Robson3022 Posted June 10, 2020 Author Share Posted June 10, 2020 1 hour ago, paulplom said: Loads better. You’d made a canny effort mind! By the way how terrible were the fixings for the replacement grill you bought! paulplom 1 Link to comment Share on other sites More sharing options...
paulplom Posted June 10, 2020 Share Posted June 10, 2020 Shocking. They were just twisting off with minimal pressure. I haven't left them feedback yet. What would you like me to say? Sent from my SM-G975F using Tapatalk Link to comment Share on other sites More sharing options...
Robson3022 Posted June 10, 2020 Author Share Posted June 10, 2020 32 minutes ago, paulplom said: Shocking. They were just twisting off with minimal pressure. I haven't left them feedback yet. What would you like me to say? Sent from my SM-G975F using Tapatalk It’s like it’s been designed to be single use. I’m not sure I could re fit it even if I wanted to! paulplom 1 Link to comment Share on other sites More sharing options...
Shandylegs Posted June 10, 2020 Share Posted June 10, 2020 Always liked this. The best colour imo - but then again I’m a bit biased (mine just having a bit of a spruce up after some kind soul key’d it down the whole side). Robson3022 1 Link to comment Share on other sites More sharing options...
Robson3022 Posted June 13, 2020 Author Share Posted June 13, 2020 So the Volvo has had a huff because I’ve been tidying and using the mini so much! Fired it up today and after about 30 seconds it cut out and was running a little rough. Fired it up again and held the throttle a little and it seemed to clear. We’ve had a shed load of rain and it hasn’t moved so I’m hoping it’s just that. Thought I best give it some love! First job is to paint the headlight washer covers. Apparently these are prone to disappearing. Fortunately there were a set in the car. The only issue is they’re gold..... I have no idea what I’m doing but for my first foray into painting I don’t suppose I can do much damage. Keyed with some 600 wet and dry. Improvise, adapt, overcome. A borked seat cable from the Vectra and some washer pipe from the Bini S as hangers. First coat of primer on Goldendoodle normally inspects my work. Today it was the spiders shift a couple of coats later I put some base colour on but there’s obviously an issue with one of them. Probably a grimy finger mark. I used some 1500 wet and dry after the primer. Is that the right thing to do? Should I sand between base coats and between each coat of lacquer? See what happens tomorrow and I’ll be trying to rescue the fuel filler cap. paulplom 1 Link to comment Share on other sites More sharing options...
paulplom Posted June 14, 2020 Share Posted June 14, 2020 15 hours ago, Robson3022 said: I used some 1500 wet and dry after the primer. Is that the right thing to do? Should I sand between base coats and between each coat of lacquer? I didn't sand between coats. But then again I don't have a clue what I'm doing either. Link to comment Share on other sites More sharing options...
Robson3022 Posted June 14, 2020 Author Share Posted June 14, 2020 24 minutes ago, paulplom said: I didn't sand between coats. But then again I don't have a clue what I'm doing either. Your efforts on the mini inspired me haha. Although I have swapped the bonnet you painted so I don’t suppose that means much ?? paulplom 1 Link to comment Share on other sites More sharing options...
paulplom Posted June 14, 2020 Share Posted June 14, 2020 It's down to sheer boredom with me.Sent from my SM-G975F using Tapatalk Link to comment Share on other sites More sharing options...
Robson3022 Posted June 14, 2020 Author Share Posted June 14, 2020 Mid headlight wet sand. Not scared if I get it wrong as it came with a set of spare head lights. Beginning Middle end haven’t used my machine polisher for about 5 years (as much as I’ve threatened to!!) forgot how heavy it was. It’s done some work and seems to be pretty robust. I’m sure there are lighter fancier ones available now. Improvement is massive but I’ve still got lots of scratches. Do we reckon it’s just more work with finer wet and dry? Started with 600 and worked up to 1500?? Polished on a medium speed with my softest pad and a medium compound? Any shitters with better suggestions? Flat4 and paulplom 2 Link to comment Share on other sites More sharing options...
Shandylegs Posted June 14, 2020 Share Posted June 14, 2020 It will be one of two things: scratches caused by going from too coarse to too fine sandpaper, or; you not going coarse enough and haven’t removed marks in the headlights that were there to start with? In terms of painting, you wouldn’t believe the amount of times it goes wrong for professionals. They are just better at knowing what to do to recover the situation! Robson3022 and paulplom 2 Link to comment Share on other sites More sharing options...
Robson3022 Posted June 14, 2020 Author Share Posted June 14, 2020 23 hours ago, Shandylegs said: It will be one of two things: scratches caused by going from too coarse to too fine sandpaper, or; you not going coarse enough and haven’t removed marks in the headlights that were there to start with? In terms of painting, you wouldn’t believe the amount of times it goes wrong for professionals. They are just better at knowing what to do to recover the situation! Do we think 600 grit is coarse enough? I kept going until I couldn’t feel anything under the paper? Painting appears to have gone ok. Colour match isn’t amazing but I imagine fresh paint as oppose to 16 year old paint isn’t going to be great. Will see when I’ve polished the rest of the car. paulplom 1 Link to comment Share on other sites More sharing options...
Robson3022 Posted June 15, 2020 Author Share Posted June 15, 2020 Looks much better with its specs back on! Colour match is absolutely perfect as to be expected..... Think I’ll try and find a filler flap in colour rather than have it that far out!! Broadsword, Flat4, rainagain and 1 other 4 Link to comment Share on other sites More sharing options...
Robson3022 Posted June 15, 2020 Author Share Posted June 15, 2020 @paulplom not just 1 but two too kwality painters based in the north east. I think we should start a business together... paulplom 1 Link to comment Share on other sites More sharing options...
Robson3022 Posted June 25, 2020 Author Share Posted June 25, 2020 Soooo The drive is empty...... Soon to have 2 shitters cars in place. But what could they be? I seem to have become the unofficial autoshite bike rescuer allowing them to leave the fold and onto better lives. Less wollarding, pez shots and poo counts!! That’s the Civic, Bini S and Volvo T5 of many shitters gone from Autoshite I’d agreed to buy the T5 and a day or so after I collected it the Cooper S came up for sale. I bought them both because lockdown is boring. The plan was to drive them both for a bit and decide which one to keep. The mini was an absolute blast and I found myself jumping in it whenever I needed to go anywhere. However I then remembered I’m 33 with a dog, child and am an outdoor instructor so the practicalities of it were a bit useless. It was an absolute hoot to drive though, even if I did feel like I’d been kicked all over every time I got out of it! So I sold it on taking the Merc in p/x, which is going to a shitter in exchange for a fine piece of automotive engineering and not for something boring at all. That left the T5 which I was more than happy with. I’d tinkered and tidied it and was considering having the wheels re done when something popped up on here that would be perfect for my needs! So the Volvo also left to fold last night. A bit of a shame, turned out to be a pretty rare car in manual form so I was told. So 2 vehicles arriving in the next week or so. Place bets now!!!!!! paulplom and spartacus 2 Link to comment Share on other sites More sharing options...
Robson3022 Posted June 29, 2020 Author Share Posted June 29, 2020 Early morning collection!! This is a keeper. Off to the WLM capital his fine morning. I’m knackered. Why did I stay up last night reading Confessions of a Plummer till 2am! Ffs Breakfast shot first duty poo count 1 (Ralph’s) it’s going to be his car so thought it best he got involved. BlankFrank, paulplom, fairkens and 2 others 5 Link to comment Share on other sites More sharing options...
Robson3022 Posted June 29, 2020 Author Share Posted June 29, 2020 White goods transport fairkens 1 Link to comment Share on other sites More sharing options...
paulplom Posted June 29, 2020 Share Posted June 29, 2020 Good Luck! Link to comment Share on other sites More sharing options...
Robson3022 Posted June 29, 2020 Author Share Posted June 29, 2020 eta 8.30 Weather is disgusting paulplom and Split_Pin 2 Link to comment Share on other sites More sharing options...
Robson3022 Posted June 29, 2020 Author Share Posted June 29, 2020 Poo count = two. Still not found anywhere for a coffee Poo count 2 Link to comment Share on other sites More sharing options...
Robson3022 Posted June 29, 2020 Author Share Posted June 29, 2020 Pez shot with no pez as showing 220 miles and breakfast is required NorthernMonkey, Split_Pin, Flat4 and 4 others 7 Link to comment Share on other sites More sharing options...
Robson3022 Posted June 29, 2020 Author Share Posted June 29, 2020 Just got home in this. A few issues it was not as described there was no mention in the advert of the fully functioning parrot Bluetooth kit Or the factory fitted landline I was told it would do 50mpg anywhere. This was a lie it did 59.8 Finally it did not come with a Labrador as labelled This is such a good car. Really really pleased with it. Drives brilliantly and was certainly undersold. I love it. Would definitely buy chod from Burnley again!!!! I even payed 3p less than I thought! paulplom, Coprolalia, Flat4 and 5 others 6 2 Link to comment Share on other sites More sharing options...
Robson3022 Posted June 29, 2020 Author Share Posted June 29, 2020 Little niggles so far are center arm rest lid is broken. I think some gorilla glue will fettle it. It wants a good wash and polish, possibly gaiters for the hand brake and gear knob and erm, well.....nothing as far as I can see!! Goodendoodle approved! NorthernMonkey, stripped fred, Flat4 and 2 others 5 Link to comment Share on other sites More sharing options...
NorthernMonkey Posted June 29, 2020 Share Posted June 29, 2020 If I remember correctly, you were missold the picnic table that folds up out of the rear seat cushion too...I only discovered that at a later date! It would have cost you 33p less but I managed to fish the 20 and the 10 out earlier. Couldn’t be arsed with the copper... ? paulplom and Tickman 2 Link to comment Share on other sites More sharing options...
hairnet Posted June 29, 2020 Share Posted June 29, 2020 take lab sticker off and put a DOGWAGON one there instead did he give you a pie from baxenden Link to comment Share on other sites More sharing options...
Robson3022 Posted June 29, 2020 Author Share Posted June 29, 2020 3 minutes ago, NorthernMonkey said: If I remember correctly, you were missold the picnic table that folds up out of the rear seat cushion too...I only discovered that at a later date! It would have cost you 33p less but I managed to fish the 20 and the 10 out earlier. Couldn’t be arsed with the copper... ? I mean WTF is this picnic table all about! If you’ve been miss sold a vehicle from @NorthernMonkey please get in touch I feel we could get him banned! He also promised me a butter pie and all I got were these delicious farm shop sausage rolls. (I’ve eaten one and it was delicious but that’s not the point) 17.5/10 Flat4 1 Link to comment Share on other sites More sharing options...
Robson3022 Posted June 29, 2020 Author Share Posted June 29, 2020 3 minutes ago, hairnet said: take lab sticker off and put a DOGWAGON one there instead did he give you a pie from baxenden He did not Link to comment Share on other sites More sharing options...
hairnet Posted June 29, 2020 Share Posted June 29, 2020 yon phurn in centre console wtf Link to comment Share on other sites More sharing options...
Supernaut Posted June 29, 2020 Share Posted June 29, 2020 Knocking on the door of 60mpg in an automatic, AWD, jacked up estate car? Witchcraft. Tickman and Flat4 2 Link to comment Share on other sites More sharing options...
Robson3022 Posted June 30, 2020 Author Share Posted June 30, 2020 What’s better than 1 Astra?????? 2 Astra’s So I was offered this cheap cheap on account it has 180,000 miles. It’s got a bill for a full rebuild in 2018. It came to me and I moved it around yesterday. I was topping the water up and it wouldn’t start afterwards. The fuse box lid is missing so I may have spilled a little on there. I know it’s been stood a while so I tried charging the battery to be sure it wasn’t that, it helped in that the radio comes on now but no ignition lights or anything else does and it won’t even try to start? As I’m trying my best to start working on my own cars what do I check next? Could there be an issue with the key? Or should I just call in the cavalry? Anyway here is said beast. Link to comment Share on other sites More sharing options...
Agila Posted June 30, 2020 Share Posted June 30, 2020 I'd probably be checking all fuses and going through them all. Starting on the main likely suspects. Anything relating to ECU etc. bangernomics 1 Link to comment Share on other sites More sharing options...
