loserone 12991 Posted August 4, 2020 Share Posted August 4, 2020 Who the fuck are you and what have you done with Ken catsinthewelder and blackboilersuit 2 Link to post Share on other sites
purplebargeken 15263 Posted August 4, 2020 Author Share Posted August 4, 2020 Fuck...... rumbled. DSdriver 1 Link to post Share on other sites
Twiggy 2426 Posted August 4, 2020 Share Posted August 4, 2020 That looks tasty ! Link to post Share on other sites
purplebargeken 15263 Posted August 5, 2020 Author Share Posted August 5, 2020 She is ace! At the window tinting place as we speak. Link to post Share on other sites
320touring 19083 Posted August 5, 2020 Share Posted August 5, 2020 Coming along well there Ken, good stuff! Link to post Share on other sites
purplebargeken 15263 Posted August 5, 2020 Author Share Posted August 5, 2020 Here you go. Makes a huge difference inside.  privatewire, Fabergé Greggs, Jim Bell and 8 others 10 1 Link to post Share on other sites
loserone 12991 Posted August 31, 2020 Share Posted August 31, 2020 Have I called dibs on this already? Can I, please? Link to post Share on other sites
purplebargeken 15263 Posted September 1, 2020 Author Share Posted September 1, 2020 You have now but it will be a long, long wait Link to post Share on other sites
Fabergé Greggs 5470 Posted September 1, 2020 Share Posted September 1, 2020 How did I miss this??!! Looks bloody brilliant Link to post Share on other sites
purplebargeken 15263 Posted November 3, 2020 Author Share Posted November 3, 2020 Good morning everybody and I do mean........ everybody. The Espace has been doing very well indeed and has clocked up many miles without fault, however, there is an issue now. I had a brief period of slightly rough running a couple of weeks ago, nothing major, a slight stutter. I thought it was crappy fuel but it got a little worse. I got a local mobile mechanic out who said that it wasn't plugs or leads and that the throttle body needed a clean. He did this and it seemed a lot better. However, coming back to St Helens on Sunday was an issue. It struggled to start for a while, previously a first turn of the key car. It was running roughly, revs were dropping and surging and would cut out. AA were called but all seemed good, suspected crap in the fuel. Wasn't convinced but AA guy said to try and see how it fares on the journey to Merseyside. Off I went, on the A1 it started to judder, shake, and lose power. I pulled onto the hard shoulder and called the AA again, same bloke turned up and sported relay out for me. I had a quick look, the front two injectors can be twisted from side to side whilst in situ. So maybe seals have become tired? Or fuel pump maybe? Am going to contact Paul the Renault guru but he is very far away, too far to assist. Anybody know of a local mechanic that is happy to deal with older cars in the locality? SiC, Coprolalia and loserone 3 Link to post Share on other sites
Tenmil Socket 1582 Posted November 3, 2020 Share Posted November 3, 2020 1 hour ago, purplebargeken said: Good morning everybody and I do mean........ everybody. The Espace has been doing very well indeed and has clocked up many miles without fault, however, there is an issue now. I had a brief period of slightly rough running a couple of weeks ago, nothing major, a slight stutter. I thought it was crappy fuel but it got a little worse. I got a local mobile mechanic out who said that it wasn't plugs or leads and that the throttle body needed a clean. He did this and it seemed a lot better. However, coming back to St Helens on Sunday was an issue. It struggled to start for a while, previously a first turn of the key car. It was running roughly, revs were dropping and surging and would cut out. AA were called but all seemed good, suspected crap in the fuel. Wasn't convinced but AA guy said to try and see how it fares on the journey to Merseyside. Off I went, on the A1 it started to judder, shake, and lose power. I pulled onto the hard shoulder and called the AA again, same bloke turned up and sported relay out for me. I had a quick look, the front two injectors can be twisted from side to side whilst in situ. So maybe seals have become tired? Or fuel pump maybe? Am going to contact Paul the Renault guru but he is very far away, too far to assist. Anybody know of a local mechanic that is happy to deal with older cars in the locality? Citroen Tune? 01744 759001 Link to post Share on other sites
eddyramrod 17325 Posted November 3, 2020 Share Posted November 3, 2020 If you don't mind going over to Southport I can send you to someone, PM me... Link to post Share on other sites
purplebargeken 15263 Posted November 3, 2020 Author Share Posted November 3, 2020 I spoke to Renner Paul who said the injectors rarely fail and that movement is ok, he reckons ICV or dizzy cap woes. He will call me later with more info. Cheers re: Southport option but just wonder if it would get me there tbh. Ta re: Citroen Tune. I reckon the ICV is a good candidate as he said that they can get a bit sticky. I will try and sort it first and foremost, then try the locals. Thanks+++ Angrydicky 1 Link to post Share on other sites
SiC 20564 Posted November 3, 2020 Share Posted November 3, 2020 Is this an external fuel pump or in-tank pump? Might be worth doing the old screwdriver on the ear trick to listen how that's running. purplebargeken 1 Link to post Share on other sites
purplebargeken 15263 Posted November 3, 2020 Author Share Posted November 3, 2020 Not sure mate, will hopefully know more when Paul calls or messages. Link to post Share on other sites
purplebargeken 15263 Posted November 9, 2020 Author Share Posted November 9, 2020 Ok, had a chat with Paul the Renner Guru. He feels that it could well be blocked injectors following the use of some injector cleaner. Sounds odd right. Seemingly not. She is running rough. At a crossroads with this. Link to post Share on other sites
purplebargeken 15263 Posted November 9, 2020 Author Share Posted November 9, 2020 Just sounding it out but anyone interested in taking this over maybe? Link to post Share on other sites
loserone 12991 Posted November 9, 2020 Share Posted November 9, 2020 Maybe. What's the crack? How much, where, how many seats left? Link to post Share on other sites
SiC 20564 Posted November 9, 2020 Share Posted November 9, 2020 I reckon see if you can get it to @scaryoldcortina. He loves a good electrical problem and a old Renault! Used to anyway. I don't think you're a million miles away from him now. I still reckon its possibly the fuel pump dieing. Can you do the screwdriver stethoscope on it and have a listen. tonedepear 1 Link to post Share on other sites
purplebargeken 15263 Posted November 9, 2020 Author Share Posted November 9, 2020 Where...... St Helens. Seats........ all of em, 7 in total The crack........... it drives like it's missing and is idling badly. How much, well it owes me for all the work done (cambelt, clutch, rear brake cables, fuel filter, alloys and down pipe) but ........... not sure make me an offer that isn't a punch in the throat. Link to post Share on other sites
loserone 12991 Posted November 9, 2020 Share Posted November 9, 2020 ^ that is basically my plan tonedepear, The Moog and somewhatfoolish 3 Link to post Share on other sites
SiC 20564 Posted November 9, 2020 Share Posted November 9, 2020 Also I'd try disconnecting the MAP sensor and then try disconnecting the Lambda sensor (if it has one). There can't be many things wrong with this as there isn't a lot to them! Did you try throwing new rotor+cap+leads+plugs? Link to post Share on other sites
purplebargeken 15263 Posted November 9, 2020 Author Share Posted November 9, 2020 No, not really looked at it, no energy, it's a lovely old bus and is a hoot to drive but I am  actually majorly exhausted 99% of the time. It has a near full tank of petrol too. SiC and loserone 2 Link to post Share on other sites
somewhatfoolish 7430 Posted November 9, 2020 Share Posted November 9, 2020 10 minutes ago, purplebargeken said: It has a near full tank of petrol too. GIB! Link to post Share on other sites
purplebargeken 15263 Posted November 10, 2020 Author Share Posted November 10, 2020 Sadly Citroen Tune can't help as the Espace is too big for their ramps. loserone 1 Link to post Share on other sites
purplebargeken 15263 Posted November 10, 2020 Author Share Posted November 10, 2020 There is a place 1.5 miles away that I will try. There is also the mobile guy that came around previously despite his thinking that it was the throttle body needing cleaning. loserone 1 Link to post Share on other sites
purplebargeken 15263 Posted November 10, 2020 Author Share Posted November 10, 2020 Going to try and get the old girl over to the Haydock Service Centre tomorrow morning. They seem friendly enough and willing to have a look. Fingers crossed. privatewire and loserone 1 1 Link to post Share on other sites
purplebargeken 15263 Posted November 11, 2020 Author Share Posted November 11, 2020 Well, got here ok, a bit of stuttering and spluttering and two cut out episides at low speed. Getting here is good. Fingers crossed. I will update accordingly. Dirk Diggler, loserone, Coprolalia and 1 other 4 Link to post Share on other sites
2flags 167 Posted November 11, 2020 Share Posted November 11, 2020 Good luck with this. purplebargeken 1 Link to post Share on other sites
purplebargeken 15263 Posted November 11, 2020 Author Share Posted November 11, 2020 No update news today. I will give them a call midmorning and see what they say. Link to post Share on other sites
