Burger King one. Seems to drive well. Pressing on now so will update when home. its durrrrty Jim Bell, purplebargeken and paulplom 3 Link to comment Share on other sites More sharing options...
loserone Posted July 7, 2020 Share Posted July 7, 2020 Well, I know that tat has been collected The Moog 1 Link to comment Share on other sites More sharing options...
320touring Posted July 7, 2020 Share Posted July 7, 2020 I washed it last week - Was in my posh claes, so didn't do the bits I would need to climb for? Good to meet you! Safe run back paulplom, bangernomics, Robson3022 and 1 other 3 1 Link to comment Share on other sites More sharing options...
Matty Posted July 7, 2020 Share Posted July 7, 2020 You're washing too hard. You've fetched the paint of them roof bars ? 320touring and purplebargeken 1 1 Link to comment Share on other sites More sharing options...
320touring Posted July 7, 2020 Share Posted July 7, 2020 9 minutes ago, Matty said: You're washing too hard. You've fetched the paint of them roof bars ? Using a sharpening stone will do that! Matty and purplebargeken 1 1 Link to comment Share on other sites More sharing options...
Robson3022 Posted July 7, 2020 Author Share Posted July 7, 2020 Home!!! What ride height issues......?.?.?.?.? pleasure to meet you @320touring and thanks @TheDoctor. updates later 320touring, paulplom, Jim Bell and 2 others 5 Link to comment Share on other sites More sharing options...
Robson3022 Posted July 8, 2020 Author Share Posted July 8, 2020 So what have I bought in the cold light of day. Well what seems to be a reasonably tatty but well driving 4x4. Was happy enough at 70 with the cruise set last night. I’ve driven it to work this morning and it starts well and other than the exhaust seems mechanically pretty good. A couple of broken switches inside and the rear boot lock doesn’t work but I’ll work it out. It’s going to @scaryoldcortina to have a look at at lunch time to see if it’s worth putting an exhaust on it and I’ll go from there All in all not bad. Looking forward to cleaning it and seeing if it’s worth spending any time on the body work. Link to comment Share on other sites More sharing options...
Robson3022 Posted July 8, 2020 Author Share Posted July 8, 2020 So the results are in Needs 2 rear drop links and a cat* for MoT so it’s getting those and an MOT. It’s not due till October but I worry some of it might end up too frilly by then so it’s getting a fresh ticket!! I may then attempt to fix some of the frilly bits but every door bottom has gone plus the tail gate and there’s a dent in the leading edge of the bonnet so it will never be a looker. Link to comment Share on other sites More sharing options...
DoctorRetro Posted July 8, 2020 Share Posted July 8, 2020 5 minutes ago, Robson3022 said: So the results are in Needs 2 rear drop links and a cat* for MoT so it’s getting those and an MOT. It’s not due till October but I worry some of it might end up too frilly by then so it’s getting a fresh ticket!! I may then attempt to fix some of the frilly bits but every door bottom has gone plus the tail gate and there’s a dent in the leading edge of the bonnet so it will never be a looker. Get the matt black out, it will look well 'gangsta'. If that's all it needs, I should have collected it! ? Link to comment Share on other sites More sharing options...
Robson3022 Posted July 8, 2020 Author Share Posted July 8, 2020 12 minutes ago, TheDoctor said: Get the matt black out, it will look well 'gangsta'. If that's all it needs, I should have collected it! ? That and a cleaning bomb ? Link to comment Share on other sites More sharing options...
Robson3022 Posted July 21, 2020 Author Share Posted July 21, 2020 So the Merc has had drop links but I’m going to move it on. Spent a few hours cleaning it today. I would say it scrubs up alright but that’s a big fat lie. It does drive well though there’s just no need for it with the XC70 being much tidier, much better on fuel and arguably a nicer place to sit!! Volvo doing Volvo things. Still no Labrador on board. Merc washed and hoovered! Cord Fourteener and 320touring 2 Link to comment Share on other sites More sharing options...
320touring Posted July 21, 2020 Share Posted July 21, 2020 Lovely* ? Link to comment Share on other sites More sharing options...
Robson3022 Posted July 21, 2020 Author Share Posted July 21, 2020 18 minutes ago, 320touring said: Lovely* ? To be fair it got a new piece of duck tape too!! 320touring 1 Link to comment Share on other sites More sharing options...
320touring Posted July 21, 2020 Share Posted July 21, 2020 Have you had the v5 through yet? Robson3022 1 Link to comment Share on other sites More sharing options...
Robson3022 Posted July 21, 2020 Author Share Posted July 21, 2020 19 minutes ago, 320touring said: Have you had the v5 through yet? Yeah ages ago Link to comment Share on other sites More sharing options...
320touring Posted July 21, 2020 Share Posted July 21, 2020 Cool cool:) Link to comment Share on other sites More sharing options...
Robson3022 Posted July 21, 2020 Author Share Posted July 21, 2020 4 minutes ago, 320touring said: Cool cool:) I can see how you put the miles on it mind. It’s quite a nice place to be and with the cruise on it’s a reasonable steed to eat up the miles in. It’s a shame it’s so crusty and the Volvo is so good!!! Link to comment Share on other sites More sharing options...
Robson3022 Posted July 27, 2020 Author Share Posted July 27, 2020 So I did a whoopsie today preping a car. Guess where the keys were? Link to comment Share on other sites More sharing options...
